![](/up/prod/600/DPN-144DG_A1.jpg)
DPN-144DGProje
Dual-band wireless voice gateway subscriber GPON ONT with 1 GPON port 4 10/100/1000Base-T, 2 FXS ports, 1 USB port and support AC1200
Tanımlama
The use of GPON technology
DPN-144DG provides a connection for the optical channel with the device class GPON OLT. The main advantage of GPON technology is the optimal bandwidth usage. This technology is the next step in providing high-speed access to Internet services for home and office. DPN-144DG allows you to organize reliable connection with high bandwidth over long distances for users living or working in remote apartment buildings and business centers.
Tripleplay Services
High-speed broadband with speeds up to 2.4 GB/s can simultaneously provide customers with all necessary services: IPTV, high quality IP-telephony services and access to the Internet.
Voice
The device is equipped with a FSX port which allows you to connect an analogue phone to use VoIP service provider.
Wireless interface
Using the wireless gateway DPN-144DG, You can quickly arrange high-speed wireless network in the home or office, providing access to the Internet, computers and mobile devices almost anywhere (within range of a wireless network). Simultaneous operation in the 2.4 GHz and 5 GHz allows you to use a wireless network to a wide range of tasks. The device can operate as a base station for connecting wireless devices of the standards 802.11 a, 802.11 b, 802.11 g, 802.11 n and 802.11 ac (with wifi speeds up to 1167 Mbit/s)1.
A secure, wireless connection
In DPN-144DG supports multiple functions for the wireless interface. The device supports several security standards (WEP, WPA/WPA2), filtering devices by MAC address, and allows you to use WPS and WMM.
In addition, the device is equipped with a button to disable/enable the Wi-Fi network. If necessary, for example, leaving the house, You can turn off the wireless network DPN-144DG one button, while the devices connected to the LAN ports, will remain in the network.
Advanced wireless network
The ability to customize guest Wi-Fi network will allow You to create a separate wireless network, network security and maximum speed limit. Devices guest network will be able to connect to the Internet, but be isolated from the devices and resources the local network the wireless gateway.
USB port
DPN-144DG is equipped with a USB port for connecting a USB-modem with which You will be able to connect to the Internet. In addition, You can connect to a USB port on the device USB drive that will be used as a network drive, or a printer.
Security
Voice gateway DPN-144DG equipped with a built-in firewall. The advanced security functions minimize threats of hackers and prevent intrusions to the local network and access to unwanted websites for users.
Easy setup and update
To configure the device via the userfriendly web-interface (available in Russian and English).
DPN-144DG checks the update server D-Link. If you have a new checked ON the web interface of the device notifies it is ready to install.
Built-in client TR-069 enables you to configure and diagnose devices remotely, without the participation of the subscriber.
1 to 300 Mbps in the 2.4 GHz band and up to 867 Mbps in the 5 GHz band.
