DCS-6010LEOL EOS
Wireless 802.11n IP-video camera with a viewing angle of 360 ° and a support service mydlink
Tanımlama
Wireless 802.11n IP-video camera with a viewing angle of 360 ° DCS-6010L, equipped with a lens fisheye ("fish-eye"), two-megapixel sensor and a maintenance service mydlink, is the perfect solution for video surveillance over a large area
360 ° viewing angle
DCS-6010L uses a lens fisheye, to provide an incredibly wide viewing angle. Just place the camera on the wall for a panoramic view of the room or place the camera on the ceiling for the 360-degree view of the lack of dead zones. Distortion correction function captures an image from the camera, so you can use the ePTZ to zoom, remote and turn the camera images and video surveillance of a large area.
Remote access through the service mydlink
Wireless 802.11n IP-video camera with a viewing angle of 360 ° DCS-6010L supports service mydlink, allowing you to access and configure the camera remotely, regardless of location. You can view the camera image in real time over the Web-site mydlink, or you can download the mobile app mydlink and monitor directly to your mobile device with iOS or Android. Watch out for the house when you're at work or supervise work in the office when you're on the road, with the help of service mydlink.
Zero Configuration Mechanism
If you have a router that supports the service mydlink, then through the mechanism of Zero Configuration to install and configure DCS-6010L is not difficult. Simply connect the camera to the power adapter, and then - to the mydlink router using Ethernet-cable. The camera will be automatically added to your account. Mydlink service allows even inexperienced users to easily install and use cameras that support this service.
Ready, scalable solution for video surveillance
DCS-6010L is a standalone solution for video surveillance lets you record still images and video on a Micro SD card and does not require a PC or network storage device.
Options to expand video surveillance kit includes software D-ViewCam, providing the opportunity to control up to 32 cameras with a wide range of functions, including viewing of multiple cameras and automatic e-mail alert to suspicious or unusual activity.
Versatility
DCS-6010L has a host of features that enhance the surveillance capabilities and make the camera ideal for any situation. Built-in microphone and speaker provide two-way audio transmission performance of the signal or siren when a specific event. DCS-6010L also supports wireless 802.11n, allowing you to place the camera anywhere without the need to lay Ethernet-cable.
