DGS-6600-CM-IIProjektideks
CPU Module for DGS-6600 Series
Kust osta
Kirjeldus
Põhiomadused
• Switching Capacity: 480W
• 1x Female DCE RS-232 DB-9 console port
• 1x Female USB series type B console port
• 1 x RJ-45 Out-of-band management port for out-of-band SNMP / Web / Telnet management
• 2 CF card slots for portable images and configurations files
• CPU: 1.3GHz
• RAM: 2GB
• Flash memory: Prom 4MB, Runtime 1GB (internal CF card)
Füüsilised parameetrid
Power Consumption
Max: 53.856W
Heat dissipation
183.6BTU/hr
MTBF (hours)
263,581
Operating temperature
0 to 50°C
Storage temperature
-40 to 70°C
Operating humidity
10% to 90% non-condensing
Storage humidity
5% to 90% non-condensing
Sertifikaadid
Sidustooted
DGS-6600-CM-II  CPU Module for DGS-6600 Series
Pildid
DGS-6600-CM-II
Eestvaade
Vasakvaade
Failid
Vaadake samuti
