DCS-2132LEOL EOS
Tanımlama
Wireless 802.11n HD Camcorder "Cube" DCS-2132L mydlink-enabled service provides round the clock remote monitoring your home or office.
24/7 Camera Surveillance
DCS-2132L has a megapixel sensor and can create crisp, detailed still images and high-quality video at up to 720p HD. EPTZ function, you can zoom, rotate the camera image, and view such a vast area.
Built-in ICR-filter blocks infrared light during the day to improve image quality. At night, the ICR-filter is moved to the side to use a wider range of radiation surveillance, and with infrared illumination provides control over an object, even in complete darkness.
Remote access through the service mydlink
Wireless 802.11n HD Camcorder "Cube" supports service mydlink, allowing you to access and configure the camera remotely, regardless of location. You can view the images from the camera in real time over the Web-site mydlink, or you can download the mobile application mydlink and monitor directly to your mobile device with iOS or Android. Keep the house, when you're at work or supervise work in the office while you're on the go, with the service mydlink.
Zero Configuration Mechanism
If you have a router that supports the service mydlink, is due to the mechanism Zero Configuration to install and configure DCS-2132L is not difficult. Simply connect the camera to the power adapter, and then - to the mydlink router using Ethernet-cable. The camera will be automatically added to your account. Mydlink service allows even inexperienced users to easily install and use cameras that support this service.
Universality
DCS-2132L has many features that enhance the surveillance capabilities and make the camera ideal for any situation. PIR-sensor detects movement near the camera, allowing you to automatically record the video and send a notice in this case. Built-in microphone and speaker allow two-way communication and can be useful when used at the entrance to the building. Wireless connectivity 802.11n standard makes it easy to place the camera anywhere without running Ethernet-cable.
Ready, scalable solution for video surveillance
DCS-2132L is a standalone solution for video surveillance can record still images and video on the MicroSD card and does not require a PC or network storage device.
Options for expanding video delivery including software D-ViewCam, providing the ability to manage 32 cameras, with a range of functions, including viewing of multiple cameras, and automatic e-mail alert for suspicious or unusual activity.
