D-Link, an industry leader in networking, introduces the DWL-P200 Power over Ethernet (PoE) Adapter.
The DWL-P200 delivers both data and electrical power to
Ethernet-enabled devices using a single Ethernet cable. Using Power
over Ethernet, you eliminate the need to place an Ethernet-enabled
device, such as a wireless access point, near a power outlet, giving
you more freedom in placement.
The DWL-P200 Power over Ethernet
(PoE) Adapter is simple to install, requiring no tools and no software.
Its compact size makes implementation of the DWL-P200 easy. Plug the
base unit into a power outlet, and then connect the terminal unit to
your network device using any standard Ethernet cable. Once set up, the
terminal device unit can output power** to any compatible 5V or 12V
Ethernet-enabled device.
The DWL-P200 simplifies your
installation of Ethernet-enabled devices, such as an Internet camera or
wireless access points, by allowing you to place it beyond the range of
standard power outlets. You can now mount these devices to a ceiling or
outside without placing them near a power supply.
With the
DWL-P200 Power over Ethernet (PoE) Adapter, both power and data can be
transmitted up to 328 feet (100m)* using standard Ethernet cabling with
virtually no reduction in data throughput. Use the DWL-P200 with
Ethernet-enabled devices where power outlets are not readily available.
* 1 Maximun distance per 802.3u specifications
** Maximum power output: 5 volts = 2.5 amps; 12 volts = 1 amp
