DUB-H4EOL
4-Port USB 2.0 Hub
Tanımlama
The D-Link DUB-H4 4-Port USB 2.0 Hub provides an easy way to add four USB 2.0 ports to your notebook or desktop computer. In Fast Charge Mode, each of the USB ports can provide a maximum charging current of 2.4 A for iPads, or 1.5 A for Battery Charging 1.2 compliant devices. This means you can charge devices like iPads while also connect additional USB devices like digital and web cameras, card readers, hard drives, mice, keyboards, printers, scanners, and other peripherals.
Add Four USB 2.0 Ports to Your Computer
With the DUB-H4 4-Port USB 2.0 Hub, you can conveniently add more USB 2.0 ports to any computer. Now you can connect up to four more USB peripheral devices – such as digital cameras, printers, external hard drives, mice, keyboards, flash drives, and tablet computers – to your notebook or desktop computer. USB 2.0 technology supports data rates of up to 480 Mbps, which means that you can enjoy faster transfer speeds compared to previous USB standards.
Fast Charge Your Devices
The DUB-H4 features four Fast Charge USB ports that are designed to provide an increased maximum charging current of 2.4 A to connected devices when the DUB-H4 is in Fast Charge Mode*. This makes it perfect for charging power-hungry mobile devices like the iPad, as these devices have high-capacity batteries that require higher charging currents to recharge quickly and effectively. The DUB-H4 does not require a PC to charge your devices, so you can take it with you on the road and leave your mobile device chargers at home.
Sync and Charge Your iPad Anywhere
The DUB-H4 lets you back up your iPad while giving it a full charge at the same time**. It is
designed to fit into any notebook bag, and the compact size of the device will allow you to
conveniently carry it with you wherever you go. Experience the freedom and convenience of portability and expandability with the D-Link DUB-H4 4-Port USB 2.0 Hub.
Plug and Play
Simply plug in the power adapter and connect the DUB-H4 to any PC. It’s that easy - no drivers or software installation is required. Now you can connect up to four additional USB devices to your laptop, notebook, or desktop computer.
* The total combined power draw must be under 2.4 A or 12 W.
** D-Link provides a Windows utility for simultaneously syncing and charging iPads with 30-pin connectors.
Genel Özellikler
Standards
• USB specification version 2.0 (data rates of up to 480 Mbps)
• USB specification version 1.1 (data rates of up to 12 Mbps)
• OHCI
• UHIC
• EHCI
Interfaces
• Four USB Type A (female) downstream ports, white
• Upstream USB Type B (female) port
Connectivity Rules
• Up to 127 devices
• Up to five cascaded hubs
Minimum System Requirements
• Windows 10/8/7/Vista/XP
• Mac OS X 10.3 or above
• Linux
Power LED
• Bus-powered (Blue):
- Standard Charge Mode
• Self-powered (Green):
- Fast Charge Mode
Supplied Charging Current*
• Standard Mode:
- 500 mA total for all USB ports
• Fast Charge Mode*:
- Max. 1.5 A each for Battery Charging 1.2 compliant devices
- Max. 2.4 A each for iPad / iPhone
Physical Parameters
Power Input
• 5 V / 2.5 A DC
Temperature
• Operating: 0° to 40°C
• Storage: -40° to 60°C
Humidity
• Operating: 10% to 90%
• Storage: 5% to 95%
Dimensions
• 64 mm x 64 mm x 14 mm
Certifications
• FCC
• CE
• C-Tick
• IC
• RoHS
Çözümler
Sipariş Bilgisi
DUB-H4/D1 4-Port USB 2.0 Hub
