Description
The DP-G301 single-port wireless G print server provides a parallel printer port for connection to a parallel printer. Equipped with a 10/100BASE-TX Ethernet and 802.11g wireless LAN interface, this device lets you conveniently share your printer with a group of home or office users, with or without the network wires. Supporting multiple network operating systems, this print server brings a high level of flexibility and performance to your printing needs.
Flexible Installation. The DP-G301 wireless G print server is ideal for both the large office and the small workgroup. For homes and SOHO with just one printer to share, this print server offers a single port and saves you the cost. For the large office with many computer users and several printers scattered at different places, you can plug one print server to each of these printers to share them on the network.
Ethernet and Wireless Interfaces. Two LAN interfaces are provided on this print server: (1) a 10/100BASE-TX Ethernet port and (2) a high-speed 802.11g wireless LAN interface supporting up to 54Mbps network data transfer. The wireless LAN interface allows you to put your printer anywhere in the room without cable restrictions, while users can send files wirelessly to the printer for printing.
Wireless Network Security. The DP-G301 wireless G print server provides the necessary security for wireless users, using the user-selectable 64/128-bit industry-standard WEP (Wired Equivalent Privacy) encryption protocol. Data privacy mechanism is based on a shared key algorithm, as described in the wireless LAN standard.
Multiple Network OS Support. The DP-G301 supports many network OS, including Windows, Apple MacOS, Linux, Solaris, SCO Unix and NetWare 5.x native NDS. This gives you the flexibility to install the print server, regardless of your network environment.Easy Setup. Setting up the print server is easy with a Windows-based menu-driven program, which guides you through all the necessary steps to set up and configure your network printer. SNMP and latest MIB-II MIBs are built into the print server , allowing you to manage this device on any SNMP standard-based network.
General features
Printer Port
DB 36-pin male centronic port, suppor ting bi-directional communication
Network Interfaces
802.11g wireless LAN - 10/100BASE-TX port
Network Protocols
TCP/IP , NetBEUI, AppleTalk, LPR, SMB over IP , IPP
(Internet Printing Protocol)
Data Buffer Size
8MB SDRAM
O.S. Support
- Microsoft Windows 95, 98, ME, NT, 2000, XP, 2003
- Mac O.S. 7.6 and above AppleTalk
- NetWare 5.x NDPS LPR Remote Printing (TCP/IP)
- HP-UX Unix
- Sun O.S Solaris
- SCO Unix
- AIX
- Unix, Linux
Management
- Web-based configuration
- Windows-based administration program
- SNMP v.2c with built-in MIB-II (RFC 1213)
- DHCP client support
Firmware Upgrade
Through web browser, FTP or administration program
Diagnostic LED Indicators
- Power
- Link/Activity
- LTP
Wireless LAN Standards
- 802.11g
- 802.11b
Data Rates
(With auto rate fallback)
- 802.11g: 6/9/12/18/24/36/48/54Mbps
- 802.11b: 1/2/5.5/11Mbps
Transmission T echnology
DSSS
RF Frequency Range
2.4 to 2.4835GHz
Operating Channels
- 1 to 11 channels (FCC)
- 1 to 13 channels (ETSI)
Data Modulation Type
DBPSK, DQPSK, CCK, OFDM
Antenna
2dBi Gain external dipole antenna
Transmit Output Power
15dBm +/- 2dB
Built-in Wireless LAN
Receive Sensitivity (for 802.11b)
- 54 Mbps OFDM, 10% PER, -68 dBm
- 48 Mbps OFDM, 10% PER, -68 dBm
- 36 Mbps OFDM, 10% PER, -75 dBm
- 24 Mbps OFDM, 10% PER, -79 dBm
- 18 Mbps OFDM, 10% PER, -82 dBm
- 12 Mbps OFDM, 10% PER, -84 dBm
- 11 Mbps CCK, 8% PER, -82 dBm
- 9 Mbps OFDM, 10% PER, -87 dBm
- 6 Mbps OFDM, 10% PER, -88 dBm
- 5.5 Mbps CCK, 8% PER, -85 dBm
- 2 Mbps QPSK, 8% PER, -86 dBm
- 1 Mbps BPSK, 8% PER, -89 dBm
Operating Range *
- Indoors: 100 meters
- Outdoors: 400 meters
* Environmental factors may adversely affect range
Security
WPA, 64/128-bit WEP data encryption with TKIP, MIC, IV Expansion, Shared Key
Basic Settings
- Communication mode
- SSID
- Wireless LAN channel number (default channel 6)
- Site survey
Advanced Settings
Authentication methods, Beacon interval, Preamble
Certificates
Order info
DP-G301 Wireless G Print Server
