DPS-PWR1200ACYeni
1200 W AC Power Supply with a Fan for the DXS-3130-28P Switch
Tanımlama
DPS-PWR1200AC is a 1200 W AC Power Supply with a fan for the DXS-3130-28P Switch.
Genel Özellikler
Hardware
Max. Output Power
• 1200 W
Rated Input Voltage Range
• 100~240 V AC
Input Voltage Range
• 90~264 V AC
Input Frequency Range
• 47~63 Hz
Output Voltage
• 54.5 V DC
Max. Input Current
• 15 A @ 115 V AC
• 8 A @ 230 V AC
Max. Output Current
• 22 A @ 54.5 V DC
Max. Inrush Current
• 15 A @ 115 V AC
• 30 A @ 230 V AC
Efficiency
• 91% @ 230 V AC
Physical Parameters
Dimensions (L x W x H)
• 185 х 73.5 х 40 mm
Operational Conditions
MTBF (hours)
• 202 562
Temperature
• Operating: 0 to 50 °C
• Storage: -20 to 80 °C
Humidity
• Operating: 20 to 80% non-condensing
• Storage: 10 to 90% non-condensing
Compatible Equipment
• DXS-3130-28P Switch
Çözümler
Sipariş Bilgisi
DPS-PWR1200AC
AC Power Supply with a Fan for the DXS-3130-28P Switch, 1200 W
