DHP-600AVEOL EOS
Gigabit Ethernet port Powerline Adapter
Tanımlama
Adapter DHP-600AV Powerline AV2 with a Gigabit Ethernet port uses the existing home electrical wiring to create a network or extend an existing network 1 . This adapter provides shared access to the Internet in the office, to game consoles in the living room, and allows you to establish a connection between two computers in different rooms without the need to use cables.
Data on the electrical wiring
Network Adapter DHP-600AV, incorporated into an electrical outlet, allows access to a variety of digital media devices, game consoles, print servers, computers and network storage devices. Thanks to HomePlug AV2 standard compliance and backward compatibility with the standard HomePlug AV adapter can be used DHP-600AV PowerLine devices with earlier versions.
The ideal solution for applications that require high bandwidth
DHP-600AV provides data transfer rates of up to 600 Mbit / s 2 , which makes the device an ideal solution for applications that require high bandwidth, providing streaming HD-video, VoIP-calls and play online without delay. In addition, the adapter supports the prioritization of Internet traffic, providing the performance of multimedia applications while viewing Web-pages and downloads. The device provides a high bandwidth, giving users the ability to use existing wiring for streaming high quality video.
Easy installation and safety
DHP-600AV plugs directly into a power outlet and does not require additional cables. Expand your home network by connecting multiple devices from the most distant points of the house, or create additional connection by connecting a switch or wireless access point to the adapter. For ease of installation, you can configure the encryption key at the touch of a button. The adapter supports 128-bit AES encryption to protect your network from unauthorized connection to the line. With simple installation Plug-and-Play, DHP-600AV adapter is the perfect solution to create a home network.
The power save function
DHP-600AV supports power saving mode, if for a certain period of time is not being transmitted or received, the adapter automatically switches to standby mode, reducing power consumption by more than 70%, and providing automatic energy savings without sacrificing performance.
Kit DHP-601AV
Set PowerLine AV2 600 DHP-601AV includes two adapters DHP-600AV. With the kit, you can create a home network PowerLine.
