ANT50-2000NEOL EOS
Dual-polarized directional antenna for external use of 5 GHz
Nereden Alınır
Tanımlama
Directional Antenna D-Link ANT50-2000N Dual polarization for outdoor use can increase the range of your wireless network LAN, operating in the 5 GHz band. The antenna can provide a high-speed connection to connect to the devices standard 802.11n. The antenna is equipped with two connectors for the transmission of two spatial streams.
Point-to-Point
ANT50-2000N is ideal for operation in such modes as a point-to-point (WDS), and other modes which require a directional antenna with a high gain. The antenna provides the extension of the local network by combining the two networks LAN, separated physically. Alternatively customers WISP (Wireless Internet Service Provider) can also be used for this antenna installation secure connection between the host and external access point provider.
Weather resistance
Antenna ANT50-2000N made waterproof, rugged housing that conforms to IP67 and provides protection against environmental influences. Moreover, the case is made of a material resistant to corrosion, can withstand severe weather conditions and wind speeds up to 216 km / h, providing reliable performance throughout the life cycle. Module lightning protection ANT70-SP can be purchased separately for the protection of the receiver antenna from electrical voltage which could cause damage to other elements of external influences such as lightning.
Installation flexibility
To perform the installation of the antenna ANT50-2000N supplied antenna is set for installation, providing installation of antennas on the mast to provide improved wireless coverage. The package also included adapter cable with connectors N-type and RP-SMA for easy connections to the host.
Genel Özellikler
Fiziksel Özellikler
Frequency band
From 5.15 GHz to 5.875 GHz
Resistance
50 ohms
Gain
12-14dBi (5GHz frequency band)
VSWR
2.0: 1 (max)
The maximum gain
20 dBi
Radiation pattern in the horizontal plane (HPBW / H-PLANE)
10 ° C.
Radiation pattern in the vertical plane (HPBW / V-PLANE)
10 ° C.
Polarization
Dual in-line, 45 ° and -45 °
The ratio of foreground and background signal levels (PZO)
-30dB (max)
Cross-polarization isolation
24dB (minimum)
Fiziksel Özellikler
Cable
2 RP-SMA cable access points designed for indoor use
Jack
Two N-type connector
Allowable Power
6 W (cw)
Lightning Protection
DC Ground
Wind Load
216 km / h
Operating temperature
From -40 ° C to 80 ° C.
Operating Humidity
95% at 55 ° C.
The color and material
Gray-white, PC UV Resistant
Weight
1.32 kg
Measurements
320 x 320 x 20 mm
Impermeability
IP67
Mount Kit
Pole Mount and Wall
Çözümler
Sipariş Bilgisi
Görseller
ANT50-2000N/A1
Back view
Front view
İndir
Destek Merkezi
