![](/up/prod/600/DSA-3110_A1.jpg)
DSA-3110 hotspot editionProje
Tanımlama
Quick organization public access to Internet (Hotspot)
The hotspot service gateway provides comfortable and secure way to provide access to Internet for your clients or/and employees. The system guarantees that only registered users are able to use network resources. Used HTTPS (secure http) connection technologies provide a security way of user’s authorization.
AAA Function Execution
The DSA-3110 performs for you authentication, authorization and accounting (AAA), three basic issues that are encountered frequently in many network services. Examples of these services are dial in access to Internet, electronic commerce, Internet printing, and Mobile IP. Authentication acts to verify an identity so authorization can be granted to access a resource. Accounting collects resource consumption data for the purposes of trend analysis, and capacity planning, billing, auditing, and cost allocation.
Can Be Used on Commercial Hotspot
The DSA-3110 Hotspot Edition can also be installed in a commercial network providing access to Internet. Supporting time-based and traffic-based tariffs allow give flexible services for your clients.Using DSA-3110 Hotspot Edition with printer DSA-3100P allow you reduce total cost of ownership (TSO) and organize servicing commercial hotspot using low qualification employees.
Can Be Used on SOHO and SMB Business
The DSA-3110 Hotspot Edition can also be installed in a business network for traffic controlling. Supporting quotas allow set quota (maximum size of Internet traffic) each of your users (employees).
Genel Özellikler
Fonksiyonları
•Dahili bir veritabanı üzerindeki 250 kullanıcı hesaplarının yerleştirme
•ye kadar 50 veya 80 (denetim DSA-3110/E/B hotspot baskı için) eş zamanlı online kullanıcılar için Destek
• Erişim Protokolü: http
•Şifreli https bağlantısı desteği
• ID / Parola dayalı kimlik doğrulama ve yetkilendirme
•iç kimlik doğrulama mekanizması desteği
• Destek editör kontrolleri (kontrol DSA-3100P bir termal yazıcı ile birlikte kullanıldığında, UNS veya Vatandaş MBP-910II-40RF230-A SP1)
•WEB arayüzü yönetimi Erişim
•SSH için komut satırı arayüzü Uzaktan erişim
• DMZ NAT, Port Forwarding, destekler (CLI)
• Statik IP, DHCP istemci arabirimleri
Donanım Platformu
Işlemci
Intel IHP-425 veya 266 MHz Intel IXP-425 533 MHz (denetim DSA-3110/E/B hotspot baskı için)
Hafıza
64 MB SDRAM
Cihazın Portları
• 7 10/100Mbps Fast Ethernet
• 4 bağımsız olarak yapılandırılabilir arayüzler (LAN, WAN portu veren istatistik olarak kullanılabilir)
Göstergeler
• Güç (Power)
• Durum (Status)
• 7 göstergeleri Fast Ethernet portu
