![](/up/prod/600/DSL-2640U_RB_U2A.jpg)
DSL-2640U/RB
Wireless Router ADSL2 + (Annex B) that supports Ethernet WAN
Tanımlama
ADSL-port and 4-port switch, Ethernet WAN support
The router is equipped with ADSL-port for connection to ADSL-line. Built-in 4-port switch allows you to connect computers equipped with Ethernet-adapters, game consoles and other devices to your network. In addition, any Ethernet-port devices can be used to connect to a dedicated Ethernet-line.
Wireless Interface
You can quickly create a wireless network at home or in the office, which will allow your employees or members of your family to connect to your wireless network virtually anywhere (in the range of a wireless network). A router can act as a base station to connect to a wireless network devices operating on the standards 802.11b, 802.11g and 802.11n.
The device supports several security standards (WEP, WPA / WPA2), filtering devices to be connected on the MAC-address, as well as technology allows WPS. Furthermore, the device is equipped with a button for switching off / on Wi-Fi-network. In case of need, such as leaving your home, you can turn off the router's wireless network at the touch of a button, and the devices connected to the LAN-port router will remain in the network.
Security
Wireless router DSL-2640U is equipped with a built-in firewall. Enhanced security functions minimize threats of hacker attacks, prevent unwanted intrusions into your network and access to unwanted websites for users of your LAN.
Easy setup and update
To set up a wireless router DSL-2640U uses a simple and user-friendly web-interface (available in several languages).
Now you can easily update the firmware - the router itself is validated on the server version of the software update D-Link and notifies the user ready to install it.
