DES-1008C-CN
8-Port 10/100 Mbps Unmanaged Switch
Tanımlama
The DES-1008C-CN 10/100 Mbps Unmanaged Switch is economical, plug-and-play networking switch solutions for SOHO and small and medium businesses wanting to benefit from the increased bandwidth of Fast Ethernet. It provides 8 10/100 Mbps ports that enable you to easily expand your network and provide a quick way to upgrade your network to fast connectivity.
Upgrade to Gigabit Networking
With data transfer speeds of up to 200 Mbps at full duplex, this switch is ideal for quick file transfers, online gaming and smooth streaming media. It features easy-to-access Ethernet ports with LED indicators per port to easily distinguish link status. Auto MDI/MDIX crossover makes connection a cinch; just plug in your cables and you're ready to go.
Conserve Energy
The DES-1008C-CN implements 802.3az Energy Efficient Ethernet, which saves energy and reduces heat automatically without sacrificing performance or functionality. The switch can detect when a connected computer is shut down or when there is no Ethernet traffic, and will put the port in standby mode, saving a substantial amount of power. In addition, the switch optimizes power usage for each port for the length of cable connected to it, using only as much power as is required. Both of these features work together to help you save power automatically.
Reliable Plug and Play Installation
The DES-1008C-CN is Plug-and-Play device that requires no configuration, so setup is simple and hassle-free, and you can easily connect multiple computers, share files, music, and video across your home or small office network, or even create a multiplayer gaming environment. 802.3x flow control on each port minimizes dropped packets when the port's receiving buffer is full, giving you a more reliable connection for all of your connected devices.
Genel Özellikler
Interfaces
• 8 x 10/100 Mbps LAN ports
LEDs
• Power (per device)
• Link/Activity (per port)
Port Standards & Functions
• IEEE 802.3 10BASE-T
• IEEE 802.3u 100BASE-TX
• IEEE 802.3x Flow Control
• Auto MDI/MDIX crossover for all ports
Data Transfer Rates
• Ethernet:
• 10 Mbps (half duplex)
• 20 Mbps (full duplex)
• Fast Ethernet:
• 100 Mbps (half duplex)
• 200 Mbps (full duplex)
Performance
Switching Capacity
• 1.6 Gbps
Transmission Method
• Store-and-forward
MAC Address Table
• 1K entries
Packet Filtering/Forwarding Rates
• Ethernet: 14,880 pps per port
• Fast Ethernet: 148,800 pps per port
Physical Parameters
Dimensions (L x W x H)
• 128 x 71 x 27 mm
Weight
• 180 g
Power Input
• DC 5 V / 0.55 A
• DC jack: Located on side
Surge Protection
• up to 2kV in common mode
• up to 1kV in differential mode
Maximum Power Consumption
• 2.15 W
Temperature
• Operating: 0 to 40 C
• Storage: -40 to 70 C
Humidity
• Operating: 10% to 90% (Non-condensing)
• Storage: 5% to 95% (Non-condensing)
Certifications
• CCC
Çözümler
Sipariş Bilgisi
DES-1008C-CN
Görseller
DES-1008C-CN/
Front view
View from the right
Back view
İndir
Destek Merkezi
