Tanımlama
* DWA-182 hardware version A1 only supports USB 2.0
1 Maximum wireless signal rate derived from standard specifications IEEE 802.11ac (draft) and 802.11n. Company D-Link does not guarantee compatibility with any future standards or interoperability of 802.11ac (draft) devices from other manufacturers. The data rate may differ significantly from the speed of wireless connections. The conditions under which the network operates, as well as environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual throughput. On the range of a wireless network can be affected by environmental factors. Wireless transmission speeds up to 867 Mbit / s is achieved when connecting to other 802.11ac devices. Data rate may also be limited by interface devices (less than 480 Mbit / s interface USB 2.0). Your computer must meet the recommended system requirements for Microsoft.
Genel Özellikler
Fiziksel Özellikler
MCS | GI = 800ns | GI = 400ns | ||
20MHz | 40MHz | 20MHz | 40MHz | |
0 | 6.5 | 13.5 | 7.2 | 15 |
1 | 13 | 27 | 14.4 | 30 |
2 | 19.5 | 40.5 | 21.7 | 45 |
3 | 26 | 54 | 28.9 | 60 |
4 | 39 | 81 | 43.3 | 90 |
5 | 52 | 108 | 57.8 | 120 |
6 | 58.5 | 121.5 | 55.0 | 135 |
7 | 65 | 135 | 72.2 | 150 |
8 | 13 | 27 | 14,444 | 30 |
9 | 26 | 54 | 28.889 | 60 |
10 | 39 | 81 | 43.333 | 90 |
11 | 52 | 108 | 57.778 | 120 |
12 | 78 | 162 | 86.667 | 180 |
13 | 104 | 216 | 115.556 | 240 |
14 | 117 | 243 | 130,000 | 170 |
15 | 130 | 270 | 144.444 | 300 |
0 | 58.5 | 65.0 |
1 | 117.0 | 130.0 |
2 | 175.5 | 195.0 |
3 | 234.0 | 260.0 |
4 | 351.0 | 390.0 |
5 | 468.0 | 520.0 |
6 | 526.5 | 585.0 |
7 | 585.0 | 650.0 |
8 | 702.0 | 780.0 |
9 | 780.0 | 866.7 |
2.4 GGts/HT-20 :
18 dBm at MCS0
15 dBm at MCS7
2.4 GGts/HT-40:
18 dBm at MCS0
15 dBm at MCS7
5 GGts/HT-20:
18 dBm at MCS0
15 dBm at MCS7
5 GGts/HT-40:
18 dBm at MCS0
15 dBm at MCS7
2.4 GGts/HT-20
-82 DBm at MCS8
-79 DBm at MCS9
-77 DBm at MCS10
-74 DBm at MCS11
-70 DBm at MCS12
-66 DBm at MCS13
-65 DBm at MCS14
-64 DBm at MCS15
2.4 GGts/HT-40:
-79 DBm at MCS8
-76 DBm at MCS9
-74 DBm at MCS10
-74 DBm at MCS11
-67 DBm at MCS12
-63 DBm at MCS13
-62 DBm at MCS14
-61 DBm at MCS15
5 GGts/HT-20
-82 DBm at MCS8
-79 DBm at MCS9
-77 DBm at MCS10
-74 DBm at MCS11
-70 DBm at MCS12
-66 DBm at MCS13
-65 DBm at MCS14
-64 DBm at MCS15
-59 DBm at MCS8
5 GGts/HT-40
-79 DBm at MCS8
-76 DBm at MCS9
-74 DBm at MCS10
-74 DBm at MCS11
-67 DBm at MCS12
-63 DBm at MCS13
-62 DBm at MCS14
-61 DBm at MCS15
-56 DBm at MCS8
-54 DBm at MCS9
5 GGts/HT-80
-76 DBm at MCS0
-73 DBm at MCS1
-71 DBm at MCS2
-68 DBm at MCS3
-64 DBm at MCS4
-60 DBm at MCS5
-59 DBm at MCS6
-58 DBm at MCS7
-53 DBm at MCS8
-51 DBm at MCS9
5 GGts/VHT-40:
-56 DBm at MCS8
-54 DBm at MCS9
5 GGts/VHT-20:
-57 DBm at MCS8
- USB-port
- Supports standard USB 3.0 (optional) *
Fiziksel Özellikler
