DCS-3714EOL EOS
HD Day and Night WDR Camera
Tanımlama
Tanımlama:
The D-Link DCS-3714 HD Day and Night WDR Camera with LowLight+ is a high definition professional surveillance and security solution suitable for small, medium, and large enterprises. The camera uses a high-sensitivity HD resolution progressive scan CMOS sensor with onboard WDR image enhancement to deliver truly superior quality video in all conditions.
LowLight+
Incorporating a highly sensitive CMOS sensor, the DCS-3714 provides outstanding performance in low light-conditions, resulting in more vibrant color detail regardless of the amount of light available. The noise reduction feature has been upgraded and enhanced as well to provide a level of detail in the image quality that is unmatched by other offerings in the market.
Flexible Connectivity
The DCS-3714 includes input and output ports allowing connectivity to external devices such as IR sensors, switches, and alarm relays. It also comes with an RS-485 interface, providing connectivity to an optional pan/tilt enclosure which effectively adds pan/tilt functionality to the DCS-3714. An additional 12 V interface provides power for an optional LED illuminator.
High Resolution Surveillance
The D-Link DCS-3714 is a high-end HD Day & Night WDR Network Camera, equipped with a 1/3” HD Resolution WDR Progressive Scan CMOS sensor and a 2.9-8.2 mm DC auto iris lens. The DCS-3714 captures video in both dark and light environments, or even subjects shot with backlighting by neutralizing imperfect lighting and generating a realistic image. In addition, the removable IR-cut filter for day/night functionality provides clear detail and high quality video at any hour of the day. The DCS-3714 incorporates Power over Ethernet (PoE) and an SD card slot, allowing it to be easily installed in a variety of locations.
Multiple Video Streams
The DCS-3714 supports simultaneous streaming of H.264, MPEG-4, and MJPEG video to provide both high-quality and bandwidth-efficient compression formats. MJPEG delivers excellent file integrity, ideal for situations which require high image detail. H.264 and MPEG-4 produce a small file size, useful for extended recording or for use in low-bandwidth networks. Additionally, the DCS-3714 supports multicast H.264 and MPEG-4 streaming, allowing users to view the camera feed by subscribing to a multicast IP address on the network.
Wide Dynamic Range (WDR) Applications
The Wide Dynamic Range (WDR) function provides clear images even under backlit conditions where the intensity of illumination can vary significantly, making the DCS-3714 perfect for extreme high-contrast environments. For example, when placed indoors, the DCS-3714 will adjust itself to the intense sunlight that may be streaming in through a nearby window. This makes it an ideal solution for security applications.
Genel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
DCS-3714/Ax
Left side view
View from the right
Back view
İndir
Destek Merkezi
