DPS-800Projektideks
2-slot chassis
Kust osta
Kirjeldus
The DPS-800 chassis can hold two DPS-200, DPS-300 or DPS-500/500DC and is useful for adding a few RPS to the equipment rack.
Using the chassis, users can save space, while their cabling will look neat. The chasses are not equipped with any power supply of their own. All redundant power supply units installed in the chassis will connect directly to their power source. As they are independent units, they are hot-swappable when used with the chassis.
Põhiomadused
Technical specifications
2 slots chassis for DPS-200/300/500/500DC
Füüsilised parameetrid
Operating temperature:
0 to 40°C
Storage temperature:
-10 to 55°C
Humidity:
20% to 80% non-condensing
Dimensions:
482 x 180 x 55mm
Weight:
1.06kg
Sertifikaadid
Sidustooted
DPS-800   2-slot chassis
Pildid
DPS-800
Eestvaade
Failid
Vaadake samuti
