DMS-106XT
6-Port Multi-Gigabit Configurable Switch with DIP Switch
Tanımlama
The DMS-106XT 6-Port Multi-Gigabit Configurable Switch is equipped with five 100/1000/2.5GBase-T ports (for unrestricted Wi-Fi 6 router or AP connections), one 100/1000/2.5G/5G/10GBase-T port (for NAS or uplink connectivity) and a DIP switch with configuration capability. With a durable design, silent operation, and plug-and-play functionality, the DMS-106XT switch can be easily set up and be placed in almost any location where network connectivity is required.
TURBO Mode
Turn on TURBO mode to enable low latency and multicast function to make your network efficient for multi-media application (e.g. gaming, video streaming or file download, etc). The port-based QoS will be activated as well when TURBO mode is on.
Integrated Networking
The DMS-106XT switch uses auto-sensing ports, providing a small workgroup to flexibly connect Ethernet, Fast Ethernet, Gigabit, 2.5 Gigabit, 5 Gigabit and 10 Gigabit devices to create an integrated network. These ports detect the network speed via auto-negotiation allowing you to get the maximum speed possible for each device connected to your network.
Simplified Installation
All of the ports on the DMS-106XT switch supports automatic MDI/MDIX crossover, eliminating the need for crossover cables. Each port can be plugged in directly to a server, hub, router, or switch using regular straight-through twisted-pair Ethernet cables.
Green Technology
The DMS-106XT switch features green technology, such as IEEE 802.3az Energy-Efficient Ethernet (EEE)*.
Traffic Management
The DMS-106XT switch includes traffic management features, such as IEEE 802.1p Quality of Service (QoS) and IEEE 802.3x Flow Control.
Genel Özellikler
Interfaces
• 4 x 10/100/1000/2.5GBase-T ports
• 1 x 100/1000/2.5GBase-T port
• 1 x 100/1000/2.5G/5G/10GBase-T port
Standards
• IEEE 802.3 10Base-T
• IEEE 802.3u 100Base-TX
• IEEE 802.3ab 1000Base-T
• IEEE 802.3bz 2.5GBase-T
• IEEE 802.3bz 5GBase-T
• IEEE 802.3an 10GBase-T
• IEEE 802.3az Energy-Efficient Ethernet (EEE)*
• IEEE 802.3x Flow Control
• Auto-MDI/MDIX adjustment on all ports
• Port-based QoS**
• IGMP Snooping***
Diagnostic LEDs
• Power/Turbo
• Link/Activity/Speed (per port)
Switching Capacity
• 45 Gbps switching fabric
Transmission Method
• Store-and-forward
Packet Filtering / Forwarding Rates
• 18.6 Mpps
MAC Address Table
• 4K entries
Jumbo Frame Size
• 9,728 byte
Packet Buffer
• 1 MB
Physical Parameters
Dimensions
• 217 x 163 x 33 mm
Weight
• 0.68 kg
DC Input
• External 12 V / 1.5 A power adapter
Maximum Power Consumption
• 10.6 W
MTBF
• 489,941 hours
Heat Dissipation
• 10.59 W (36.17 BTU/hr)
Ventilation System
• Fanless
Temperature
• Operating: 0° to 40°C
• Storage: -10° to 70°C
Humidity
• Operating: 10 to 95% non-condensing
• Storage: 5% to 95% non-condensing
EMI
• CE
• FCC
• RCM
• BSMI
• VCCI
• RoHS
* EEE will be disabled when TURBO mode ON.
** Supports port priority based on port number when TURBO mode enabled.
*** Supports IGMP snooping v1/v2/v3 (except source IP filter) when TURBO mode enabled.
Çözümler
Sipariş Bilgisi
DMS-106XT
