DCS-930LEOL EOS
802.11n Wireless Internet Camera with mydlink support service
Tanımlama
	Surveillance Camera for home and office
	DCS-930/930L - a versatile and unique solution for the small office and home. In contrast to standard Web-cameras DCS-930/930L a complete system with a built-in CPU and web-server that transmits high quality video images for security and surveillance. Simple installation and an intuitive Web-based interface offer easy integration with Ethernet / Fast Ethernet or wireless network 802.11n. DCS-930/930L also comes with remote monitoring and motion detection features for a complete and effective home security solution.
	802.11n wireless connectivity
	DCS-930/930L wireless interface supports 802.11n, and thus a simple integration into existing network. Wireless N technology allows you to stream high-quality video to remote sites or mobile devices. Site Survey feature also allows you to easily view and connect to nearby wireless networks. DCS-930/930L an Ethernet port for connection to traditional wired networks.
	Mydlink utility for quick and easy access to the video (DCS-930L)
	With the convenient mydlink ™ utility, you can quickly set up the camera DCS-930L, then register it on the web-site mydlink ™.DCS-930L will then automatically configure and connect to the service mydlink ™ for easy access to the video from anywhere on the Internet.
	Easy setup and easy to use
	The network camera supports Plug-n-Play, which allows computers running on Windows XP/Vista/7 to automatically recognize the camera and add it to the network. Sign up with one of the free servers DDNS, you can set the camera domain name (for example, mycamera.dlinkddns.com). This will allow the use of remote access to the camera without knowing its IP-address.Software D-ViewCam D-Link allows you to view up to 32 cameras on a single computer screen. Users can set up an automatic notification by e-mail to be instantly informed of unusual activities.
