DEM-PB1S-OLTProje
GPON OLT transceiver at a rate of 2.488 / 1.244 Gb / s downstream / upstream
Tanımlama
Transceiver GPON OLT DEM-PB1S-OLT is intended for use in passive optical network (PON), with data rates 2.488 Gb / s - for downstream, 1.244 Gbit / s - for upstream. This transceiver complies with the ITU-T G.984.2.
Transceiver DEM-PB1S-OLT has a connector type SC, an industry standard.
The module is designed for use in a GPON OLT DPN-6608.
