DAP-1525EOL EOS
2.4/5GGts Dual Band Wireless (802.11n) access point / bridge, up to 300 Mbits /s
Nereden AlınırTanımlama
A fast, reliable connection to devices
Access Point D-Link DAP-1525 can function as a base station for connecting to a wireless network device of the standards 802.11a, 802.11b, 802.11g and 802.11n. DAP-1525 can operate in two frequency bands 802.11n technology to support SmartBeam: You can select a range of 2.4 GHz for compatibility with devices standards 802.11b/g/n, or 5 GHz for a stable connection with the 802.11a / n devices. Mode of the device - the bridge (bridge): works the same as "wireless client", but provides simultaneous access to the network for multiple devices connected using Ethernet-cable (as opposed to the regime, "wireless client"). Access Point DAP-1525 has four built-in Gigabit LAN ports with support for QoS; just connect wired devices to the ports in order of importance, and the DAP-1525 will automatically configure QoS for you. You can also connect a USB-printer or network storage and gain share them via the function SharePort D-Link.
Technology SmartBeam
Using a unique smart antenna D-Link, the access point DAP-1525 automatically adjusts its coverage to optimize the connection of each authorized wireless client. This extends the range of network coverage and minimize interference, provides high-speed connections, and even save power by adjusting the amount of power used for wireless connections.
Double wireless network coverage
Multiple antennas of the access point DAP-1525 double provide wireless coverage over the standard antenna, except for the dead zone. Connect the device at a great distance from the central point of access and enjoy a reliable connection to your network inside, outside and around the house.
Safety and reliability
WPA/WPA2 encryption protocols prevent unauthorized access to network traffic. You can also customize the guest areas to provide limited network access to individual wireless devices, as well as a timetable, it allows off your wireless network when you are away from your home or office.
Genel Özellikler
Fiziksel Özellikler
Standards
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.11b
• IEEE 802.11a
• IEEE 802.3
• IEEE 802.3u
• IEEE 802.3ab
Device Interfaces
• 802.11n/g/b/a wireless LAN
• 4-port LAN 10/100/1000BASE-T Gigabit
• 1 USB 2.0 port
Antenna Type
Internal Antenna with Smart Technology Smart Beam
Operation of the device
• The access point (AP)
• Bridge (bridge) *
Safety
• WPA and WPA2 (Wi-Fi Protected Access)
• 64/128-bit WEP-encryption
• Wi-Fi Protected setup (WPS) PBC / PIN
QoS
Port-based QoS
Data rate
IEEE 802.11a:
6, 9, 12, 18, 24, 36, 48, 54 Mbit / s
IEEE 802.11b:
11, 5.5, 2 and 1 Mbit / s
IEEE 802.11g:
IEEE 802.11n 5 GHz for:
from 0 to MCS MCS 15 (up to 300 Mbit / s)
IEEE 802.11n for 2.4 GHz:
The output power of the transmitter
IEEE 802.11a:
+12 DBm at 54, 48 Mbit / s
+14 DBm at 36, 24 Mbit / s
+15 DBm at 18, 12 Mbit / s
+15 DBm at 9, 6 Mbit / s
IEEE 802.11b:
+17 DBm at 11, 5.5, 2 and 1 Mbit / s
IEEE 802.11g:
+14 DBm at 54, 48 Mbit / s
+15 DBm at 36, 24 Mbit / s
+16 DBm at 18, 12 Mbit / s
+16 DBm at 9, 6 Mbit / s
HT20
12dBm at MCS0 ~ MCS15
HT40
HT-20
+14 DBm at MCS0 / 8, 1/9
+14 DBm at MCS2/10, 3/11
+14 DBm at MCS4/12, 5/13
+14 DBm at MCS6/14, 7/15
HT-40
+12 DBm at MCS0 / 8, 1/9
+12 DBm at MCS2/10, 3/11
+12 DBm at MCS4/12, 5/13
+12 DBm at MCS6/14, 7/15
Receiver Sensitivity
IEEE 802.11a:
-65 DBm at 54 Mbit / s
-66 DBm at 48 Mbit / s
-70 DBm at 36 Mbit / s
-74 DBm at 24 Mbit / s
-77 DBm at 18 Mbit / s
-79 DBm at 12 Mbit / s
-81 DBm at 9 Mbits / s
-82 DBm at 6 Mbit / s
IEEE 802.11b:
-76 DBm at 11 Mbit / s
-76 DBm at 5.5 Mbit / s
-80 DBm at 2 Mbit / s
-80 DBm at 1 Mbit / s
IEEE 802.11g:
HT-20
-82 DBm at MCS0 / 8
-79 DBm at MCS1 / 9
-77 DBm at MCS2/10
-74 DBm at MCS3/11
-70 DBm at MCS4/12
-66 DBm at MCS5/13
-65 DBm at MCS6/14
-64 DBm at MCS7/15
HT-40
-79 DBm at MCS0 / 8
-76 DBm at MCS1 / 9
-74 DBm at MCS2/10
-71 DBm at MCS3/11
-67 DBm at MCS4/12
-63 DBm at MCS5/13
-62 DBm at MCS6/14
-61 DBm at MCS7/15
HT-20
-82 DBm at MCS0 / 8
-79 DBm at MCS1 / 9
-77 DBm at MCS2/10
-74 DBm at MCS3/11
-70 DBm at MCS4/12
-66 DBm at MCS5/13
-65 DBm at MCS6/14
-64 DBm at MCS7/15
HT-40
-79 DBm at MCS0 / 8
-76 DBm at MCS1 / 9
-74 DBm at MCS2/10
-71 DBm at MCS3/11
-67 DBm at MCS4/12
-63 DBm at MCS5/13
-62 DBm at MCS6/14
-61 DBm at MCS7/15
Device control
• The Wizard Wireless Network
• Web-based management interface Internet Explorer v6 or higher, Firefox 2.0 or later or other Java-enabled browser
Podderzhkka features SharePort ™
• Shared access to the multifunction printer or USB-USB-attached storage device
Indicators
• AP
• Bridge
• WPS
• Power
Fiziksel Özellikler
Operating temperature
From 0 º to 40 º C
Storage temperature
From -20 ˚ to 65 ˚ C
Operating Humidity
From 10% to 90%, non-condensing
Humidity
From 5% to 95%, non-condensing
Measurements
115 x 95 x 190 mm
Weight
341.5 g
Certifications
• fcc class Statement B
• CE
• IC
• C-Tick
• IPv6 Ready
• Wi-Fi
• WMM
• Compatible with Windows 7
* Allows you to connect to wireless networks operating in the 2.4 GHz or 5 GHz (optional) works the same as "wireless client", but can provide simultaneous access to multiple network devices connected via Ethernet-cable.
