DHP-346AV
PowerLine Switch with 4-port Ethernet 10/100Base-TX, up to 200 Mbit / s
Tanımlama
The radius of your home network
PowerLine 4-Port Switch D-Link DHP-346AV HomePlug AV standard supports for quick and easy extend the range of your home network. HomePlug AV provides data transfer rates of 200 Mbit/s1, making the device an ideal solution for fast Internet access, games, without delay, streaming video and VoIP. The Switch has four Fast Ethernet ports and a button to establish a secure PowerLine network connection in a few seconds.
Easy installation and safety
Port-based QoS makes setting quality of service in networks that require high performance, for example, network games, VoIP and multimedia applications. Connect devices that require high-performance, Ethernet-ports to the high priority and the switch itself will carry out all the necessary settings.
Saving energy with the help of technology D-Link Green
Technology D-Link Green include the following: reduction of the power consumption for the PLC and, depending on the status of the connection to Ethernet-ports. This technology disables the PowerLine with no activity over Ethernet. Power saving function automatically checks the status of the connection of wired devices and reduces the power consumption on inactive ports.
