DIS-210G-12UPYeni
Layer 2 Industrial Managed Switch with 6x10/100/1000Base-T 802.3at PoE Ports, 2x10/100/1000Base-T 802.3bt/UPoE Ports and 4x1000Base-X SFP Ports
Tanımlama
The DIS-210G-12UP Layer 2 Gigabit Industrial Managed Switch is equipped with 6 30 W PoE-capable 10/100/1000Base-T ports, 2 60 W PoE-capable 10/100/1000BASE-T ports and 4 SFP ports. This switch features a robust design making it ideal for deployment in industrial and outdoor cabinet surveillance settings, capable of withstanding the harshest environments. The DIS-210G-12UP switch furthermore integrates advanced management and security functions to provide a complete industrial networking solution.
Durable, Reliable, and Efficient
The DIS-210G-12UP switch is housed in a highly resistant IP40-rated metal casing to protect it from harsh environmental conditions. The high electromagnetic compatibility (EMC) protects the DIS-210G-12UP from unwanted effects when operating in environments with strong electromagnetic interference. Meanwhile, the fanless design extends the life of the DIS-210G-12UP while also being able to operate in a wider temperature range of up to 75 °C. With DIN rail mounting capability, the DIS-210G-12UP can fit seamlessly into your industrial equipment infastructure.
Additionally, the DIS-210G-12UP features high-capacity 6 kV surge protection on all copper ports to help prevent damage to the switch and connected devices caused by sudden power surges and lightning strikes. The built-in surge protection of up to 6 kV can mitigate the damage to the switch from both indoor and outdoor devices and network connections by absorbing the excess energy while still letting through the amount of power required for the switch to operate normally. This increases network reliability, reduces repair costs, and removes the need for replacement hardware in the event of an electrical surge or lightning strike.
High Redundancy and Reliability
The DIS-210G-12UP supports ERPS quick failover recovery for ring topologies that ensures minimal downtime and avoids any loss of data in mission-critical deployment settings. Meanwhile, the dual power input allows for a redundant power supply to make sure the device continues to operate in the event of a primary power supply failure.
Easy Troubleshooting
The DIS-210G-12UP features loopback detection and a web-based management interface to help network administrators find and solve network problems quickly and easily. Loopback detection is used to detect loops created by a specific port and automatically shuts down the affected port. The web-based interface provides a user-friendly way for network administrators to manage the switch down to the port level. The interface can be accessed from a web browser, allowing the switch to be controlled from any PC that is connected to the network.
Power Over Ethernet
The DIS-210G-12UP is PoE-ready switch with a total PoE budget of 240 W. The DIS-210G-12UP provides 6 PoE ports using 802.3af and 802.3at, and 2 ports using 802.3bt 60 W PoE standards. This effectively reduces deployment times, reduces cable clutter, and eliminates the need for dedicated power supplies to allow PoE-devices to be installed in remote locations.
Genel Özellikler
Hardware Version
• A1
Number of Ports
• 8 10/100/1000Base-T PoE ports
• 4 1000Base-X SFP ports
• RJ-45 console port
Diagnostic LEDs
• Power
• SYS
• Link/Act (per port)
• PoE (per PoE port)
Material
• IP40-rated metal casing
Installation
• DIN rail mountable
Port Functions
• IEEE 802.3 10Base-T
• IEEE 802.3u 100Base-TX
• IEEE 802.3ab 1000Base-T
• IEEE 802.3z 1000Base-X
Media Interface Exchange
• Auto-MDI/MDIX adjustment for all twisted pair ports
Switching Capacity
• 24 Gbps
Transmission Method
• Store-and-forward
Maximum Forwarding Rate
• 17.85 Mpps
MAC Address Table Size
• 8K entries
Packet Buffer Memory
• 4.1 MB
Jumbo Frame
• 9 KB
Flash Memory
• 16 MB
DRAM Size
• 128 MB
PoE Standards
• IEEE 802.3bt/UPoE
• IEEE 802.3at
• IEEE 802.3af
PoE Ports
• Ports 1 to 8
PoE Mode
• Ports 1 to 8: mode A
PoE Budget
• 240 W
• Up to 60 W per port 1-2
• Up to 30 W per port 3-8
Software Features
L2 Features
• MAC Address Table
- 8K entries
• IGMP Snooping
- IGMP v1/v2 Snooping
- 508 IGMP groups
- IGMP Snooping Fast Leave
- 508 static IGMP groups
- Per VLAN IGMP Snooping
- IGMP Snooping Querier
• Loopback Detection
• 802.3ad Link Aggregation
- Max. 8 groups per device, 8 ports per group
• LLDP
• LLDP-MED
• Spanning Tree Protocol
- 802.1D STP
- 802.1w RSTP
- 802.1s MSTP
- BPDU Filtering
- Root Guard
- Loop Guard
• Port Mirroring
- One-to-One
- Many-to-One
- Mirroring for Tx/Rx
• Flow Control
- 802.3x Flow Control
- HOL Blocking Prevention
• MLD Snooping
- MLD v1/v2 Snooping
- Support 508 MLD Groups
- MLD Snooping Fast Leave
- Supports 508 static MLD groups
- MLD Snooping Querier
- Per VLAN MLD Snooping
• VLAN Mirroring
• RSPAN
• L2 Protocol Tunneling
• Ethernet Ring Protection Switching (ERPS)
VLAN
• 802.1Q
- Configurable VID from 1 - 4094
• GVRP
- Max. 4094 dynamic VLAN group
• Double VLAN (Q-in-Q)
- Port-based Q-in-Q
- Selective Q-in-Q
• Port-based VLAN
• 802.1v Protocol-based VLAN
• MAC-based VLAN
• Voice VLAN
• Subnet-based VLAN
• VLAN Trunking
• Super VLAN
• Private VLAN
Quality of Service (QoS)
• 802.1p
• 8 queues per port
• Queue Handling
- Strict Priority Queue (SPQ)
- Weighted Round Robin (WRR)
- SPQ + WRR
• Policy Map
- Remark 802.1p priority
- Remark ToS/DSCP
- Rate Limiting
- Time-based QoS
• Bandwidth Control
- Port-based (ingress/egress, min. granularity 64 Kbps)
- Flow-based (ingress/egress, min. granularity 64 Kbps)
- Queue-based bandwidth control
L3 Features
• IP interface
- Supports 10 interfaces
• ARP Proxy
- Local ARP Proxy support
• Gratuitous ARP
• UDP Helper
L3 Routing
• Static routing
- Max IPv4 static routes: 128
- Max IPv6 static routes: 64
• IPv4/IPv6 Default Route
• Null Route
Access Control List (ACL)
• Max. ACL entries:
- Ingress
- IPv4: 895
- IPv6: 384
• ACL based on:
- 802.1p priority
- MAC address
- IP address
• Max Access List Numbers: 256
Security Features
• Broadcast/Multicast/Unicast Storm Control
• SSH v2
• TLS v.1.2
• SSL v3
• Port Security
- Up to 8K MAC addresses per port
• ARP Spoofing Prevention
- Max. 200 entries
• IP Source Guard
• Dynamic ARP Inspection (DAI)
• L3 Control Packet Filtering
• BPDU Attack Protection
• DoS attack prevention
• IP-MAC-Port Binding (IMPB)
• DHCP Snooping
• Password encryption
AAA
• 802.1X Authentication
- Supports port/host-based policy assignment
- ACL Assignment
• Guest VLAN
• Trusted Host
• RADIUS/TACACS+ Accounting
• Web-based Access Control (WAC)
• Authentication Database Failover
• MAC-based Access Control (MAC)
• MD5 authentication
• IPv4/IPv6 RADIUS server
OAM (Operations, Administration and Maintenance)
• Cable diagnostics
• 802.3ah Ethernet Link OAM
• Dying Gasp
• Y.1731 OAM
Management
• Web-based GUI
- IPv4 access
- SSL (HTTPS)
• Command Line Interface (CLI)
• Telnet Server
• Telnet Client for IPv4/IPv6
• TFTP Client
• DHCP Client
• Secured FTP (SFTP) Server
• SNMP v1/v2c/v3
• SNMP Traps
• sFlow
• DHCP Auto-Configuration
• DHCP/DHCPv6 Local Relay
• DHCP Relay Option 82
• Flash File System
• Debug command
• IPv4 SNTP Server
• Network Time Protocol (NTP)
• System Log
• SNTP
• RMON v1/v2
• Command logging
• Zero Touch Provisioning (ZTP)
Green Feature
• Time-based PoE
MIBs
• RFC1065, RFC1066, RFC1155, RFC1156, RFC2578 MIB Structure
• RFC1213 MIBII
• RFC1493, RFC4188 Bridge MIB
• RFC1157, RFC2571, RFC2572, RFC2573, RFC2574, RFC2575, RFC2576 SNMP MIB
• RFC1442, RFC1901, RFC1902, RFC1903, RFC1904, RFC1905, RFC1906, RFC1907, RFC1908, RFC2578, RFC3418, RFC3636 SNMPv2 MIB
• RFC2819 RMON MIB
• RFC2021 RMONv2 MIB
• RFC1398, RFC1643, RFC1650, RFC2358, RFC2665, RFC3635 Ether-like MIB
• RFC2674, RFC4363 802.1p MIB
• RFC2233, Interface Group MIB
• RFC4133 Entity MIB
• Private MIB
• RFC3621 Power Ethernet MIB
• LLDP-MED MIB
• IPv4 Multicast Routing MIB
• IP Forwarding Table MIB
RFC Standards
• RFC791 IP
• RFC768 UDP
• RFC793 TCP
• RFC792 ICMPv4
• RFC2463, RFC4443 ICMPv6
• RFC4884 Extended ICMP to Support Multi-Part Messages
• RFC826 ARP
• RFC1338, RFC1519 CIDR
• RFC2474, RFC3168, RFC3260 Definition of the DS Field in the IPv4 and IPv6 headers
• RFC2571 SNMP Framework
• RFC1886 DNS extension support for IPv6
• RFC1981 Path MTU Discovery for IPv6
• RFC2460 IPv6
• RFC2461, RFC4861 Neighbor Discovery for IPv6
• RFC2462, RFC4862 IPv6 Stateless Address Autoconfiguration (SLAAC)
• RFC3513, RFC4291 IPv6 Addressing Architecture
• RFC2893, RFC4213 IPv4/IPv6 dual stack function
• RFC2068, RFC2616
• RFC2866 RADIUS Accounting
• RFC2574 User-based Security Model for SNMPv3
• RFC854 Telnet
• RFC2131 DHCP Client
Physical Parameters
Power Input
• 48-55 V DC / 5.2 A terminal block dual input
Power Consumption
• Maximum: 251.67 W (PoE on) / 14.1 W (PoE off)
• Standby: 6.5 W
Heat Dissipation
• 251.57 W (858.9 BTU/hr)
MTBF
• > 200,000 hours
Acoustic
• 0 dB
Ventilation
• Fanless
Surge Protection
• Built-in 6 KV surge protection on copper ports
Dimensions
• 107 x 44 x 164 mm
Weight
• 0.88 kg
Temperature
• Operating: -40° to 75°C
• Storage: -40° to 85°C
Humidity
• Operating: 5% to 95% non-condensing
• Storage: 5% to 95% non-condensing
Safety
• cUL
• CB
• CE
• BSMI
EMI
• CE Class A
• VCCI Class A
• FCC Class A
• IC
• BSMI
• RCM
*Not included.
Çözümler
Sipariş Bilgisi
DIS-210G-12UP/A1A
