![](/up/prod/600/DAP-2680_A1.jpg)
DAP-X2810Yeni
Tanımlama
The DAP-X2810 Wireless AX1800 Wave 2 Dual-Band PoE Access Point is designed to support small to medium business or enterprise environments by providing network administrators with secure and manageable dual-band wireless LAN options, and utilizing the cutting-edge speed of Wireless AC.
Blazing Wireless Wave 2 AX Performance
TheDAP-X2810 delivers reliable, high-speed wireless performance using the latest 802.11ac Wave 2 standard with maximum wireless signal rates of up to 450 Mbps over the 2.4 GHz band, and 1300 Mbps over the 5 GHz band*. This, coupled with support for the Wi-Fi MultimediaTM (WMM) Quality of Service (QoS) feature, makes it an ideal access point for audio, video, and voice applications. When enabled, QoS allows the DAP-X2810 to automatically prioritize network traffic according to the level of interactive streaming, such as HD movies or VoIP. The QoS feature can be adjusted through the DAP-X2810 web GUI using a drop-down menu to select customized priority rules. Additionally, the DAP-X2810 supports load balancing to ensure maximum performance by limiting the maximum number of users per access point.
Versatile Access Point Functionality
TheDAP-X2810 allows network administrators to deploy a highly manageable and extremely robust simultaneous dual-band wireless network. TheDAP-X2810 can provide optimal wireless coverage over either the 2.4 GHz (802.11b, 802.11g, and 802.11n) or the 5 GHz (802.11a, 802.11n, and 802.11ax) bands. The DAP-X2810 can be ceiling mounted, wall mounted, or placed on a desktop to meet any wireless demands. For advanced installations, the DAP-X2810 has integrated 802.3at Power over Ethernet (PoE) support, allowing the device to be installed in areas where power outlets are not readily available.
Security
To help maintain a secure wireless network, theDAP-X2810 supports both Personal and Enterprise versions of WPA and WPA2 (802.11i), with support for RADIUS server backend and a built-in internal RADIUS server allowing users to create their accounts within the device itself. This access point also includes MAC address filtering, wireless LAN segmentation, SSID broadcast disable, rogue AP detection, and wireless broadcast scheduling for further protection of your wireless network. The DAP-X2810 includes support for up to eight VLANs per band, allowing multiple SSIDs to be implemented and further segment users on the network. It also includes a wireless client isolation mechanism, which limits direct client-to-client communication. Additionally, the DAP-X2810 supports Network Access Protection (NAP), a feature of Windows Server® 2008, allowing network administrators to define multiple levels of network access based on individual client’s needs.
Multiple Operation Modes
To maximize total return on investment, the DAP-X2810 can be configured to optimize network performance based on any one of its multiple operation modes: Access Point, Wireless Distribution System (WDS), a WDS with Access Point, and Wireless Client. With WDS support, network administrators can set up multiple DAP-X2810s throughout a facility and configure them to bridge with one another, while also providing network access to individual clients. TheDAP-X2810 also features advanced features such as load balancing and redundancy, for fail-safe wireless connectivity.
Network Management
Network administrators have multiple options for managing the DAP-X2810, including Web (HTTP), Secure Socket Layer (SSL), Secure Shell (SSH), and Telnet. For advanced network management, administrators can use the D-Link Central Wi-Fi Manager to configure and manage multiple access points from a single location. In addition, the D-Link Central Wi-Fi Manager provides network administrators with the means of conducting regular maintenance checks remotely, eliminating the need for sending out personnel to physically verify proper operation. The DAP-X2810 also has a wireless scheduling feature, turning off wireless functionality when it is not needed to save power. With simultaneous dual-band functionality, PoE support, extensive manageability, versatile operation modes, and solid security enhancements, the DAP-X2810 provides small to medium business and enterprise environments with a business-class solution for deploying a wireless network.
Genel Özellikler
Device Interfaces
- IEEE 802.11a/b/g/n/ac/ax Wave 2 Wi-Fi 6 wireless interface
- 1 x Gigabit PoE-capable LAN port
- 1 x Console port
- 1 x reset button
Standards
- IEEE 802.3i/u/ab
- IEEE 802.3az Energy-Efficient Ethernet (EEE)
- IEEE 802.3af/at Power over Ethernet
- AP Mode, WDS Mode, WDS with AP, Client mode
- Airtime Fairness/ Fast Roaming/ Band Steering
- Multi SSID
- Dual image
Antennas
- 2 x 2 internal dual-band antennas
- 3.2 dBi at 2.4 GHz
- 4.3 dBi at 5 GHz
Operating Frequency**
- 2.4 GHz band: 2.4 to 2.4835 GHz
- 5 GHz band: 5.15 to 5.35 GHz, 5.47 to 5.85 GHz
Maximum Output Power
- 23 dBm for 2.4 GHz
- 26. dBm for 5 GHz
Data Signal Rate
- 2.4 GHz: Up to 450 Mbps*
- 5 GHz: Up to 1350 Mbps*
Security
- WPA-Personal
- WPA-Enterprise
- WPA2-Personal
- WPA2-Enterprise
- WPA3-Personal
- WEP 64/128-bit encryption
- 1024QAM
- SSID broadcast disable
- MAC address access control
- Network Access Protection (NAP)
- Internal RADIUS server
- Rogue AP Detection
Network Management
- Telnet
- Secure Telnet (SSH)
- Web (HTTP, HTTPS)
- Secure Socket Layer (SSL)
- Traffic control
- SNMP v1/v2c/v3
- DHCP Server
- D-Link DNA
- D-Link Nuclias Connect
- Nuclias Connect APP (IOS/Android)
- D-View 8 (Future)
QOS
- Priority Classifiers 4q
- Traffic Manager
LEDs
- Power/Device/status
Dimensions
- 170 x 170 x 28 mm
Weight
- 477 g without mounting base
- 566.5 g with mounting base
Power Supply
- External power adapter (not included into package contents): 12 V/2,5 A
- IEEE 802.3af/at PoE
Maximum Power Consumption
- 19,44 Watt
Temperature
- Operating: 0 to 40 °C
- Storage: -20 to 65 °C
Humidity
- Operating: 10% to 90% non-condensing
- Storage: 5% to 95% non-condensing
Meantime Between Failure (MTBF)
- > 30,000 hours
Certifications
- FCC
- Wi-Fi
- CE
- UL
Mount
- Mount with D-Link universal mounting kit.
Firmware Upgrade Page
- tsd.dlink.com.tw
