Kiirotsing
Toote omadused:
SFP Transceivers 1 port 100Base-FX for singlemode fiber optic cable, power supply 3.3V (up to 15km)
Põhiomadused:
Cable
Single-Mode Fiber
Fiber Type
9/125um Single-Mode
Max. Cable Distance
15 km
Standard
802.3u 100BASE-FX
Data Rates
100Mbps
Port Type
Duplex LC
RoHS Compliant
Wavelength
1310nm
Füüsilised parameetrid
Output Optical Power
Max. -8dBm, Min. -15dBm
Sensitivity
-32dBm
Power Budget
17dB
Power Voltage
3.3V
Operating temperature
0 to 70°C
Storage humidity
-40 to 85°C
MTBF (hours)
3259763
Dimensions
13.4x 56.4 x 10.35мм
Weight
0.0164kg
Emission
FCC Class B, CE, ICES-003, VCCI
Safety
FDA/CDRH, TUV, UL
Tooted ja lahendused | Tootetugi  | Uudised  | Firmast |
