DCS-960LEOL EOS
Wireless HD network cloud camera with a viewing angle of 180° and support for night photography
Tanımlama
Wireless AC HD camera with a viewing angle of 180° and the support of night shooting DCS-960L is equipped with a wide-angle lens, providing a full overview of room in the resolution of 720p. Due to the possibility of position adjustment of the housing mounting the camera on the ceiling is never a problem, and the infrared illuminator allows video surveillance. Using the mydlink mobile app You can at any time get the remote access to the camera.
HD-quality video
Shooting in HD with a resolution of 720p allows you to display all the necessary details
Modern wireless standard 802.11 ac
Improving the quality of streaming video by providing wider bandwidth
Video surveillance
The presence of infrared illumination enables surveillance even in low light conditions or in its absence
Motion detection and sound
When the motion detector or sound by e-mail will be sent notifications with snapshots or video clips
8x digital zoom
Multiple image magnification for the detail of the subject in any point of view of the camera
Viewing angle 180°
The lens provides a wider coverage of the observed space compared to conventional cameras
Viewing angle 180°
The DCS-960L is equipped with a wide-angle lens, providing a viewing angle of 180°. Technology eliminate distortion allows to obtain a clear picture, but HD-sensor with a resolution of 720p provides detailed shooting.
Video surveillance
In the daytime the ICR filter camera cuts the infrared spectrum of light radiation, prevent obtaining the normal image, the maximum correction in color reproduction. At night ICR filter moves out of the way to use a wider range of radiation surveillance, and with infrared illumination (5m) provides control of the object even in complete darkness.
Motion detection and sound detection
The camera supports motion detection in the specified area of observation and the ability to set the thresholds of background sound, the excess of which is committed. When the motion detector or sound by e-mail will be sent notifications with snapshots or video clips.
High speed and reliable connection thanks to the 802.11 AC
When mounting the camera you must ensure that when connecting to the local network, video is transmitted without delay. The support of 802.11 AC can improve the quality of streaming video by providing a wider bandwidth. In addition, due to the larger coverage area of the camera can be placed almost anywhere.
Remote access with mydlink
Support DCS-960L the mydlink™ service makes monitoring your home or office easier and more convenient and allows you to stay connected regardless of location. Camera access can be obtained via the mydlink website and by using the application that enables view and control camera from your tablet or mobile phone.
