DVG-N5402SP/2S1U/C1A
İki FXS-port, USB-port ve 4-port switch ile Universal Wireless VoIP-yönlendirici
Tanımlama
	SIP-telephony
	VoIP-Router is equipped with two FXS-ports that allow you to connect analog phones to make calls over the Internet.
	USB-port
	The router is equipped with USB-port for connecting a USB-modem with which you can quickly connect to the Internet. In addition, you can connect to the USB-port on the router USB-drive, which will be used as a network drive, or a printer.
	Wireless Interface
	Using Wireless Router DVG-N5402SP, you can quickly arrange high-speed wireless network at home or in the office, providing Internet access to computers and mobile devices almost anywhere (within range of a wireless network.) The Router can serve as an access point to connect to the wireless network devices of the standards 802.11b, 802.11g and 802.11n (up to 300 Mbit / s). Enable and disable the wireless network router, you can single click WLAN, located on the device.
	In the router supports multiple functions for the wireless interface. The device supports several security standards (WEP, WPA/WPA2), filtering devices to be connected to MAC-address, as well as allows you to use WPS, WMM.
	Security
	Wireless Router DVG-N5402SP provides firewall. Enhanced security functions minimize threats of hackers and prevent intrusions to your network.
	Configuration and Management
	To manage and configure the wireless router DVG-N5402SP uses a simple and user-friendly web-interface (available in several languages).
