![](/up/prod/600/COVR-1102_B1.jpg)
COVR-1102
AC1200 Dual Band Whole Home Mesh Wi-Fi System
Tanımlama
Introducing the COVR-1102 AC1200 Dual Band Whole Home Mesh Wi-Fi System, a seamless Wi-Fi solution that’s the perfect fit for your modern home. It features two high-performance COVR Points that blanket every square inch of your home with high-speed AC1200 dual band Wi-Fi as well as two on-board Gigabit Ethernet ports (per unit) for wired connectivity. With COVR, you enjoy Wi-Fi that’s stable, consistent, and truly seamless. With the COVR-1102 D-Link has got you COVR’d.
Create or Expand your COVR Network
Gone are the days of only being able to use Wi-Fi in certain areas of your home. The COVR-1102 AC1200 Dual Band Whole Home Mesh Wi-Fi System covers up to 3500 square feet and allows you to easily expand your COVR mesh network just by adding on a COVR-1102 unit wherever you need more Wi-Fi coverage. Thanks to revolutionary Smart Roaming technology, the COVR AC1200 Dual Band Whole Home Mesh Wi-Fi System continuously scans the wireless signal strength to your devices, automatically connecting them to the strongest signal available. The COVR AC1200 Dual Band Whole Home Mesh Wi-Fi System handles the transfer seamlessly, allowing you to walk from room to room without experiencing dropped VoIP calls or frozen video streams. You enjoy seamless connectivity no matter where you are in the house.
High-Performance, Flexible Mesh Network
Wi-Fi CERTIFIED EasyMeshTM means easy to use, self-adapting Wi-Fi with greater flexibility in device choice. The COVR-1102 is equipped with industry standard Wi-Fi CERTIFIED EasyMeshTM technology. Your COVR points work together to form a self-organizing and self-optimizing network which collects information and responds to network conditions to
maximize performance. From 1-storey apartments to 4-storey houses, and from basements to back decks, COVR’s got you covered.
High-Speed Wired and Wireless Connectivity
With COVR-1102 you can bring the full potential of Wireless AC speeds of up to 1200 Mbps 1 to any area in your home, including dead spots. The COVR-1102 creates its own exclusive high-speed Wi-Fi zone for communication with your wireless devices, allowing you to fully experience demanding multimedia applications from anywhere in your home. The COVR-1102 is also equipped with optional Ethernet Backhaul connectivity so that you can optimize the connection between COVR units no matter what’s between them. In addition, the Gigabit Ethernet ports give you solid, dependable wired performance for devices such as Network Attached Storage (NAS), media centers, and gaming consoles.
MU-MIMO and Smart Steering Technology
The COVR AC1200 Dual Band Whole Home Mesh Wi-Fi System features multi-user multiple input, multiple output (MU-MIMO) Wi-Fi, which transmits multiple separate data streams to each wireless device simultaneously to ncrease speed and efficiency. Enjoy increased throughput and seamless high-definition streaming media, Internet phone calls, online gaming, and content-rich web surfing throughout your entire home or office with COVR. Additionally, the COVR-1102 is equipped with dual-band radios and intelligent Smart Steering. Don’t worry if you don’t know your 2.4 Ghz from your 5 Ghz, COVR automatically places your device on the optimal wireless band depending on network traffic conditions. With COVR, this happens seamlessly without dropouts, lag, or interruption to your wireless connection, and most importantly - without you ever lifting a finger.
Always Up-to-Date with the Latest Features
Tired of having to visit the website or manually going to the router’s UI every so often to check for the latest firmware. The COVR-1102 will automatically check daily for updates to make sure that the device always has the latest features and the most secure firmware, and will install the update silently in the background. For an extra peace of mind, in the event of failure during the firmware update, the router will store a backup system image in the memory before proceeding with the update.
Simple Setup and Configuration
The COVR AC1200 Dual Band Whole Home Mesh Wi-Fi System provides you with a home networking solution that is quick and easy to set up. The COVR-1102 works straight out of the box, so you just need to plug it in to get started. Configure your network in no time with the free D-Link Wi-Fi app on your Android or iOS compatible device, or by using the intuitive web-based interface.
Genel Özellikler
Device Interfaces (per unit)
• 1 x Gigabit WAN Port
• 1 x Gigabit LAN Port
• IEEE 802.11 a/g/n/ac Wireless WAN
LEDs
• Status LED
Antenna Type
• 2 x Internal Dual Band Antennas
• Two pack coverage up to 325 sqm. / 3500 sq. ft.1
Data Signal Rate
• 2.4 GHz
• Up to 300 Mbps1
• 5 GHz
• Up to 866 Mbps1
• Ethernet
• 10/100/1000 Mbps (auto-negotiation)
Standards
• IEEE 802.3i
• IEEE 802.3u
• IEEE 802.3ab
• Supports auto-negotiation
• Supports auto-MDI/MDIX
• IEEE 802.11ac Wave 2
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.11a
Functionality
Security
• WPA2/WPA3 wireless security
Advanced Features
• COVR Wi-Fi
• Auto-configuration
• Wireless roaming
• Wireless band steering
• Wireless Air Time Fairness (ATF)
• Ethernet Backhaul
• D-Link Wi-Fi app
• MU-MIMO (Wi-Fi)
• Multicast Support
Physical
Dimensions (L x W x H)
• 92 x 92 x 92 mm (3.6 x 3.6 x 3.6 in)
Weight (per unit)
• 197 g (0.43 lbs)
Power Input
• 100 V to 240 V/AC, 50/60 Hz
Power Consumption
• 8.55 W
Temperature
• Operating: 0 to 40 °C (32 to 104 °F)
• Storage: -20 to 70 °C (-4 to 158 °F)
Humidity
• Storage: 5% to 90% non-condensing
Certifications
• FCC
• IC
• CE
• ErP
• RoHS
• Wi-Fi CERTIFIED EasyMeshTM
1Maximum wireless signal rate derived from the IEEE 802.11ac and 802.11n standards specifications. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic, building materials and construction, and network overhead, may lower actual data throughput rate. Environmental factors will adversely affect wireless signal range.
Çözümler
Sipariş Bilgisi
