DGS-1210-52X/MEYeni
Managed Switch with 48 x GE PoE Ports and 4 x 10G SFP+ Ports
Tanımlama
The DGS-1210-52X/ME Metro Ethernet Switch is designed for Metro Ethernet applications. It features 48 x GE PoE ports and 4 x 10G SFP+ ports forincreased network bandwidth. Surge protection, advanced Layer 2 functions, and a suite of security and management tools make the DGS-1210-52X/ME Metro Ethernet Switch ideal for Metro Ethernet applications.
Efficient and Resilient
For mission critical environments, the DGS-1210-52X/ME supports IEEE 802.1D 2004 edition, 802.1w, and 802.1s Spanning Tree Protocols (STP). The Spanning Tree Protocol allows the switches to participate in Spanning Tree topology, providing an alternative Layer 2 path in the event of a network failover. The switch also supports IEEE 802.3ad link aggregation, which enables multiple ports to be grouped to form a single virtual port, increasing bandwidth and redundancy for higher availability. Furthermore, it features IEEE 802.1p Quality of Service (QoS), allowing for real-time traffic classification into Weighted Round Robin (WRR) and strict priority levels mapped to 8 queues. Advanced traffic classification parameters allow the network to be tuned for flexible configurations for specific multimedia applications such as VoIP or IPTV.
Security and Authentication
The DGS-1210-52X/ME supports IEEE 802.1X port-based/host-based access control, guest VLAN, and RADIUS/TACACS+ authentication for strict access control to the network. The IP-MAC-Port Binding (IMPB) feature allows administrators to associate a source IP address with a designated MAC address and also offers the flexibility to define the port number to enhance user access control. The built-in D-Link Safeguard Engine™ protects the CPU from broadcast, multicast, and unicast flooding by automatically trapping packets and logging events in these situations. In addition, the Access Control List (ACL) feature enhances network security and switch performance.
Management Capabilities
A user-friendly web interface gives administrators access to advanced management features such as DHCP auto-configuration. This enables switch to load its configuration from a TFTP server once it has been assigned an IP address, allowing central management of device configurations. The switch supports Link Layer Discovery Protocol (LLDP), which advertises the device’s capabilities and identity to the local network, allowing administrators to better manage their network topology. Each port also supports cable diagnostics, which can be used to troubleshoot cable length and functionality problems remotely, resulting in lower management overheads.
Traffic and Bandwidth Control
Integrated bandwidth control allows network administrators to define the throughput levels for ingress and egress bandwidth. It provides a minimum granularity of 64 Kbps for ingress port and flow-based bandwidth control, and a minimum granularity of 64 Kbps for egress queue bandwidth. The DGS-1210-52X/ME also supports traffic control, which optimizes performance by dropping
packets when exceeding a set threshold, while port mirroring helps administrators facilitate traffic diagnostics and track network performance. The DGS-1210-52X/ME also provides IGMP snooping
with IGMP authentication to prune multicast traffic and to optimize available bandwidth.
Multicast Applications
The DGS-1210-52X/ME features a full set of L2 multicast functions, including IGMP snooping, IGMP filtering, fast leave, and multicast traffic configuration for specific ports. With L2 multicast  support, the DGS-1210-52X/ME is ready and capable of handling growing IPTV applications. Host-based IGMP/MLD snooping allows for multiple multicast subscribers per physical interface, and ISM VLAN sends multicast streams in a multicast VLAN, saving bandwidth on the backbone. Additionally, ISM VLAN profiles allow users to bind or replace the predefined multicast registration information to subscriber ports quickly and easily.
Genel Özellikler
Hardware Version
• C1
Interface
• 48 x GE PoE ports
• 4 x 10G SFP+ ports
• RJ-45 console port
Size
• 19-inch standard rack-mount width
• 1U height
Port Standards/Functions
• IEEE 802.3 10BASE-T Ethernet
• IEEE 802.3u 100BASE-TX Fast Ethernet
• IEEE 802.3ab 1000BASE-T Gigabit Ethernet
• IEEE 802.3ae 10G Ethernet
• IEEE 802.3x Flow Control for fullduplex mode, auto-negotiation
Half/Full Duplex
• Half/full-duplex for 10/100 Mbps and full-duplex for 1000 Mbps speeds (Applicable only to copper ports)
Media Interface Exchange
• Auto or configurable MDI/MDIX (Applicable only to copper ports)
Performance
Switching Capacity
• 176 Gbps
Forwarding Method
• Store-and-forward
MAC Address Table Size
• 16 K entries
MAC Address Update
• Up to 256 static MAC entries
64-Byte Max Forwarding Rate
• 130.94 Mpps
DRAM Size
• 1 GB DDR4
Flash
• 128 MB
Packet Buffer
• 1.5 MB
Optional RPS
• DPS-200A, DPS-500A/DC
LEDs
• Power (per device)
• Console (per device)
• Link/Active/Speed (per port)
• Fan Error
Software
L2 Features
• MAC Address Table: 16K
• Flow Control
  - 802.3x
  - HOL Blocking Prevention
• Link Aggregation
  - 802.1AX
  - 802.3ad
  - Supports max 8 groups per device/8 ports per group
• Spanning Tree Protocol
  - 802.1D STP
  - 802.1w RSTP
  - 802.1s MSTP
  - BPDU Filtering
  - Root Guard (Restriction)
  - Loop Guard
• Loopback Detection
• Port Mirroring
  - Support One-to-One, Many-to-One, Flow-based (ACL) mirroring for ingress traffic
  - Supports 1 mirroring group
  - Supports Mirroring for both Tx/Rx
• Flow mirroring
  - Supports Mirroring for Rx
• VLAN Mirroring
• RSPAN
• L2 Protocol Tunneling
L2 Multicasting
• IGMP Snooping
  - IGMP v1/v2/v3
  - IGMP v3 awareness
  - IGMP Authentication
  - Support 1024 groups
  - VLAN/host-based IGMP Snooping Fast Leave
  - Report Suppression
  - IGMP Snooping Querier
  - Data Driven Learning
• MLD Snooping
  - MLD v1/v2
  - MLD v2 awareness
  - Port-based MLD Snooping Fast Leave
  - MLD Snooping Querier
VLAN
• 802.1Q Tagged VLAN
• VLAN group:
  - Max. 4094 VLAN groups
• Port-based VLAN
• GVRP
  - Max. 256 Dynamic VLAN Groups
• Auto Surveillance VLAN
• 802.1v Protocol VLAN
• Voice VLAN
• MAC-based VLAN
• Multicast VLAN (ISM VLAN for IPv4/IPv6)
• Asymmetric VLAN
• Private VLAN
• VLAN Trunking
• Port-based Q-in-Q
• Q-in-Q Selective
• 8 queues per port
• Queue Handling
  - Strict Priority
  - Weighted Round Robin (WRR)
• CoS based on:
  - Switch port
  - 802.1p priority queues
  - VLAN ID
  - MAC address
  - IPv4/IPv6 address
  - DSCP
  - ToS
  - Protocol type
  - TCP/UDP port
  - IPv6 traffic class
• Bandwidth Control
  - Port-based (Ingress, Min. Granularity 64 Kbps)
   - Flow-based (Ingress, Min. Granularity 64 Kbps)
   - Egress queue bandwidth control (Min. Granularity 64 Kbps)
L3 Features
• ARP
  - Max. 768 ARP entries
  - Supports 768 static ARP entries
• Gratuitous ARP
• IP Interfaces: 4
• Default Route
• Static route
  - Supports 64 IPv4 static routes
  - Supports 32 IPv6 static routes
• ACL based on
  - MAC address
  - IPv4/IPv6 address
  - Protocol type
  - TCP/UDP port number
• Up to 768 ingress access rules
• Time-based ACL
• CPU interface filtering
Security
• Port Security
  - Up to 64 MAC addresses per port
• Broadcast/multicast/unicast storm control
• D-Link Safeguard Engine
• DHCP Server Screening
• IP Source Guard
• DHCP Snooping
• IPv6 ND Snooping
• IP-MAC-Port Binding (IMPB)
  - ND Snooping IPv6
  - ARP inspection
  - IP inspection
  - IPv6 DHCP snooping
• Traffic segmentation
• SSL
  - Supports v1/v2/v3
  - Supports TLS 1.0/1.1/1.2/1.3
  - Supports IPv4/IPv6 access
• SSH
  - Supports SSH v2
• DHCP client filtering
• BPDU attack protection
• DoS attack prevention
• Duplicate Address Detection (DAD)
OAM
• 802.3ah Ethernet Link OAM
• D-Link Unidirectional Link Detection (DULD)
• Dying Gasp
• Y.1731 OAM
• Cable diagnostics
• Digital Diagnosics Monitoring (DDM)
AAA
• 802.1X:
  - Supports port/host-based access control
  - Identity-driven Policy Assignment
  - Supports local/RADIUS database
  - Supports EAP, OTP, TLS, TTLS, PEAP
• Guest VLAN
• Support MD5 authentication
• Trusted Host
• RADIUS/TACACS+ Accounting
• User account privilege (4 level user access)
• Web-based Access Control (WAC)
  - Host-based Access Control
  - Identity Driven WAC policy assignment
  - Dynamic VLAN Assignment
  - Bandwidth Control Assignment
  - ACL Assignment
• RAIDUS and TACACS+ Authentication
• Microsoft® NAP
  - Support 802.1X NAP
  - Support DHCP NAP
• MAC-based Access Control (MAC)
  - Host-based access control
  - ACL Assignment
Management
• Web-based GUI
  - Support IPv4/IPv6 access
  - Support SSL (HTTPS)
• Command Line Interface (CLI)
• Telnet Server for IPv4/IPv6
• Telnet Client for IPv4/IPv6
• TFTP Client for IPv4/IPv6
• DNS Client for IPv4/IPv6
• FTP Client for IPv4/IPv6
• SNMP
  - Support v1/v2c/v3
• SNMP Traps
• System Log for IPv4/IPv6 Syslog Server
• sFlow
• RMON v1
• RMON v2:
  - Supports Probe Config group
• LLDP/LLDP-MED
• BootP/DHCP client
• DHCP Auto-configuration
• DHCP/DHCPv6 Local Relay
• DHCP Relay Option 12/58/59/77/82
• DHCP auto-image
• PPPoE Circuit-ID insertion
• D-Link Discover Protocol (DDP)
• SNTP
• Password recovery
• Password encryption
• Command Logging
• SMTP
• DHCPv6 Prefix Delegation (PD)
• Ping/Traceroute for IPv4/IPv6
• Zero Touch Provisioning (ZTP)
Green Features
• IEEE 802.3az Energy Efficient Ethernet (EEE)
• Power Saving by:
  - Link Status
  - LED Shutoff
  - Port Shutoff
  - System Hibernation
MIB Standards
• RFC1065, RFC1155, RFC2578 MIB Structure
• RFC1213 MIBII
• RFC1493 Bridge MIB
• RFC1157, RFC2573, RFC2575, RFC2576 SNMP MIB
• RFC3418 SNMPv2 MIB
• RFC2819 RMON MIB
• RFC2021 RMONv2 MIB
• RFC1643, RFC1650, RFC2665, Ether-like MIB
• RFC2674 802.1p MIB
• RFC2233 Interface Group MIB
• RFC4022 MIB for TCP
• RFC4113 MIB for UDP
• RFC2389 MIB for Diffserv.
• RFC2925 Ping & TRACEROUTE MIB
• TFTP uploads and downloads (D-Link MIB)
• Trap MIB (D-Link MIB)
• DDM MIB (D-Link MIB)
• Private MIB
• RFC3621 Power Ethernet MIB
• DDP MIB
• LLDP-MED MIB
IETF Standards
• RFC768 UDP
• RFC791 IP
• RFC793 TCP
• RFC792 ICMPv4
• RFC2463, RFC4443 ICMPv6
• RFC826 ARP
• RFC1338, RFC1519 CIDR
• RFC2474, RFC3168, RFC3260 Definition of the DS Field in the IPv4 and IPv6 Headers
• RFC1321, RFC2284, RFC2865, RFC2716, RFC3580 Extensible Authentication Protocol (EAP)
• RFC2573, SNMP Applications
• RFC2574 User-based Security Model for SNMPv3
IPv6
• RFC1981 Path MTU Discovery
• RFC2460 IPv6
• RFC2461, RFC4861 Neighbor Discovery for IPv6
• RFC2462, RFC4862 IPv6 Stateless Address Auto-configuration (SLAAC)
• RFC3513, RFC4291 IPv6 Addressing Architecture
• RFC2893, RFC4213 IPv4/IPv6 dual stack function
Physical/Environmental
MTBF
• 450,166.57 hours
Acoustic
• High Speed 43.6 dB(A)
• Low Speed 40.8 dB(A)
Heat Dissipation
• 119.92 BTU/hr
Power Input
• AC Input: 100 to 240 V AC, 50/60 Hz
Max Power Consumption
• 35.04 W/100 V
• 34.38 W/240 V
Standby Power Consumption
• 14.39 W/100 V
• 14.15 W/240 V
Dimensions
• 440 x 250 x 44 mm
Ventilation
• 1 x Smart fan
Weight
• 3.50 kg
Power Surge Protection
• IEC 61000-4-5 surge protection on all Gigabit Ethernet ports
Operating Temperature
• 0 to 50 °C (23 to 122 °F)
Storage Temperature
• -25 to 70 °C (-40 to 158 °F)
Operating Humidity
• 10% to 90% non-condensing
Storage Humidity
• 5% to 90% non-condensing
EMI
• CE, FCC, IC, RCM, VCCI
Safety Certifications
• CB, UL, LVD
Çözümler
Sipariş Bilgisi
DGS-1210-52X/ME  48 Ports GE + 4 Ports 10G SFP+ Managed Switch
Optional SFP Transceivers
DEM-310GT  1000BASE-LX, Single-mode, 10 km
DEM-311GT  1000BASE-SX, Multi-mode, 500 m
DEM-314GT  1000BASE-LHX, Single-mode, 50 km
DGS-712  1000BASE-T 100 m (only supports 1000 Mbps mode - no flow control)
Optional WDM SFP Transceiver
DEM-330T  1000BASE-LX, Single-mode, 10 km, Tx: 1550, Rx: 1310 nm
DEM-330R  1000BASE-LX, Single-mode, 10 km, Tx: 1310, Rx: 1550 nm
Optional SFP+ Transceivers
DEM-431XT 10GBASE-SR SFP+ Transceiver, 33 m: OM1 MMF, 82 m: OM2 MMF, 300 m: OM3 MMF
DEM-432XT   10GBASE-LR SFP+ Transceiver, 10 km
DEM-433XT   10GBASE-ER SFP+ Transceiver, 40 km
DEM-434XT  10GBASE-ZR SFP+ Transceiver, 80 km
DEM-436XT-BXD  10GBASE-LR BiDi SFP+ Transceiver, Tx: 1330 nm, Rx: 1270 nm, 20 km
DEM-436XT-BXU  10GBASE-LR BiDi SFP+ Transceiver, Tx 1270 nm, Rx: 1330 nm, 20 km
Optional SFP+ Direct Attach Stacking Cables
DEM-CB100S  10-GE SFP+ 1 m Direct Attach Cable
DEM-CB300S   10-GE SFP+ 3 m Direct Attach Cable
DEM-CB700S   10-GE SFP+ 7 m Direct Attach Cable
Görseller
DGS-1210-52X/ME/C1
Front view
View from the right
Left side view
Back view
Top view
İndir
Destek Merkezi
