Description
SHARE YOUR PRINTERES ANA MULTIFUNCTION EQUIPMENT
The DPR-1061 3-Port Print Server provides users with 3 available ports from a single device, and offers print and scan compatibility for those who are using multifunction equipment. this print server allows users to directly send out documents from their PC for fax transmissions. Enjoy sharing your printer and multifunction equipment's printing, faxing, and scanning abilities among the users on your network - all with a single print server.
SIMULTANEOUS OPERATION OF ALL DEVICES
Equipped with a powerful CPU, large memory, high speed USB ports and network data transfer, this print server makes your operations fast. devices attached to the DPR-1061 can print, scan, and fax at the same time, giving this multi-port print server a similar performance to 3 separate single-port print servers at a fraction of the cost.
ACCESS SECURITY AND MULTIPLE OS SUPPORT
The DPR-1061 provides the necessary security by allowing the administrator to confgure user access rights to the network printers and equipment. it supports a wide range of network OS including: Windows 95/98/ME/nt 4.0/2000/XP, Apple MacOS with Appletalk, Linux, Solaris, SCO Unix, iBM AiX and netWare 5.x native NDS. Enjoy the fexibility and compatibility in major network OS that this print server has to offer.
REMOTE PRINTING SUPPORT
The DPR-1061 supports the internet Printing Protocol (iPP), enabling remote users to output fles to their offce printer even when they are away from the site. HP PJL protocol is also supported for bi-directional network printer communication, providing network administrators with critical information about the network printer. Regardless of where you are, never worry about being unable to print out important fles ever again with this print server’s convenient functions.
