DGS-1100-08PEOL
8 port EasySmart 10BASE-T/100BASE-TX/1000BASE-T ve PoE destekli kompakt anahtar
Nereden AlınırTanımlama
Switch DGS-1100 series is a cost-effective solution for a class of SOHO and small and medium-sized businesses, as well as for networking companies, such as branch offices and meeting rooms that require simple control. Each model comes in a compact desktop metal case and is equipped with 5, 8, 16 or 24 Gigabit ports.
Energy saving technology of D-Link Green
DGS-1100 switches conform IEEE802.3az Energy Efficient Ethernet, consuming less power with a small amount of traffic.Installation of EEE provides small and medium-sized businesses saving money by reducing the costs associated with the purchase of equipment for cooling. Switches DGS-1100 series support JavaScript D-Link Green, providing automatic reduction of energy consumption. If the automatically determined by the length of cable connected less than 20 meters, the switch reduces power consumption. In addition, the switch determines the connection status of each port and provides automatically powers down ports.
Simple operation
EasySmart switches support management through SmartConsole utility or through a Web-based interface. SmartConsole easily allows customers to discover line switches D-Link Smart in the same network segment L2. With this utility, eliminating the need to change the IP-address of the computer and provides easy initial installation series switches Smart. Displayed on the screen switches belonging to the same network segment and connected to the user's local PC, and there is the possibility of immediate access. User available extended configuration and basic setup of discovered devices such as password changes and software updates. Web-friendly graphical interface allows network administrators to remotely manage network port level.
Surveillance VLAN and Bandwidth Management
Switches DGS-1100 series support JavaScript Surveillance VLAN for the video. Surveillance VLAN assigns video traffic priority and a separate VLAN, providing high-quality video surveillance and data through one switch DGS-1100, thereby reducing expenses associated with the acquisition of additional equipment. In addition, the bandwidth management function allows to reserve bandwidth for various applications that require high bandwidth, or provide them with the highest priority.
Simple Troubleshooting
Switches support the Loopback Detection and Cable Diagnostics, which allows network administrators to quickly and easily find and fix problems in the network. Loopback Detection is used to detect loops and automatically disable the port on which a loop was detected. Cable Diagnostics is designed to determine the types of copper cabling, and the type of cable error.
Advanced feature set
Switch Series DGS-1100 supports advanced security features such as Static MAC, protection from storms and IGMP Snooping.Static MAC function allows you to create "white" list of MAC-addresses, allowing access only to authorized devices. Function storm protection necessary to limit to a predetermined threshold broadcast, multicast or unknown unicast traffic. Switch blocks or drops packets that fall under this restriction, since a large number of such traffic can lead to network congestion. IGMP Snooping function reduces the number of multicast traffic and increase network performance.
Genel Özellikler
Fiziksel Özellikler
Size
Table size
Number of ports
8-port 10/100/1000BaseT PoE
Function on the ports
• IEEE 802.3
• IEEE 802.3u
• Supports full / half duplex (for half-duplex 10/100 Mbit / s, full duplex 1000 Mbit / s)
• Auto-negotiation
• Auto detection of MDI / MDIX
• IEEE 802.3x flow control in full duplex mode
• IEEE 802.3az
Performance
• Bandwidth switch 16 Gbit / c
• Maximum speed packet forwarding: 11.9 Mpps
• MAC-Address Table: 8K entries per device
• Packet Buffer: 2 Mbps
• Flash-Memory: 2 MB
Standard PoE
802.3af
Ports with PoE
• Ports 1-8: 15.4W
• Max. 15.4W on 4 ports 10/100/1000 Mbit / s
• Max. 8 W at 8 ports 10/100/1000 Mb / s
PoE power budget
64 W
Indicators
• Power (per device)
• Max. PoE
• Link / Activity / Speed (per port)
Software Functions
VLAN
• Port-based
• 802.1Q tagged VLAN
• Surveillance VLAN
• Management VLAN
• Group VLAN
- Max. 32 static VLAN
- Max. 4094 VIDs
Layer 2 features
• MAC Address Table: 8K
• Flow Control
- 802.3x Flow Control
- HOL Blocking Prevention
• Jumbo-frames up to 9216 bytes
• IGMP Snooping
- IGMP v1/v2 Snooping
- Supports up to 32 IGMP-groups
• Link Aggregation: Group 1, 2-4 ports per group
• The Loopback Detection
• Diagnostic cable
• Port Mirroring
- One-to-One
• Statistics
- Tx Ok
- Tx Error
- Rx Ok
- Rx Error
Quality of service (QoS)
• 802.1p
• 4 queues per port
• Mechanisms queuing
- Strict
- Weighted Round Robin (WRR)
• Bandwidth Management
- Port-based (Ingress / Egress, selected from a list with a minimum of 8 kbit / s)
Security
• Static MAC-address: up to 32 entries
• Protection from the broadcast / multicast / unicast storm
Management
• Web-interface GUI (Supports IPv4)
• The SmartConsole
Technology D-Link Green
• Lower power consumption, depending on:
- Connection status
- Cable lengths
• RoHS 6
List of RFC standards
• RFC 768 UDP
• RFC 791 IP
• RFC 792 ICMP
• RFC 793 TCP
• RFC 826 ARP
• RFC 951 BootP-client
• RFC 1542 BootP / DHCP client
• RFC 1945 HTTP/1.0
• RFC 2647 802.1p
Fiziksel Özellikler
Power consumption
• Mode Standby: 2,0 W
• Maximum: 78,8 W
Power Input
External universal power supply 100 to 240 VAC, 50/60 Hz
MTBF (hours)
708.219 h
Noise level
0 dB
Heat release
268,87 BTU / hour
Weight
0,706 kg
Measurements
190 x 120 x 38 mm
Fans
no
Operating temperature
From 0 to 50 ° C.
Storage temperature
-10 To 70 ° C
Operating Humidity
From 10 to 95% (non-condensing)
Electromagnetic compatibility
FCC Class A, CE Class A, VCCI Class A, ICES-003, C-Tick
Security
cUL, CE LVD
