DIS-200G-12PSProje
Industrial Layer 2 switch with 10 10/100 / 1000Base-T ports and 2 1000Base-X SFP ports (8 ports with PoE support 802.3af / 802.3at (30W), PoE budget up to 240W)
Nereden AlınırTanımlama
The DIS-200G-12PS managed switch, equipped with 10 10/100 / 1000Base-T ports (8 ports support Power over Ethernet (PoE)), and 2 1000Base-X SFP ports used to connect to a high-speed backbone, is designed for applications in the networks of industrial enterprises. The DIS-200G-12PS supports D-Link Green technology and advanced management and security features. Management functions include SNMP, Web-based management, D-Link Network Assistant and the command-line interface (CLI).
Reliable design
The metal case (IP30 standard) and a wide operating temperature range allow the DIS-200G-12PS to be used in adverse environmental conditions. A high level of electromagnetic compatibility ensures the stability of the switch to the effects of strong electromagnetic interference, and the passive cooling system - the noiseless operation of the switch. This device can be mounted on a wall, mounted on a DIN rail or in a 19-inch rack using the appropriate brackets (rack mounts are not included in the scope of delivery).
Protection against static electricity of 6 kV ensures the stability of copper ports to the induced voltage and prevents damage to the switch and the devices connected to it.
Reliability and fault tolerance
The DIS-200G-12PS supports Ethernet Ring Protection Switching (ERPS 1 , ITU-T G.8032), which provides a minimum recovery time for the ring after a failure. To ensure maximum resiliency in the switch, a dual redundancy scheme is implemented: up to two independent DC 2 power supplies can be connected to the DIS-200G-12PS , and a connector for connecting the AC 2 power adapter .
Auto Surveillance VLAN
The DIS-200G-12PS supports Auto Surveillance VLAN (ASV), which makes it an ideal solution for deploying video surveillance systems. This functionality allows you to automatically recognize in the general network of video surveillance equipment and allocate it to a separate VLAN within which the highest priority of service will be assigned for video traffic. Support for Auto Surveillance VLAN ensures stable operation of video applications, high-quality transmission and maximum protection of multimedia traffic, regardless of the overall network load.
Simple Troubleshooting
The DIS-200G-12PS supports cable diagnostics and Loopback Detection, which allows network administrators to quickly and easily find and fix network problems. Loopback Detection is used to detect loops and automatically turn off the port on which the loop is detected. The cable diagnosis function is used to determine the status of the twisted pair, as well as the type of cable fault.
Power over Ethernet
The 8 ports of this switch support the IEEE 802.3at PoE standard. At the same time, the total budget of the switch can reach 240 W depending on the power of the connected power source. So, when you connect a 180 W power adapter to the DIS-PWR180AC, the PoE budget is 140 watts, and if you connect a more powerful power source such as 300 watts, the PoE budget can reach 240 watts, that is, 30 watts per port. The special indicators on the front panel of the device help control the activated PoE budget.
Genel Özellikler
Fiziksel Özellikler
Hardware
CPU
• Vitesse VSC7425 (416 MHz)
• Microsemi PD69208M + PD69200 (PoE)
RAM
• 128 MB
Flash Memory
• 32 MB
Interfaces
• 10 10/100 / 1000Base-T ports (8 ports with PoE support)
• 2 ports of 1000Base-X SFP
• Console port with RJ-45 connector
• Relay output 1 A / 24 V for power failure notification
Indicators
• PWR 1/2/3
• ALM
• SYS
• Link / Activity / Speed (per port)
• PoE status
• Power budget PoE
Buttons
• Reset button
Power connector
• DC: terminal block for connecting up to two independent power supplies 1
(46 V to 54 V DC) • AC: 4 pin power mini-DIN PD-40VS (for connecting the power adapter 1 with the PDP-40 plug)
Housing
• Metal housing (IP30 standard)
Functional
Standards and functions
• IEEE 802.3 10Base-T (copper twisted pair)
• IEEE 802.3u 100Base-TX (copper twisted pair)
• IEEE 802.3ab 1000Base-T (copper twisted pair)
• IEEE 802.3z 1000Base-X
• IEEE 802.3x Flow Control
• Automatic detection of MDI / MDIX on all copper ports
Performance
Switching matrix
• 24 Gb / s
Switching Method
• Store-and-forward
MAC address table size
• 8K entries
Max. the speed of redirection of 64-byte packets
• 17.85 Mpps
Package Buffer
• 4 MB
Jumbo frame
• 9,216 bytes
Software
Layer 2 functions
• Flow control
- 802.3x
- Preventing HOL locks
• IGMP Snooping
- IGMP v1 / v2
- IGMP v3 2
- Support for 64 groups
- IGMP Snooping Querier
• MLD Snooping
- MLD v1
- MLD v2 2
- MLD Snooping Querier
• Link aggregation
- 802.3ad
- Max. 6 groups per device / 8 ports per group
• Support for Ethernet Ring Protection Switching (ERPS 2 , ITU-T G.8032)
• Loopback Detection
• LLDP
• Port mirroring
- Support for 1 group of mirroring
- Modes: One-to-One, Many-to-One
• Statistics
- Tx Ok
- Tx Error
- Rx Ok
- Rx Error
• Spanning Tree Protocol
- 802.1D STP
- 802.1w RSTP
- 802.1s MSTP 2
VLAN
• 802.1Q Tagged VLAN
• Port-based VLANs
• Auto Surveillance VLAN 2.0 (ASV2.0) 2
• Voice VLAN
• Asymmetric VLAN
• VLAN Groups
- 128 VLAN groups
- Max. 4094 VLANs
• GVRP 2
Quality of Service (QoS)
• CoS based on:
- Switch Ports
- 802.1p priority queues
- ToS
- IP Precedence
• Bandwidth management
- Based on the port (incoming, with a minimum step of up to 64 Kbps)
• Queue processing
- Strict Priority
- Weighted Round Robin (WRR)
• 4 queues per port
AAA
• Web-based access control (WAC) 2
• 802.1X authentication 2
• RADIUS 2
Security
• D-Link Safeguard Engine
• Segmentation of traffic
• Broadcast / Multicast / Unicast Storm Protection
• Preventing DoS attacks
• SSL
• Port Security
OAM
• Cable Diagnostics
• Dying Gasp 2
• DDM digital monitoring function (Digital Diagnosics Monitoring) 2
Control
• Web interface (support for IPv4 / IPv6)
• D-Link Network Assistant (DNA)
• Command line interface (CLI)
• SNTP
• SNMP v1 / v2c
• SNMP v3 2
• SNMP Trap
• Telnet server
• System log
• DHCP client
• TFTP client
• LLDP
• D-Link Discovery Protocol (DDP)
• Support for multiple software versions
• Support for multiple versions of configurations
Technology Green
• Energy saving due to:
- Connection Status Definitions
- Turn off indicators
- Turn off the ports
- Using sleep mode
MIB / RFC
• RFC768 UDP
• RFC791 IP
• RFC792 ICMP
• RFC793 TCP
• RFC826 ARP
• RFC1213 MIB II
• RFC1493 Bridage MIB
• RFC1907 SNMPv2 MIB
• RFC2668 802.3 MAU MIB
• RFC4133 Entity MIB
• RFC4363 IEEE 802.1p MIB
• ZoneDefense MIB
• Private MIB
PoE
PoE standard
• IEEE 802.3af
• IEEE 802.3at
Ports with PoE support
• Ports 1-8
PoE Power Budget
• Up to 240W (when the 180W PWR180AC power adapter is connected, the PoE budget is 140W, and if you connect a more powerful power source such as 300W, the PoE budget can reach 240W, max 30W per PoE)
Physical parameters
Dimensions (L x W x H)
• 210 x 171.2 x 48 mm
The weight
• 2.5 kg
terms of Use
Food
• 46-54 V DC (with the ability to connect up to two power supplies (not included in the scope of delivery))
• Power adapter (not included):
- Input: 100-240 V AC, 2.5 A, 50/60 Hz
- Output: 54 V, 3.34 A
Noise level
• 0 dB
• Support of static electricity protection on copper ports (IEC61000-4-5 standard)
Ventilation system
• Passive
Temperature
• Operating: -40 to 65 ° C
• Storage: -40 to 85 ° C
Humidity
• Operating: 0% to 95% non-condensing
• When stored: 0% to 95% non-condensing
Contents of delivery
• Switch DIS-200G-12PS
• Console cable with RJ-45 connector
• Wall mounting kit
• DIN rail mounting kit
• Quick Installation Guide
• CD
Other
EMI
• CE
• FCC
• BSMI
• C-Tick
Security
• UL
