DIR-857EOL EOS
Wireless 802.11n Dual-Band HD media router with built-in 4-port switch, 1-port USB 3.0, up to 450 Mbit / s
Nereden Alınır
Tanımlama
Router Functions
Wireless HD Media Router 3000 supports data rates from 450 to 450 Mbit / s with simultaneous use of two frequency ranges, which provides a continuous broadcast of HD video streaming and faster data transfer. Built-in Quality of Service (QoS) to optimize network performance and provide playback of multimedia and online games without delay.
Sharing files through SharePort technology
SharePort technology enables shared access to photos, music and video, thanks to this technology, you can connect high-speed USB 3.0 storage device to USB-port router and arrange instant file sharing on the network 1 . You can also connect a multifunction USB-printer and Share the functions of printing, scanning and fax numbers, allowing you to use only one printer for the home and office.
1 SD-card is not included
Genel Özellikler
Fiziksel Özellikler
Standards
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.11b
• IEEE 802.11a
• IEEE 802.3
• IEEE 802.3u
• IEEE 802.3ab
• USB 3.0
WAN connection types
• Dynamic IP
• Static IP
• PPPoE
• PPTP
• L2TP
Device Interfaces
• 802.11n/g/b/a wireless LAN
• 4-port 10/100/1000 BASE-T Gigabit LAN
• 1 USB 3.0 port
• Slot for SD-cards
Wireless speed
Wireless connection to a speed of 450 + 450 Mbit / s using two bands 2
Safety
• WPA and WPA2 (Wi-Fi Protected Access)
• 64/128-bit WEP-encryption
• WPS-connection
QoS
• QoS engine to prioritize traffic
• WMM for WLAN traffic
Technology Shareport 3
• Shared access to an external USB hard drive or fash-drive through a file share, SAMBA
• Simultaneous access by multiple users to a drive
• Shared access to the multifunction USB-printer
Indicators
• Power / Status
• Internet
Device control
• Supports UPnP
• Support DDNS
• Wireless Security Wizard and Wireless Protected Setup (WPS)
• Windows Connect Now (WCN)
• Web-based management interface based on Internet Explorer 6 or later or other Java-enabled browser
• Check the software update online
• Notification by email of freelance events
• UPnP TM -server for streaming media content to compatible media players 4
• Support for multiple languages
Wireless speed
• IEEE 802.11a: 54, 48, 36, 24, 18, 12, 9 and 6 Mbit / s
• IEEE 802.11b: 11, 5.5, 2 and 1 Mbit / s
• IEEE 802.11g: 54, 48, 36, 24, 18, 12, 9 and 6 Mbit / s
• IEEE 802.11n (2.4 / 5 GHz): 6.5 ~ 450 Mb / s
The output power of the transmitter
• IEEE 802.11a
  +16 DBm at 6-18 Mbit / s
  +14 DBm at 24-36 Mbit / s
  +11 DBm at 48-54 Mbit / s
• IEEE 802.11b
  +17 DBm at 11, 5.5, 2 and 1 Mbit / s
• IEEE 802.11g
  +16 DBm at 6-36 Mbit / s
  +13 DBm at 48-54 Mbit / s
• IEEE 802.11n (2.4 GHz)
  +16 DBm at MCS0-MCS2, MCS8-MCS10, MCS16-18
  +15 DBm at MCS3-MCS4, MCS11-MCS12, MCS19-20
  +15 DBm at MCS5-MCS7, MCS13-MCS15, MCS21-23
• IEEE 802.11n (5 GHz)
  +14 DBm at MCS0-MCS4, MCS8-MCS12, MCS16-20
  +11 DBm at MCS5-MCS7, MCS13-MCS15, MCS21-23
Scope of delivery
• Router DIR-857 HD Media Router 3000
• Installation CD-ROM with User Manual
• The power adapter 12 V DC / 2 A
• Ethernet-cable - CAT 5
System Requirements
• Cable or DSL-modem with Ethernet-port
• The AC adapter
• CD-ROM
• Windows 7/Vista/XP SP3 or above 5
• Internet Explorer 6 or higher, Firefox 1.5 or higher
Additional Options
For maximum performance router HD Media Router 3000, use it in conjunction with the following devices D-Link:
• DSM-380: Boxee Box D-Link
  Browsing the Internet via a HD TV
• DWA-160 Wireless USB-adapter
  Connecting a computer to a wireless network using a USB-AC adapter
• DNS-325: network drive
  Connect the drive to your network and keeping it to back up
Fiziksel Özellikler
Operating temperature
From 0 ° to 40 ° C.
Storage temperature
From -20 ° to 65 ° C.
Operating Humidity
From 10% to 95% (non-condensing)
Weight
341.5 g
Measurements
212 x 160 x 34.4 mm
Humidity
5 to 95% (non-condensing)
Certifications
• FCC Class B
• CE
• IC
• C-Tick
• IPv6 Ready
• Wi-Fi
• WMM
• Supports Windows 7
2 Maximum wireless signal rate derived from the standard specifications of IEEE 802.11. Actual data throughput will vary. The conditions under which the network operates, as well as environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual throughput. Wireless signal range can be affected by environmental factors.The maximum capacity is provided using standard 802.11n.
3 The software included with this product is not compatible with Mac.
4 Company D-Link does not guarantee full compatibility or proper playback with all codecs. Playback capability depends on the codec media player supported UPnP AV.
5 computer meets the system requirements recommended by Microsoft.
Çözümler
Sipariş Bilgisi
Görseller
DIR-857A1
Front view
Back view
Front view
İndir
Destek Merkezi
