DIR-320EOL EOS
Description
WIRELESS NETWORKING
Create a wireless network for your home/SOHO using the D-Link Wireless G Router. Connect the Wireless G Router to a broadband modem to wirelessly share your high-speed Internet connection and enjoy surfng the web, checking e-mail, and chatting with family and friends online. The “Guest Zone” function provides secondary SSID of wireless connection and secondary routing domain, separating them from the main network domain for better security and management.
SECURITY PROTECTION
The D-Link Wireless G Router includes a built-in frewall that safeguards your network from harmful attacks. It minimizes the threats of hackers and prevents unwanted intruders from entering your network. Additional security features like MAC address fltering prevents unauthorized network access and parental control features prevent users from viewing inappropriate content. The Wireless G Router also supports WPA and WPS encryption for wireless security. D-Link’s easy-to-use Wireless G Router includes basic routing and security features to help you create a simple wireless network for your home and offce.
PRINTER AND ETHERNET CONNECTIONS
The Wireless G Router includes a USB port for connection to a USB printer for sharing on the network. It also provides four Ethernet ports ready for you to connect Ethernet-enabled PC, game consoles and other devices to the Internet.
EASY TO INSTALL AND USE
With D-Link Quick Router Setup Wizard and Wi-Fi Protected Setup (WPS), you can set up your wireless network in minutes. The wizard will guide you through an easy to follow process to install your new hardware and connect to your network. It confgures your Internet Service Provider (ISP) settings to quickly establish broadband Internet connectivity, and makes it easy to add new wireless devices onto the network.
General features
MINIMUM SYSTEM REQUIREMENTS
+ Cable or DSL modem with Ethernet port
+ Computer with Windows XP SP2, 2000 SP4 or Mac OS X (v10.4/v10.3) or Linux-based Operating System and an Installed Ethernet adapter
+ Internet Explorer 6 or Firefox 1.5 or later
STANDARDS
+ IEEE 802.11b/g
+ IEEE 802.3, 802.3u
+ USB 2.0
WAN INTERFACE
+ 10/100BASE-TX Ethernet port
+ Supports DSL and cable modem connection
+ Supports “Always-on” (bridged) and PPPoE for PPP connection on demand
LAN INTERFACE
+ 4 10/100BASE-TX Ethernet ports
+ Support auto MDI/MDIX
+ Support 802.3x fow control (full duplex) and back pressure (half duplex)
USB INTERFACE
+ USB 2.0 Type A port
+ Printer protocols: TCP/IP, RAW printing, LPR
+ Supports Windows Connect Now (WCN) confguration
WIRELESS SIGNAL RATES
(With automatic fallback)
+ 54, 48, 36, 24, 18, 12, 11, 9, 6, 5.5, 2, 1Mbps
WIRELESS FREQUENCY RANGE
+ 2.4GHz to 2.462GHz
MODULATION TECHNOLGOY
+ Orthogonal Frequency Division
Multiplexing (OFDM)
+ Complementary Code Keying (CCK)
WIRELESS TRANSMIT POWER
+ 802.11b: 17dBm +/- 2dBm
+ 802.11g: 13dBm +/- 2dBm
ANTENNA
+ Detachable dipole antenna with reverse SMA plug
SECURITY
+ WEP 64/128-bit data encryption (user-selectable)
+ Wi-Fi Protected Access (WPA/WPA2)
+ WPS (Wi-Fi Protected Setup)
+ Two SSID
+ Guest Zone
FIREWALL FEATURES
+ Network Address Translation (NAT)
+ Stateful Packet Inspection (SPI)
+ MAC Filtering
+ Website URL Filtering
DEVICE MANAGEMENT
+ Web-based management via Internet Explorer v6 or later; or Firefox 1.5 or later browser
Certificates
Order info
DIR-320 Wireless N150 Router with 3G/CDMA/WiMAX Support and USB Port
