DCS-6616Proje
High-speed PTZ dome network camera with a 12x optical zoom
Nereden Alınır
Tanımlama
Clock surveillance
High-speed dome network camera with a 12x optical zoom, DCS-6616 provides an overview of a large area, including in low-light conditions. With built-in sensor Sony Super HAD-II quarter "CCD IP-Camera DCS-6616 can transmit high-resolution video 650 TVL with superb image quality. Built-ICR-filter allows the camera to capture high-quality images in bright lighting conditions, and in the dark. During the day, ICR-filter stays in place and does not transmit infrared radiation that provides high-quality images. At night, the ICR-shift filter, which allows the camera to use infrared light for shooting in low-light conditions.
Multi-functional PTZ (tilt / rotate / zoom)
IP-Camera DCS-6616 has a wide range of features PTZ, providing an overview of a large area. With the rotation of 360 degrees can easily observe the surrounding area, and the 12-times optical zoom with auto focus delivers picture details. The speed of rotation varies and is proportional to the scaling factor for the precise control of the movement of the camera. PTZ preset point allows the camera DCS-6616 navigate through them and monitor automatically.
The flexibility to connect
Camera DCS-6616 is equipped with input and output ports to connect to external devices such as IR sensors, switches and alarm relays. The camera is equipped with audio input and output ports, and video output to connect directly to a TV to watch in real time.
Applications WDR (Wide Dynamic Range)
WDR function provides clear images even under backlight behind the object of observation, where the intensity of illumination can vary significantly. This makes the DCS-6616 an ideal solution for observation in high-contrast lighting. For example, when installing the unit in a room DCS-6616 adapts to the conditions of intense sunlight falling out of the window, which makes this camera ideal security.
Transmission of multiple video streams
DCS-6616 supports simultaneous streams of video formats: H.264, MPEG-4 and MJPEG, to provide high-quality images in a good use of the bandwidth. MJPEG format provides file integrity and is ideal for situations that require high image detail. Compression formats H.264 and MPEG-4 files can get small size, which is useful for long-term recording or for use in networks with narrow bandwidth. In addition, DCS-6616 supports multicast transmission of data in H.264 and MPEG-4, which allows users to watch videos, connect to multicast streams in the network.
Genel Özellikler
Fiziksel Özellikler
Camera
Hardware profile camera
• Sensor Sony Super HAD-II 1/4 "CCD
• Resolution 650 TVL
• Minimum illumination: 0.1 lux (color), 0.01 lux (B / W)
• Built-in ICR-filter
• Electronic shutter from 1 to 1/100000 seconds
• The ratio of the "signal-to-noise"> 50 dB (automatic gain control (AGC off)
• 12x optical zoom
• Fixed lens with a focal length: 3.8 to 45.6 mm
• Aperture: F1.6 to F2.7 from
• Viewing angle:
   of 4,49 ° to 52,8 ° (horizontal)
   of 3,40 ° to 39,7 ° (vertical)
   from 55,4 ° to 65,4 ° (diagonal)
Hardware profile PTZ
• Rotation: 360 °
• Tilt: 10 ° to 170 °
• Manually adjust the speed from 1 ° to 80 ° per second
• Preset points: 256 points
• The accuracy of the Pan / Tilt: 0,225 °
• The speed pan / tilt: 10 ° to 400 ° per second
• Number of independent paths when operating in Sequence: 8
• The number of independent paths when operating in Auto Pan: 4
• Number of independent paths when operating in Cruise: 8
• The speed of rotation is proportional to the tilt and zoom level
• Resume after power loss
• Functions of Home: Preset, Sequence, Auto Pan, Cruise
• Automatic coup: the mechanical / digital / off
• Digital Slow Shutter
• Pause
• Image flip
Image Functions
• Setting the image size and quality, frame rate and bit rate
• The timings and paste text
• Customizable windows for motion detection
• 16 customizable areas of private masks
• Setting the white balance, shutter speed, brightness, color saturation, contrast and sharpness
Video Compression
• Video compression formats H.264/MPEG-4/MJPEG
• JPEG for still images
Video Resolution
• NTSC: 720 x 480, 352 x 240, 176 x 120 at frame rates up to 30 frames / s
• PAL: 720 x 576, 352 x 288, 176 x 144 at frame rates up to 25 frames / s
Sound support
G.726
External device interfaces
• Port 10/100 BASE-TX Ethernet
• 8 input alarm sensors
• 1 alarm output sensor
• Audio In / Out
• Video
Network
Network Protocols
IPv4, TCP / IP, UDP, ICMP, DHCP-Client, NTP-Client (D-Link), DNS-client, DDNS-Client (D-Link), SMTP-client, FTP-client, HTTP / HTTPS, Samba- client, PPPoE, port forwarding UPnP, RTP / RTSP / RTCP, filtering on IP-addresses, 3GPP, IGMP, ONVIF compliance
Safety
• Security administrator account and user groups
• Password authentication
System control
System requirements for Web-based interface
• Operating System: Microsoft Windows 7/Vista/XP/2000
• Browser: Internet Explorer, Firefox, Netscape, Opera
Event Management
• Motion detection
• Event notification and download stop-kadrov/videoklipov via HTTP, SMTP or FTP
• Supports multiple HTTP, SMTP and FTP-servers
• Multiple event notifications
• Several ways to create backups
Remote management
• Configuring via Web-browser
• Get stop-kadrov/videoklipov and save to your local hard drive or NAS via Web-browser
Support for mobile devices
The system Windows 7/Vista/XP, Pocket PC or mobile phone with 3GPP playback support
System Requirements D-ViewCam ™
• Web-browser: Internet Explorer 6 or higher
• Protocol: The standard TCP / IP
The software features D-ViewCam ™
• Remote management / control of up to 32 cameras
• View up to 32 cameras on one screen
• Supports all management functions provided in the Web-interface
• Schedule of events to trigger or manual recording
Fiziksel Özellikler
Power Input
12 V DC, 2 A
The maximum power consumption
14 W
Operating temperature
From 0 ° to 40 ° C
Storage temperature
-20 ° to 70 ° C
Humidity
From 20% to 80% non-condensing
Weight
1.2 kg
Certifications
CE (Class A), CE LVD (EN60965-1), FCC (Class A), ICES-003, C-Tick
Measurements
Çözümler
Sipariş Bilgisi
Görseller
DCS-6616/Ax
Front view
View from the right
İndir
Destek Merkezi
