DAP-E9560Yeni
Wi-Fi 7 BE9500 Tri-Band PoE Access Point
Tanımlama
The DAP-E9560 Wi-Fi 7 BE9500 Tri-Band PoE Access Point is designed for small to medium businesses or enterprises, providing unparalleled bandwidth and flexibility for administrators looking to deploy a medium to large scale Wi-Fi network. This AP has manageable trial-band wireless LAN options and utilizes the cutting-edge speed of Wireless AX and not only can the AP operate in standalone mode, it can also be centrally managed by D-Link Nuclias Connect. The Nuclias Connect solution provides for easier administration of wireless networks, including continuous monitoring of network activities, equipment configuration automation, performance parameters and network security control etc.
Wi-Fi 7 (802.11be)
The DAP-E9560 leverages cutting-edge technologies such as Multi-Link Operation (MLO), 320 MHz channel bandwidth, and 4K QAM modulation to enable data transmission across multiple frequency bands simultaneously. Whether supporting bandwidth-intensive applications like cloud gaming, real-time collaboration, or AR/VR experiences, Wi-Fi 7 provides the speed, efficiency, and reliability required in today’s high-density, devicerich environments. The DAP-E9560 delivers reliable, high-speed wireless performance with maximum wireless signal rates of up to 574 Mbps over the 2.4 GHz band, up to 2880 Mbps over the 5 GHz band and up to 5760 Mbps 6 GHz band1. This, coupled with support for the Wi-Fi Multimedia™ (WMM) Quality of Service (QoS) feature, makes it an ideal access point for audio, video, and voice applications. When enabled, QoS allows the DAP-E9560 to automatically prioritize network traffic according to the level of interactive streaming, such as HD movies or VoIP. The QoS feature can be adjusted through the DAP-E9560’s web GUI using a drop-down menu option to select customized priority rules.
10-Gigabit Ethernet Port
The DAP-E9560 also deliver ultra-fast wired connectivity, significantly reducing network latency and ensuring high throughput for bandwidth-intensive applications. With support for 10 GbE speeds, the network infrastructure is future-ready, providing the scalability and performance needed to meet growing demands and support upcoming upgrades without bottlenecks.
Versatile Access Point Functionality
The DAP-E9560 allows network administrators to deploy a highly manageable and extremely robust simultaneous trial-band wireless network. The DAP-E9560 can be ceiling mounted or wall mounted to meet any wireless demands. For advanced installations, the DAP-E9560 has integrated 802.3at/802.3bt Power over Ethernet (PoE)3 support, allowing the device to be installed in areas where power outlets are not readily available
Security
To help maintain a secure wireless network, the DAP-E9560 supports both Personal and Enterprise versions of WPA, WPA2 (802.11i) and WPA3, with support for RADIUS server backend and a built-in internal RADIUS server allowing users to create their accounts within the device itself. This access point also includes MAC address filtering, wireless LAN segmentation, SSID broadcast disable, rogue AP detection, and wireless broadcast scheduling for further protection of your wireless network. Additionally, the DAP-E9560 supports Network Access Protection (NAP), allowing network administrators to define multiple levels of network access based on individual client's needs.
Multiple Operation Modes
The DAP-E9560 supports several operating modes: Access Point, Wireless Distribution System (WDS), WDS with AP, Wireless Client. As a standard wireless access point (AP) the DAP-E9560 can connect to a wide range of devices that are 802.11a/b/g/n/ac/ax/be compliant. In wireless distribution system (WDS) mode it can expand current wireless coverage without the need for a wired backbone link. As a wireless client it can connect to an existing AP and provide access to the network for devices connected using an Ethernet cable.
Network Management
Network administrators have multiple options for managing the DAP-E9560, including web (HTTP/HTTPS), Secure Shell (SSH, which provides for a secure channel between local and remote computers) and Telnet.
The DAP-E9560 also can be configured and managed by D-Link Nuclias Connect. In addition, the DAP-E9560 has a wireless scheduler feature, which turns off wireless functionality when it isn’t needed, saving power. With simultaneous trial-band functionality, PoE support, extensive manageability, versatile operation modes, and solid security enhancements, the DAP-E9560 provides small to medium business and enterprise environments with a business-class solution for deploying a wireless network.
Genel Özellikler
Hardware
Interfaces
• 802.11b/g/n/ax (2.4 GHz)
• 802.11a/n/ac/ax (5 GHz)
• 802.11ax/be (6 GHz)
• 1x10/100/1000/2.5G/5G/10GBase-T LAN 802.3at/802.3bt PoE port3
• 1x10/100/1000/2.5GBase-T LAN port
• 1xRJ45 Concole port
LEDs
• Power/Status
- Solid green - Device operational
- Flashind red - Device booting up/Device malfunctioned
- Solid red - Device boot up has failed
Buttons
• Factory reset button
Antennas
• 2 internal antennas with 3.3 dBi for 2.4 GHz
• 2 internal antennas with 4.8 dBi for 5 GHz
• 2 internal antennas with 4.6 dBi for 6 GHz
MIMO
• 2x2, MU-MIMO
Power connector
• Power input connector USB Type-C (DC)
Mounting
• Wall
• Ceiling
Wireless Module Parameters
Standards
• IEEE 802.11a/b/g/n/ac/ax/be
Wireless Frequency Range*
*The available operating frequency ranges vary depending on the regulations of individual countries and jurisdictions. Some frequency ranges may be unavailable in certain regions.
• 2.4 GHz: 2.4 GHz to 2.4835 GHz
• 5 GHz: 5.15 GHz to 5.35 GHz, 5.47 GHz to 5.85 GHz
• 6 GHz: 5.92 GHz to 6.42 GHz
Wireless Security
• WPA-Personal/Enterprise
• WPA2-Personal/Enterprise
• WPA3-Personal/Enterprise
• 64/128-bit WEP encryption
• AES and TKIP
• SSID broadcast disable
• MAC address access control
• Network Access Protection (NAP)
• Internal RADIUS server
• Captive Portal Authentication
Wireless speed
• 802.11a: 6, 9, 12, 18, 24, 36, 48 and 54 Mbit/s
• 802.11b: 1, 2, 5.5 and 11 Mbit/s
• 802.11g: 6, 9, 12, 18, 24, 36, 48 and 54 Mbit/s
• 802.11n: 6.5 ~ 300 Mbit/s
• 802.11ac: 6.5~866 Mbit/s
• 802.11ax: 6.5~2402 Mbit/s
• 802.11be: 6.5~5765 Mbit/s
Transmitter Output Power*
The maximum value of the transmitter output power depends upon the radio frequency regulations applied in your country.
• IEEE 802.11a:
20 dBm at 6, 9, 12, 18,24,36,48,54 Mbit/s
• IEEE 802.11b:
20 dBm at 1, 2, 5.5, 11 Mbit/s
• IEEE 802.11g:
20 dBm at 6,9 Mbit/s
19 dBm at 12,18 Mbit/s
18 dBm at 24,36 Mbit/s
17 dBm at 48, 54 Mbit/s
• IEEE 802.11n:
• IEEE 802.11ac:
• IEEE 802.11ax:
• IEEE 802.11be:
Receiver Sensitivity
• IEEE 802.11a:
-95 dBm at 6 Mbit/s
-93 dBm at 9 Mbit/s
-92 dBm at 12 Mbit/s
-90 dBm at 18 Mbit/s
-86 dBm at 24 Mbit/s
-83 dBm at 36 Mbit/s
-79 dBm at 48 Mbit/s
-77 dBm at 54 Mbit/s
• IEEE 802.11b:
-94 dBm at 2 Mbit/s
-89 dBm at 11 Mbit/s
• IEEE 802.11g:
-94 dBm at 6 Mbit/s
-91 dBm at 9 Mbit/s
-91 dBm at 12 Mbit/s
-89 dBm at 18 Mbit/s
-84 dBm at 24 Mbit/s
-81 dBm at 36 Mbit/s
-77 dBm at 48 Mbit/s
-75 dBm at 54 Mbit/s
• IEEE 802.11n:
• IEEE 802.11ac:
• IEEE 802.11ax:
• IEEE 802.11be:
| Functionality | |||||||||||||||||||||||||||||
Network Management
• Web-based User Interface (HTTP/HTTPS)
• Telnet
• Secure Telnet (SSH)
• Traffic control
• Nuclias Connect
• Command Line Interface (CLI)
• SNMP
Operating Modes
• Access Point
• WDS
• WDS with AP
• Wireless Client
Supported Features
• Quality of Service (QoS)
• Multi-SSID
• VLAN
• Wireless intrusion
• Band Steering
• Airtime Fairness
• Fast Roaming (only when using Nuclias Connect controller)
• 802.11k/r Wi-Fi Roaming Protocols2
• ARP Spoofing Prevention
• Bandwidth Optimization
• DHCP Server
• Wireless Multimedia (WMM)
Standards
• IEEE 802.3u
• IEEE 802.3ab
• IEEE 802.3at/802.3bt Power over Ethernet3
Physical Parameters
Weight
• 1.152 kg
Dimensions (L x W x H)
• 223.04 x 223.04 x 47.7 mm
Operation Conditions
Power Supply
• External Power Adapter (not included): 20V DC 2.25A
• IEEE 802.3at/802.3bt PoE3
Max Power Consumption
• 27.756 W
Temperature
• Operating: 0 to 40 °C
• Storage: -20 to 65 °C
Humidity
• Operating: 10% to 90% (Non-condensing)
• Storage: 5% to 95% (Non-condensing)
Package Contents
• DAP-E9560 Access Point
• Mounting Plate and Hardware
• Quick Start Guide
Other
Certifications
• FCC
• IC
• CE
• RCM
• LVD
1The available operating frequency ranges vary depending on the regulations of individual countries and jurisdictions. Some frequency ranges may be unavailable in certain regions.
2Available when managed by the Nuclias controller.
3Supports 802.3at power input. In this mode, the DAP-E9560 will disable the 2.5G Ethernet port and limit the 10G Ethernet port speed to 2.5G. However, it does not accept 802.3af power input mode.
Çözümler
Sipariş Bilgisi
DAP-E9560/A1A
