DWS-4026EOL EOS
Kirjeldus
The DWS-4026 is D-Link’s next generation L2+ Unified Wired/Wireless Gigabit Switch with an array of advanced features and 802.11n support. With the ability to manage up to 64 DWL-8600AP wireless access points by itself and up to 256 DWL-8600APs in a Switch Cluster, the DWS-4026 is a full-featured and cost-effective mobility solution for mid-tolarge enterprises and service providers. Extremely versatile and flexible, the DWS-4026 can be deployed as a Wireless Controller in the core network or as a L2+ PoE Gigabit Switch at the edge depending on the customer’s requirement. By centralizing WLAN configuration and management functions, DWS-4026 enables network administrators to have control, security, redundancy, and reliability needed to scale and manage their wireless networks easily and efficiently.
Adaptable Wireless
Most of the current Wireless LAN controllers’ architecture requires wireless traffic to return to the controller for centralized processing, causing unnecessary traffic delay. The DWS-4026 offers network administrators additional options: depending on the wireless application, wireless traffic can either be tunneled back to the switch for better security control, or locally forwarded at the access point for optimal performance. This device offers administrators maximized flexibility with options to tunnel client traffic to the switch for centralized security control, and forward VoIP traffic directly from the access point for optimal performance.
Comprehensive Wired/Wireless Security
The DWS-4026 offers a state-of-the-art Wireless Intrusion Detection System (WIDS), which empowers network administrators to detect Rogue Access Points and Rogue Clients as well as anticipate wireless threats, preventing them from causing damage to the network. With WIDS, administrators can activate various threat detections and use RF scans to sweep the entire wireless network for any possible security breach in advance. Other wireless security features include WPA/WPA2 Enterprise, 802.11i, Captive Portal and MAC Authentication. On the wired side, the DWS-4026 utilizes Dynamic ARP Inspection (DAI) and DHCP Snooping to ensure maximum security. Together, DAI and DHCP Snooping will prevent even the most sophisticated attacks such as man-in-the-middle and ARP poisoning. Along with other advanced security features such as 802.1X Access Control, Denial-of-Service Protection, Broadcast Storm Control and
Seamless Mobility
Wireless clients can enjoy seamless and uninterrupted roaming from AP to AP managed by a DWS-4026 even if they are not in the same subnet. Because the DWS-4026 employs various mechanisms such as pre-authentication and key-caching, wireless users can freely “roam” the entire network without needing to re-authenticate. The additional Fast Roaming feature results in disruption-free, reliable wireless connectivity crucial for mobile applications such as Wi-Fi IP Phones and wireless PDAs. Furthermore, the DWS-4026 supports advanced “AP-AP Tunneling,” which is used to support L3 roaming for wireless clients without forwarding any data traffic to the Unified Switch. This can help to significantly reduce network traffic and save bandwidth.
Voice-Optimized Quality of Service (QoS)
The DWS-4026 is specifically designed and optimized for Voice over Wireless traffic with features such as Auto-VoIP and Voice VLAN. The Auto-VoIP feature explicitly matches VoIP streams and provides them with a better class-of-service than ordinary traffic. These VoIP streams include the popular call-control protocols such as SIP, H.323 and SCCP. Voice VLAN enables the switch ports to carry voice traffic with defined priority, ensuring that the sound quality of an IP phone will be safeguarded from deteriorating when data traffic on the port is high. The DWS-4026’s Voice QoS capability enables administrators to maintain the integrity and priority of the most time-sensitive traffic.
In addition, the DWS-4026 supports traffic shaping, which helps to smooth out temporary traffic bursts over time so that the transmitted traffic rate is bounded. Other advanced QoS features include per-flow bandwidth control, minimum bandwidth guarantee and 802.1p CoS all help to keep the network traffic in a predictable manner.
Network Resiliency
The DWS-4026 offers a “self-healing” network capability to increase the resiliency of the entire wireless network. To make up for a sudden RF signal vacuum created by any “dead” AP (AP with DC power failure, for example), the DWS-4026 automatically increases the transmit output power of the neighboring APs to expand the RF coverage, thereby “healing” the network. Also, to ensure continuous connection for current clients, the DWS-4026 performs load balancing across access points when network traffic reaches a certain threshold by forcing additional clients to associate with other access points. Through self-healing network and AP load lancing, the DWS-4026 can effectively manage the wireless bandwidth, optimize WLAN traffic and ensure maximum RF coverage.
Maximized Flexibility
In addition to all its wireless capabilities, the DWS-4026 also excels as an advanced L2+ PoE Switch. Complete with dynamic routing using RIPv1/v2, ACL security, multi-layer QoS, comprehensive VLAN support, IGMP/MLD Snooping as well as dual 10-Gigabit uplink support, the DWS-4026 truly enables network administrators to integrate their enterpriseclass wireless network with their wired infrastructure. Businesses contemplating upgrading their current wired or wireless network can deploy the DWS-4026 to take advantage of its dual-role flexibility.
Simplified Management
Multiple DWS-4026s can form a Switch Cluster, which enables network administrator to manage and configure all switches from one single “Cluster Master.” In addition, the Switch Cluster also manages information of all the Access Points as well as their associated clients. This helps to significantly simplify management and reduce maintenance efforts as the network scales up.
Põhiomadused
WLAN juhtimise funktsioonid
+ Kuni 64 pääsupunkti, ühendatud kommutaatoriga
+ Kuni 256 pääsupunkti klastris
+ Kuni 2048 juhtmevaba klienti (1024 kasutajat tunnelingi kasutamisel, 2048 kasutajat, kui tunnelingi ei kasutata)
Roaming
+ Kiire rouming
+ Ühe kommutaatoriga ühendatud kommutaatorite ja pääsupunktide vaheline rouming
+ Võrgusisene ja võrkudevaheline rouming
+ Pääsupunktide vaheline rouming
Ligipääsuriba juhtimine
+ Kuni 32 SSID pääsupunkti kohta (16 SSID ühe sageduse kohta)
+ Pääsupunktide koormuse tasakaalustamine vastavalt kasutajate arvutle
Hallatav pääsupunkt
DWL-8600AP
Pääsupunktide juhtimine
+ Pääsupunktide automaatne tuvastamine
+ Pääsupunktide kaug taaskäivitamine
+ Pääsupunktide monitooring: hallatavad pääsupunktid, rouge pääsupunktid ja autoriseerimata pääsupunktid
+ Klientide monitooring: klientide nimekiri vastavalt pääsupunktile
+ Ad-hoc klientide monitooring
+ Pääsupunktide autentimine lokaalse andmebaasi abil või välise RADIUS serveri kaudu
+ Kanalite/reeglite turvalisuse keskhaldus
+ Visuaalne pääsupunktide juhtimine (Kuni 16 jpg-failide toetus)
WLAN turvalisuse funktsioonid
+ Wireless Intrusion Detection & Prevention System (WIDS)
+ Võõraste pääsupunktide minimiseerimine
+ Võõraste ja lubatud pääsupunktide klassifitseerimine MAC-aadressite järgi
+ WPA Personal/Enterprise
+ WPA2 Personal/Enterprise
+ 64/128/152-bitine WEP-andmekrüpteerimine
+ Juhtmavaba jaamade ja pääsupunktide klassifitseerimine kanali, MAC-aadressi, SSID, aja baasil
+ Andmekrüpteerimine: WEP, WPA, Dynamic WEP, TKIP, AES-CCMP, EAP-FAST, EAP-TLS, EAP-TTLS, EAP- MD5, PEAP-GTC, PEAP-MS-CHAPv2, PEAP-TLS
+ Autentimine МАС-aadressite baasil
+ Jaama isoleerimine
2.kihi funktsioonid
+ MAC-aadressite tabeli suurus: 8 K kirjet
+ IGMP Snooping: 1 K multicast gruppi
+ MLD Snooping
+ 8021.D Spanning Tree
+ 802.1w Rapid Spanning Tree
+ 802.1s Multiple Spanning Tree
+ Link Aggregation 802.3ad: kuni 32 gruppi, kuni 8 porti gruppis
+ 802.1ab LLDP
+ LLDP-MED
+ One-to-One Port Mirroring
+ Many-to-One Port Mirroring
+ Jumbo-freimide suurus: kuni 9 Kb
VLAN
+ 802.1Q VLAN Tagging
+ 802.1V
+ VLAN grupid: kuni 3965 kirjet
+ VLAN alamvõrkude jaoks
+ VLAN MAC-aadressite baasil
+ GVRP
+ Double VLAN
+ Voice VLAN
3.kihi funktsioonid
+ Staatiline marsruutimine IPv4
+ Marsruutimise tabeli suurus: kuni 128 staatilist marsruuti
+ VRRP
+ Proxy ARP
+ RIPv1/v2
Quality of Service (Teenusekvaliteet)
+ Prioriteetsuse järjekorrad 802.1p (kuni 8 järjekorda pordi kohta)
+ CoS: pordipõhine, VLAN, DSCP, TCP/UDP pordipõhine, TOS, allika MAC-aadressi põhine, allika IP-aadressi põhine
+ Auto-VoIP
+ Liikluse formeerimine pordile
+ Läbilaskeriba juhtimine voo baasil
ACL (Pääsuloend)
ACL põhineb: kommutaatori port, MAC-aadress, prioriteetsuse järjekorrad 802.1p, VLAN, Ethertype, DSCP, IP-aadress, protokolli tüüp, TCP/UDP pordi number
+ RADIUS autentimine
+ TACACS+ autentimine
+ SSH v1, v2
+ SSL v3 , TLS v1
+ Port Security funktsioon: 20 MAC-aadressi pordi kohta, teatamine funktsiooni aktiveerimisel
+ MAC-aadressite filtreerimine
+ Ligipääsujuhtimine 802.1x portide baasil ja Guest VLAN
+ DoS rünnakutest kaitsmine
+ Dynamic ARP Inspection (DAI)
+ DHCP Snooping
+ Broadcast tormi juhtimine: samm 1 % kanali kiirusest
+ Kaitstud port
+ DHCP-filtreerimine
Juhtimine
+ Web-liides
+ Kommutaatorite klastrid
+ RADIUS kasutajatunnus
+ CLI
+ Telnet server: kuni 5 sessiooni
+ Telnet klient
+ TFTP klient
+ SNMP v1, v2c, v3
+ sFlow
+ Mitu konfigureerimisfaili
+ Dual Images
+ RMON v1: 4 gruppi (Statistics, History, Alarms, Events)
+ BOOTP/DHCP klient
+ DHCP server
+ DHCP Relay
+ SYSLOG
+ Portide kirjeldus
Seadme liidesed
+ 24 x 10/100/1000BASE-T PoE 802.3af toetusega
+ 4 kombo porti SFP
+ Konsoolport RS-232
+ 2 laienduspesa 10 Gigabit moodulite paigaldamiseks
Varutoiteallikas
DPS-600 toiteallika pesa
Power over Ethernet
+ Standard: 802.3af
+ Väljundvõimsus pordil: 15,4 W
+ Väljundvõimsus: 370 W
+ Pordi automaatne väljalülitamine, kui vool on kõrgem kui 350 mА
Tootlikkus
+ Sisene lülituskiirus: 88 Gbit/s
+ Paketide maksimaalne edastuskiirus: 65,47 Mpps
+ Kommutatsiooni meetod: Store and Forward
+ Paketi bufferi suurus: 750 KB
Voojuhtimine
+ Voojuhtimine 802.3x täisdupleksrežiimis
+ HOL blokeerimise ennetamine
Lisa uplink-moodulid 10GE portidega
+ DEM-410X 1 10GE XFP pordiga moodul (Optilise magistraalvõrguga ühendamiseks)
+ DEM-410CX 1 10GE CX4 pordiga moodul (Kommutaatorite liitmiseks)
Lisa XFP 10GE transiiverid
+ DEM-421XT XFP 10GBASE-SR transiiver, MMF, maksimaalne vahekaugus kuni 300 m, 3,3/5 V
+ DEM-422XT XFP 10GBASE-LR transiiver, SMF, maksimaalne vahekaugus kuni 10 km, 3,3/5 V
+ DEM-423XT XFP 10GBASE-ER transiiver, SMF, maksimaalne vahekaugus kuni 40 km, 3,3/5 V
Indikaatorid
+ Seade: Power, Console, RPS
+ 10/100/1000BASE-T pordid: Link/Activity/Speed, PoE
+ SFP pesa: Link/Activity
+ 10 Gigabit pesa: Link/Activity
Sertifikaadid
Sidustooted
DWS-4026 Juhtmevaba 2+ kihi kommutaator, 24 x 10/100/1000Base-T (PoE) porti + 4 kombo porti Mini GBIC (SFP) /1000Base-T (PoE) + 2 laienduspesa, toetab kuni 64 pääsupunkti
