MTBF
484.053 h
Noise level
• 39,6 dB at low speed
• 48,4 dB at high speed
Heat release
142,88 BTU / hr
Power Input
From 100 to 240 VAC, 50-60 Hz
The maximum power consumption
44.38 W
Measurements
441 x 210 x 44 mm
Weight
2.195 kg
Ventilation
Fan
Surge protection
All Ethernet-ports support standard IEC61000-4-5 10/700us integrated surge protection 6 kV
Operating temperature
-5 To 50 ° C
Storage temperature
-40 To 70 C
Operating Humidity
From 10% to 90% (non-condensing)
Electromagnetic radiation (EMI)
FCC Class A, CE Class A, VCCI Class A, IC, C-Tick, BSMI
Safety
CE, LVD, UL / cUL, CB, BSMI
Certificates of third party
IPv6 Ready Logo Phase 2
Fiziksel Özellikler
The hardware version
C1
Size
Width for 19 "standard rack, 1U height
Interface
• 24-port SFP
combo • 4-port 10/100/1000BASE-T / 100/1000 SFP
The console port
RJ-45
Performance
• Switch fabric: 12.8 Gbit / s
• The speed forwarding 64-byte packets: 9,5 Mpps
• The size of the table MAC-addresses: 16K
• SDRAM for CPU: 128 MB DDR2
• Packet Buffer: 1.5 MB
• Flash-Memory: 32 MB
• Jumbo-frame: 12 KB
Indicators
• Power (per device)
• Console (per device)
• Link / Active / Speed (per port)
Software
Stacking
• Virtual Stacking D-Link Single IP Management
• Combining a virtual stack of up to 32 devices
Functions Level 2
• MAC Address Table: 16K
• Flow Control
- 802.3x Flow Control
- HOL blocking prevention
• Jumbo-size frame to 12K bytes
• Spanning Tree Protocols
- 802.1D STP
- 802.1w RSTP
- 802.1s MSTP
• BPDU Filtering
• Root Restriction
• Loopback Detection
• Link Aggregation
- Compatible with 802.1AX and 802.3ad
- Max. number of teams - 14, 8 ports per group
• Port Mirroring
- Support group 1 mirroring
- Modes: One-to-One, Many-to-One, Flow-based (ACL)
- Technology Ethernet Ring Protection Switching (ERPS)
- L2 Protocol Tunneling (L2PT)
Multicast Level 2
• IGMP Snooping
- IGMP v1/v2 snooping, IGMP v3 awareness
- Support for 1024 groups
- IGMP snooping Fast Leave on the basis of the port / host
- Report Suppression
• MLD Snooping
- MLD v1, MLD v2 awareness
- Support for 1 K groups
- MLD Snooping host-based
- Fast Leave
• IGMP Authentication
• IGMP / MLD Proxy Reporting
VLAN
• 802.1Q VLAN
• Group VLAN
- Max. 4K VLAN
• VLAN port-based
• VLAN for MAC-based
• GVRP
• 802.1v VLAN-based protocol
• VLAN Trunking
• Double VLAN (Q-in-Q)
- Q-in-Q Port-Based
- Q-in-Q Selective
• ISM VLAN
• VLAN Translation
• Voice VLAN
Functions 3 levels
Quality of service (QoS)
• Bandwidth Management
- Port-based (Ingress / Egress, with steps down to 8 kbit / s)
- On the basis of the flow (inbound / outbound, with steps down to 8 kbit / s)
- For output queue (in increments of up to 8 kbit / s)
• 8 queues per port
• DSCP
• 802.1p
• Processing Queues
- Strict Priority
- Weighted Round Robin (WRR)
- Strict + WRR
• Three-color labeling
- TrTCM
- SrTCM
• CoS based on:
- Switch Port
- 802.1p Priority Queues
- VLAN ID
- MAC-address
- Ether type
- TOS
- DSCP
- The type of protocol
- TCP / UDP port
- IPv6 Traffic Class
- IPv6 flow label
- The contents of the package, the user-defined
• Support for the following streams
- Set the 802.1p priority tags
- Add a tag TOS / DSCP
- Statistics of flow
Access Control Lists (ACL)
• Up to 1024 access rules
• ACL on the basis of
- Switch Port
- 802.1p Priority
- VLAN ID
- Ether type
- IPv4/IPv6-adresa
- DSCP
- Non TCP / UDP port
- IPv6 flow label
• ACL on the basis of the time
• Statistics ACL
• CPU interface filtering
Safety
• SSH v1, v2
• SSL v1, v2, v3
• Port Security
• Up to 64 MAC-addresses per port
• Protection from a broadcast / multicast / unicast storm
• Traffic Segmentation
• IP-MAC-Port Binding (IMPB)
- Checking the ARP packets
- Check the IP packet
- DHCP Snooping
• D-Link Safeguard Engine
• Protection from unauthorized DHCP servers
• Filtering DHCP clients
• Prevent ARP Spoofing
• BPDU Attack Prevention
• Filtering NetBIOS / NetBEUI
• Prevent DoS attacks
• L3 Control Packet Filtering
AAA
• 802.1X
- Access control based on port
- Based Access Control Host
- Dynamic VLAN Assignment
• Dynamic allocation policies: VLAN, ACL or QoS
• Access Control MAC-based (MAC)
• Based Access Control Web (WAC) 1
• Microsoft ® NAP (IPv4/v61)
- Support for 802.1X NAP
- Support for DHCP NAP
• Guest VLAN
• RADIUS Accounting
• RADIUS (IPv4/v61)
• TACACS
• TACACS +
• XTACACS +
• Control of trusted hosts (Trusted Host)
OAM
• Diagnostic cable
• 802.3ah Ethernet Link OAM
• Dying Gasp
• 802.3ah D-Link extension: D-Link Unidirectional Link Detection (DULD)
Green Technology
• D-Link Green 3.0: The power saving function
- Turn off the indicator 1
- Turn off the power supply port 1
- Sleep Mode 1
• Energy saving by PoE on the basis of time (in the case of models with support for PoE)
Management
• Web-interface (support for IPv4)
• Command Line Interface (CLI)
• Telnet-server/klient (support for IPv4)
• TFTP-client (IPv4)
• FTP-client (IPv4)
• Zmodem
• Logging of keystrokes
• SNMP v1/v2c/v3
• SNMP Traps
• The system log
• RMON v1
- Support for groups 1, 2, 3, 9
• RMON v2
- Support group ProbeConfig
• LLDP
• 802.1AB
• LLDP-MED
• BootP / DHCP-Client
• DHCP automatically
• DHCP Relay (Supports IPv4)
Management
• DHCP Option 12
• DHCP Relay Option 82
• Adding a tag PPPoE Circuit-ID
• Flash File System
• SNTP
• Monitoring the CPU
• Monitoring Memory
• Debug
• Password Encryption
• Password recovery
• Support for Microsoft ® NLB (Network Load Balancing)
• Ping (support IPv4/v61)
• Traceroute
• Multiple IP Interface
MIB
• RFC 1065, 1066, 1155, 1156, 2578 MIB Structure
• RFC 1212 Concise MIB Definitions
• RFC 1213 MIB II
• RFC 1493 Bridge MIB 4188
• RFC 1157, 2571-2576 SNMP MIB
• RFC 1901-1908, 3418, 3636, 1442, 2578 SNMPv2 MIB
• RFC 271,1757, 2819 RMON MIB
• RFC 2465 IPv6 MIB
• RFC 2466 ICMPv6 MIB
• RFC 2737 Entity MIB
• Private MIB
• RFC 3289 DIFFSERV MIB
• RFC 2021 RMONv2 MIB
• RFC 1398, 1643, 1650, 2358, 2665, 3635 Ether-like MIB
• RFC 2668 802.3 MAU MIB
• RFC 2674, 4363 802.1p MIB
• RFC 2233, 2863 IF MIB
• RFC 4022 MIB for TCP
• RFC 4113 MIB for UDP
• RFC 3298 MIB for Diffserv
• RFC 2925 Ping & Traceroute MIB
• Backup and restore settings
• Upload and download files via TFTP
• Trap MIB
Standard IETF ®
• RFC 768 UDP
• RFC 791 IP
• RFC 792 ICMPv4
• RFC 2463, 4443 ICMPv6
• RFC 4884 Extended ICMP messages of support for Multi-Part
• RFC 793 TCP
• RFC 2474, 3260 Definition of the DS field in the IPv4 header and IPv6
• RFC 1321, 2284, 2865, 3580, 3748 Extensible Authentication Protocol (EAP)
• RFC 2571, RFC2572, RFC2573, RFC2574 SNMP
• RFC 826 ARP
IPv6
• RFC 1981 Path MTU Discovery
• RFC 2460 IPv6
• RFC 2461, 4861 Neighbor Discovery
• RFC 2462, 4862 IPv6 Stateless Address Auto-configuration
• RFC 2464 IPv6 Neighbor over Ethernet and definition
• RFC 3513 IPv6 Addressing Architecture 4291
• RFC 2893, 4213 Dual Stack IPv4/IPv6
• IPv6 Ready Logo Phase 2
