Tanımlama
Video monitoring
Camera DCS-2103 - a unique and versatile solution for small offices and homes. Unlike a standard webcam, the DCS-2103 is a complete system with a built-in CPU and web server that transmits high quality video. Simple installation and an intuitive Web user interface allows for easy integration with Ethernet. DCS-2103 also supports remote control and motion detection functions - ensures effective comprehensive protection of the premises.
ePTZ function
ePTZ function allows you to select the desired tracking / shooting areas to increase the use of the web browser. Because of these features megapixels resolution camera to deliver sharp color images and can monitor a large area. The fact that the camera has no moving parts, only increases its reliability.
Easy installation and use
DCS-2103 fully complies with the Universal Plug-n-Play standard that allows a computer with Windows XP/Vista/7 to automatically detect the camera and connect it to your network. Using one of the many free Dynamic DNS services online, the camera can assign an easy to remember domain name (for example, mycamera.dlinkddns.com). In this way, remote access to the camera, even without knowing its IP address. Software D-Link D-ViewCam allows simultaneously on a single computer screen shows 32 cameras view. The camera can be set for automatic e-mail alert about unusual events in the system.
Genel Özellikler
Fiziksel Özellikler
Main characteristics:
- ¼ inch million pixel progressive CMOS sensor
- Minimum illumination: 1.0 lux
- 10x digital zoom
- Built-in lens with a fixed focal length 3:45 mm
- Aperture F2.0
- Reviews angles:
- Horizontal: 57.8 o
- Vertical: 37.8 o
- Diagonally: 66 and
Video functional:
- Image quality, size and velocity of
- Text and time stamps recording option
- Outdoor motion detection to identify
- Three personal templates
- Setting the shutter speed, brightness, sharpness, contrast
Video Compression:
- Image compression of the following formats: H.264/MPEG4/MJPEG
- JPEG shots sustapdytiems
- H.264/MPEG-4 multicast streaming
Video image resolution is able to:
- 16:9 - 1280x800, 1280x720, 800 х 450, 640 х 360 х 480 270 320 176 х 176 х 144 at 30 frames / s
- 4:3 - 1024 x 768, 800 x 600, 640 x 480, 480 x 360, 320 x 240, 176 x 144 at 30 frames / s
Audio support:
- G.726
External Interfaces:
- 1 DI / 1 DO
- Micro SD card slot
- Built-in microphone
- Audio outgoing port (3.5 mm)
Network protocols:
- IPv4, TCP / IP, UDP, ICMP, DHCP Client, NTP Client (D-Link), DNS Client, DDNS Client (D-Link), SMTP Client, FTP Client, HTTP / HTTPS, Samba Client, PPPoE, UPnP Port Forwarding RTP / RTSP / RTCP, IP filtering, 3GPP, IGMP, ONVIF
Security:
- Administrator and user group security event log
- Authentication password
- Digital encryption for HTTP and RTSP
System Requirements:
- Operating system: Windows 7/Vista/XP/2000
- Browser: Internet Explorer, Firefox, Netscape, Opera
Event Management:
- Motion Detection
- Notification of events and pictures or video scanning via HTTP, SMTP or FTP
- Multiple HTTP, SMTP and FTP servers support
- Several reports on events
- Several ways to create backup
Remote control:
- Setting selection in the Web browser
- Ability sustapdytus shots or video clips via a Web browser to save to your hard drive or network repository
PDAs, mobile phones and software support:
- Windows 7/Vista/XP, handheld, or mobile phone with 3GPP support
System requirements when you want to use D-ViewCam:
- Operating System: Windows 7/Vista/XP
- Browser: Internet Explorer 6 or later
- Protocol: TCP / IP
D-ViewCam features:
- Management / control: up to 32 cameras
- Ability to view 32 cameras on a single screen view
- In support of management functions through the Web user interface
- Ability to capture an image sensor triggered or manually
Physical parameters
Meals:
- Incoming: 5 V DC, 1.2 A, 50/60 Hz
Maximum power:
- 2 W
Dimensions (mm):
Size:
- 68 g
Working temperature:
- 0 º to 40 º C
Storage temperature:
- -20 º to 70 º C
Humidity:
- 20% to 80% without condensation
Certifications:
- The FCC Class B
- CE
- CE LVD
- C-Tick
