Tanımlama
Antenna D-Link ANT24-0802C - is omni-directional antenna with a gain of 8 dBi, designed for indoor use. This antenna provides high transmission / reception for wireless network devices (for industrial, scientific and medical purposes). It can be used with wireless devices 802.11n, 802.11g and 802.11b, such as access points and remote routers, and allows you to use a single device instead of several. The antenna can be used to replace the standard antenna wireless device to increase the range.
Genel Özellikler
Fiziksel Özellikler
Resistance
50Ω
Directionality
Omnidirectional
VSWR
2.0 (max)
The maximum gain
8dBi (lossless cable)
Allowable Power
1 W
Reflectivity
-10 DB (maximum)
Antenna Type
Collinear antenna
The diagram in the horizontal plane (vector H)
360 °
Radiation pattern in the vertical plane (vector E)
24 °
Fiziksel Özellikler
Jack
RP-SMA
Operating temperature
-10 ° C ~ +45 ° C
Storage temperature
-20 ° C ~ +70 ° C
Operating Humidity
From 5% to 95% (non-condensing)
Humidity
The color and material of the antenna
• Antenna: Black
• Base plate: black
• Material: ABS, ABS + PC
Certifications
RoHS
Weight
35 grams
Measurements
325 x 13 mm
