DGS-1510-52L/MEEOL EOS
Tanımlama
Genel Özellikler
Fiziksel Özellikler
Hardware |
Interfaces |
• 48 ports 10/1001000Base-T • 4 ports 1000Base-X SFP • Auto MDI/MDIX |
Indicators |
• Power (per device) • Redundant Power Supply (RPS) (per device) • Console (per device) • Link/Activity/Speed (per port) |
Conseole Port |
• RJ-45 |
Network Cables |
• UTP category 5, 5e cable (maximum 100m); EIA/TIA-568 100-Ohm STP (100 m max.) |
Performance |
Switch Fabric |
•104 Gbps |
The maximum transmission speed of packets |
• 104 Mpps |
Transmission method |
• Store-and-forward |
The MAC address table |
• 16K entries |
Update MAC addresses |
up To 512 static entries of MAC addresses |
Buffer |
• 1,5 МB |
Flash memory |
• 32 МB |
Software |
Standards and functions |
• IEEE802.3 • IEEE802.3u • IEEE802.3ab • IEEE802.3az • IEEE802.3z • Управление потоком IEEE 802.3x |
Stacking |
Virtual stacking - D-Link Single IP Management - Up to 32 devices, United in a virtual stack |
Layer 2 features |
Standards and functions • IEEE802.3 • IEEE802.3u • IEEE802.3ab • IEEE802.3az • IEEE802.3z • Flow control IEEE 802.3 x Stacking • Virtual stacking - D-Link Single IP Management - Up to 32 devices, United in a virtual stack Layer 2 features • table MAC-addresses: 16K • Flow control - Flow control 802.3 x - HOL blocking prevention - Back pressure • Jumbo-size frames up to 9K • Spanning Tree Protocols - 802.1 D STP - 802.1 w RSTP - 802.1 s MSTP - BPDU filtering - Root Restriction • Detection loops Loopback detection • Link aggregation - Compatible with 802.1 AX and 802.3 ad • Port mirroring - Support group 1 mirroring - Modes: One-to-One, Many-to-One, Flow-based (ACL) • Ethernet Ring Protection Switching (ERPS) • L2 Protocol Tunneling (L2PT) |
Multicast layer 2 |
• IGMP Snooping - IGMP v1/v2 Snooping, v3 awareness - Support for 1024 groups - IGMP Snooping Fast Leave port-based/host - Report Suppression Authentication IGMP - Filtering IGMP • MLD Snooping - MLD v1, MLD v2 awareness - Support for 1024 groups - MLD snooping Fast Leave port-based/host |
VLAN |
• Group VLAN - Max. 4094 VLAN VLAN port-based VLAN based on MAC addresses • 802.1 Q Tagged VLAN • GVRP - Max. 255 dynamic VLAN • 802.1 v Protocol VLAN • 802.1 Q Tagged VLAN • Double VLAN (Q-in-Q) - Q-in-Q port-based • ISM VLAN • VLAN Translation • VLAN Trunking |
Functions of level 3 |
• Max. 1024 ARP entries - Supports 255 static ARP entries • Supports Gratuitous ARP • IPv6 Neighbor Discovery (ND) • 16 IP interfaces • A default route • Static маршрут1 - Support 64 static routes IPv4 - Support for 32 static routes IPv6 |
Quality of service (QoS) |
• CoS based on: - Switch port - Priority queue for 802.1 p - VLAN ID - MAC addresses - Ether Type - IPv4/IPv6 addresses - DSCP - ToS - Protocol type - TCP/UDP port - Class of IPv6 traffic - IPv6 flow label - Content package, user-defined • Bandwidth management - Port-based (incoming, in increments up to 64 Kbit/s) Based on the flow (incoming, in increments up to 64 Kbit/s) - For output queue (in increments up to 64 Kbit/s) • Processing queues - Strict Priority Queue (SPQ) - Weighted Round Robin (WRR) • QoS on a schedule • Three color marker - CIR/PIR min. step up to 8 Kbit/s - Two Rate Three Color Marker (trTCM), CBS/PBS - Single Rate Three Color Marker (srTCM), CBS/EBS • 8 output queues |
The access control lists (ACL) |
• ACL on the basis of - Switch port - The 802.1 p priority - VLAN ID - MAC addresses - Ether type - IPv4/v6-address - Class of IPv6 traffic - IPv6 flow label - DSCP - ToS - Protocol type - Port number TCP/UDP - Content package, user-defined • Up to 1024 access rules for inbound traffic • ACL schedule • Statistics ACL • Filtering CPU interface |
AAA |
• 802.1 X - Access control port-based - Access control host-based - Dynamic VLAN assignment • Access control based on MAC addresses - Access control host-based - Access control port-based - Dynamic VLAN assignment • Microsoft® NAP (IPv4) • Guest VLAN • RADIUS (IPv4) • TACACS (IPv4) • TACACS+ (for IPv4) • XTACACS+ (IPv4) • Trusted Host • Accounting RADIUS • 4 level user account |
Security |
• SSH v1/v2 • SSL v1/v2/v3 • Port Security - Up to 64 MAC-addresses per port • Protection from a broadcast/multicast/unicast storm • IP-MAC-Port Binding (IMPB) - Checking the ARP-packets - Checking the IP-packets - DHCP Snooping - DHCPv6 Snooping1 - DHCPv6 Guard1 - IPv6 Route Advertisement (RA) Guard1 - IPv6 ND Snooping1 - IPv6 ND Inspection1 • Segmentation of traffic • D-Link Safeguard Engine • L3 Control Packet Filtering • Filtering NetBIOS/NetBEUI • DHCP Server Screening • Filtering DHCP clients • The prevention of ARP Spoofing • Protection against attacks BPDU • Prevention of DoS attacks |
OAM |
Cable Diagnostics • 802.3 ah Ethernet Link OAM • Dying Gasp • 802.1 ag Connectivity Fault Management (CFM) |
Management |
• Web GUI (supports IPv4/IPv6) • Command line interface (CLI) • Telnet server/client (supports IPv4) • TFTP/FTP-client (support IPv4) • ZModem • Logging of input commands • IPv6 Neighbor Discovery • SNMP v1/v2c/v3 (supports IPv4) • SNMP Traps • System log - Max. number of entries in the log: 10 000 • SMTP (IPv4) • RMON v1: - Support for groups 1, 2, 3, 9 • RMON v2: - Support Probe Config group • 802.1 AB LLDP - LLDP-MED • BootP/DHCP-client (support IPv4) • Automatically configure DHCP1 • DHCP Relay (support IPv4) - DHCP Relay Option 60, 61 and 82 - DHCP Client Option 12 • Adding a tag PPPoE Circuit-ID1 • Supports multiple copies of SOFTWARE (Multiple Images) • Supports multiple copies of configuration (Multiple Configurations) • Flash file system • Monitoring CPU • Monitor memory • SNTP (IPv4) • Debugging commands • Password recovery • Password encryption • Ping • Traceroute • Microsoft® NLB (network load Balancing) (support IPv4) • Zero Touch Provisioning (ZTP)1 • sFlow1 • D-Link Network Assistant1 • Supports Real Time Clock (RTC) |
Standarts MIB |
• RFC1065, RFC1066, RFC1155, RFC1156, RFC2578 • RFC1212 • RFC1213 • RFC1215 • RFC1493, RFC4188 • RFC1157, RFC2571, RFC2572, RFC2573, RFC2574, RFC2575, RFC2576 • RFC1442, RFC1901, RFC1902, RFC1903, RFC1904, RFC1905, RFC1906, RFC1907, RFC1908, RFC2578, RFC3418, RFC3636 • RFC271, RFC1757, RFC2819 • RFC2021 • RFC1398, RFC1643, RFC1650, RFC2358, RFC2665, RFC3635 • RFC2668 • RFC2674, RFC4363 • RFC2618 • RFC4022 • RFC4113 • RFC3298 • RFC2620 • RFC2925 • RFC2465 • RFC2466 • RFC4293 • RFC3289 |
Physical parameters |
Dimensions |
• 280 x 140 x 44 mm |
Weight |
• 1,42 kg |
Conditions |
MTBF (hours) |
• 762 952 |
Heat Dissipaiton |
• 53,229 BTU/h |
Power |
100 to 240 VAC, 50~60 Hz |
Max. power consumption |
• 15,6 W |
Power consumption in standby mode |
• 9,8 W/In 100 • To 10.5 W/240 V |
Ventilation system |
• Passive |
The static protection |
• All Ethernet ports support the standard IEC61000-4-5 built-in protection against static electricity (up to 6 kV) |
Temperature |
• Operating: -5 to 50 °C • Storage: -20 to 70 °C |
Humidity |
• operating: 0% to 95% non-condensing • Storage: 0% to 95% non-condensing |
The Kit |
• DGS-1510-20L/ME • 2 mounting bracket for installation in 19-inch rack • Set of screws (8 PCs.) and rubber feet (4 PCs.) • Connector for connecting to a backup power source • Power cable • Clamp for power cable • Console cable • Quick installation guide • Setup CD-ROM • Sticker with serial number |
Other |
EMI |
• CE, FCC, C-Tick, VCCI, BSMI |
Security |
• cUL, CB |
