Kiirotsing
Toote omadused:
10G XFP CWDM transceiver for single-mode fiber optic cable (wavelength 1331nm, up to 10 km)
Projektideks
Põhiomadused:
Standard
• Standard compliance: IEEE-802.3ae, 10GBASE-SR
• Tranceiver type: XFP
• Fibre Channel FC-PI Standard: 1200-SM-LL-L
• Fiber Media Support: Single-Mode
• Distance capacity: 10km
Features
• Hot Pluggable
• MSA Compliant
• RoHS Compliant
Speed
10Gbps
Interface
• Connector: Duplex LC Connector
• Single/Bi-Directional: Single Direction
• Wavelength: 1331nm
• Output optical power (TX optical power):
  Max.: 3dBm
  Min.: -2dBm
• Input optical power (RX optical power):
  Max.: 0.5dBm
  Min.: -12.6dBm
• Sensitivity: -12.6dBm
• Cable type: Single-mode 9/125 um fiber
Füüsilised parameetrid
Operating
• Power: 3.3V
• Maximum input current:
   3.3V: 500mA
• Minimum power budget: 10.6dB
• Maximum power budget: 15.6dB
• Heat generated: 5.94kJ/h
Reliability
MTBF (hours): 818,000
Physical and Environment
• Operating temperature: 0 to 70°C
• Storage temperature: -40 to 85°C
• Operating humidity: 0 to 85%
• Storage humidity: 0 to 85%
• Dimensions: 18.32 x 77.92 x 11.42mm
• Weight: 48.5g
EMI
CE
Safety
UL, TUV, FDA/CDRH
Tooted ja lahendused | Tootetugi  | Uudised  | Firmast |
