SP-320-48SMProje
External power supply for DAS-4192, 321.6 W
Nereden Alınır
Tanımlama
External Power Supply SP-320-48SM is ideal for use with the IP DSLAM DAS-4192 D-Link, providing the necessary parameters for operation of the DAS-4192.
SP-320-48SM supports the following nominal values ​​of characteristics: output power of 321.6 W, 6.7 A output current and output voltage of 48 V. In addition, the device has a built-in protection mechanisms against overload, over the output voltage, short circuit and high temperatures.
Genel Özellikler
Fiziksel Özellikler
Built-in protective mechanisms
• Overload protection is triggered when the value exceeds the nominal output power of 5% -35%
• Protection against exceeding the value of the output voltage and short-circuit is activated when the output voltage of 57.6 V to 67.2 in
• Protection against high temperatures
Ventilation
• Built-in DC fan
• Control of fan speed
The physical parameters
The input voltage range
• From 88 to 264 VAC
• From 124 to 370 VDC
The range of the input line voltage AC
47 Hz to 63 Hz
Leakage
<1.0 mA at 240 V AC
Output voltage
48
Nominal output current
6.7 A
The range of output currents
From 0 to 6.7 A
Rated power output
321.6 W
Size
215 x 115 x 50 mm
Temperature
• Operating: -20 to 65 C
• Storage: -40 to 85 C
Humidity
• Operating: 20% to 90% non-condensing
• Storage: 10% to 95% non-condensing
MTBF
207,000 hours at rated voltage lines, maximum load, ambient temperature of 25 C
Safety
• UL
• TUV
Çözümler
Sipariş Bilgisi
Görseller
SP-320-48SM SP-320-48SM
Front view
İndir
Destek Merkezi
