DIR-815
AC1200 Wave 2 MU-MIMO Wi-Fi EasyMesh Router with 3G/LTE Support and USB Port
Description
USB Port1
The router is equipped with a USB port for connecting a USB modem, which can be used to establish connection to the Internet. In addition, to the USB port of the router you can connect a USB storage device, which will be used as a network drive, or a printer.
In order to use the multifunction USB port effectively, the router supports simultaneous operation of several USB devices. For example, you can access multimedia content of the connected HDD storage and at the same time share a USB printer.2
Wireless Interface
Using the DIR-815 device, you are able to quickly create a high-speed wireless network at home or in your office, which lets computers and mobile devices access the Internet virtually anywhere (within the operational range of your wireless network). Simultaneous activity of 2.4GHz band and 5GHz band allows performing a wide range of tasks. The router can operate as a base station for connecting wireless devices of the standards 802.11a, 802.11b, 802.11g, 802.11n, and 802.11ac (at the wireless connection rate up to 1167Mbps3).
Secure Wireless Connection
The router supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2/WPA34), MAC address filtering, WPS, WMM.
In addition, the device is equipped with a button for switching the Wi-Fi network off/on. If needed, for example, when you leave home, you can easily switch the router’s WLAN by pressing the button, and devices connected to the LAN ports of the router will stay online.1
The EasyMesh function1 is D-Link implementation of mesh networks designed to quickly connect several5 devices into one transport network, for example, when it's required to provide high-quality Wi-Fi coverage without dead zones in living units of complicated planning or it's needed to create a large temporary Wi-Fi network for an outdoor event.
Multi-user MIMO technology allows to distribute the router's resources to let multiple wireless clients use the Wi-Fi network efficiently, keeping high rates for HD media streaming, lag-free gaming, and fast transfer of large files.
Transmit Beamforming technology allows to flexibly change the antennas' radiation pattern and to redistribute the signal directly to wireless devices connected to the router.
Smart adjustment of Wi-Fi clients6 is useful for networks based on several D-Link access points or routers – when the smart adjustment function is configured on each of them, a client always connects to the access point (router) with the highest signal level.
Support of guest Wi-Fi network allows you to create a separate wireless network with individual security settings and maximum rate limitation. Devices connected to the guest network will be able to access the Internet, but will be isolated from the devices and resources of the router's LAN.
4-port Switch
The built-in 4-port switch enables you to connect Ethernet-enabled computers, game consoles, and other devices to your network.
Security
The wireless router DIR-815 includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN.
The SSH protocol1 support provides more secure remote configuration and management of the router due to encryption of all transmitted traffic, including passwords.
In addition, the router supports IPsec and allows to create secure VPN tunnels. Support of the IKEv2 protocol1 allows to provide simplified message exchange and use asymmetric authentication engine upon configuration of an IPsec tunnel.
The router also supports the SkyDNS web content filtering service1, which provides more settings and opportunities for safer Internet experience for home users of all ages and for professional activities of corporate users.
Now the schedules7 are also implemented; they can be applied to the rules and settings of the firewall and used to reboot the router at the specified time or every specified time period, to automatically save the configuration of the router to a connected USB storage, to set rules for limitation of wireless client maximum bandwidth, and to enable/disable the wireless network and the Wi-Fi filter.
Easy Configuration and Update
You can configure the settings of the wireless router DIR-815 via the user-friendly web-based interface (the interface is available in two languages – in Russian and in English).
The configuration wizard allows you to quickly switch DIR-815 to one of the following modes: router (for connection to a wired or wireless ISP), access point, repeater, or client, and then configure all needed setting for operation in the selected mode in several simple steps.
Also DIR-815 supports configuration and management via mobile application for Android smartphones.
You can simply update the firmware: the router itself finds approved firmware on D-Link update server and notifies when ready to install it.
1Only for DIR-815/R4.
2When using a USB hub with external power supply.
3Up to 300Mbps for 2.4GHz and up to 867Mbps for 5GHz.
4WPA3 is available only for DIR-815/R4.
5Up to 6 devices.
6Only for DIR-815/S.
7For DIR-815/S only reboot on schedule is available.
General features
DIR-815/R4 | DIR-815/S | |
Hardware
Processor
RTL8197FH-VG (1GHz)
RTL8197FN (1GHz)
RAM
128MB, DDR2, built in processor
64MB, DDR2, built in processor
Flash
128MB, NAND SPI
16MB, SPI
Interfaces
10/100BASE-TX WAN port
4 10/100BASE-TX LAN ports
USB 2.0 port
LEDs
Power
Internet
4 LAN LEDs
WLAN 2.4G
WLAN 5G
WPS
USB
Internet
WLAN/WPS 2.4G
WLAN/WPS 5G
WAN
4 LAN LEDs
Buttons
POWER button to power on/power off
WIFI button to enable/disable wireless network
WPS button to connect mesh network devices and set up wireless connection
RESET button to restore factory default settings
RST/WPS button to restore factory default settings and set up wireless connection
Antenna
Four external non-detachable antennas
Four internal antennas
5dBi gain
3.5dBi gain
MIMO
2 x 2, MU-MIMO
Power connector
Power input connector (DC)
Mounting
Desktop
Wall
Software
WAN connection types
Mobile Internet (via supported USB modem)
PPPoE
IPv6 PPPoE
PPPoE Dual Stack
Static IPv4 / Dynamic IPv4
Static IPv6 / Dynamic IPv6
PPPoE + Static IP / Dynamic IP (PPPoE Dual Access)
PPTP/L2TP + Static IP
PPTP/L2TP + Dynamic IP
Network functions
Support of IEEE 802.1X for Internet connection
DHCP server/relay
Advanced configuration of built-in DHCP server
Stateful/Stateless mode for IPv6 address assignment, IPv6 prefix delegation
Automatic obtainment of LAN IP address (for access point/repeater/client modes)
DNS relay
Dynamic DNS
Static IP routing
Static IPv6 routing
IGMP Proxy
MLD Proxy
RIP
Support of UPnP |
Support of UPnP IGD
Support of VLAN
WAN ping respond
Support of SIP ALG
Support of RTSP
WAN failover
Autonegotiation of speed, duplex mode, and flow control/Manual speed and duplex mode setup for each Ethernet port
Setup of maximum TX rate for each port of the router
XUPNPD plug-in
Built-in UDPXY application
Firewall functions
Network Address Translation (NAT)
Stateful Packet Inspection (SPI)
IP filter
IPv6 filter
MAC filter
URL filter
Ad blocking function
DMZ
Prevention of ARP and DDoS attacks
Virtual servers
Built-in SkyDNS web content filtering service
VPN
IPsec/PPTP/L2TP/PPPoE pass-through
PPTP/L2TP tunnels
L2TP over IPsec client
IPsec tunnels
Transport/Tunnel mode
IKEv1 support
IKEv2 support
DES encryption
NAT Traversal
Support of DPD (Keep-alive for VPN tunnels)
USB interface functions
USB modem
Auto connection to available type of supported network (4G/3G/2G)
Auto configuration of connection upon plugging in USB modem
Enabling/disabling PIN code check, changing PIN code1
Sending/receiving/reading/removing SMS messages1
Support of USSD requests1
USB storage
File browser
Print server
Access to storage via accounts
Built-in Samba server
Built-in FTP server
Built-in DLNA server
Built-in Transmission torrent client; uploading/downloading files from/to USB storage
Management and monitoring
Local and remote access to settings through SSH
Local and remote access to settings through TELNET/WEB (HTTP/HTTPS)
Bilingual web-based interface for configuration and management (Russian/English)
Support of D-Link Assistant application for Android smartphones
Notification on connection problems and auto redirect to settings
Firmware update via web-based interface
Automatic notification on new firmware version
Saving/restoring configuration to/from file
Support of logging to remote host
Support of logging to connected USB storage
Automatic synchronization of system time with NTP server and manual time/date setup
Ping utility
Traceroute utility
TR-069 client
Automatic reboot on schedule
Schedules for rules and settings of firewall, automatic saving a configuration backup to a connected USB storage, limitation of wireless client maximum bandwidth, and enabling/disabling wireless network and Wi-Fi filter
Automatic upload of configuration file from ISP's server (Auto Provision)
Wireless Module Parameters
Standards
IEEE 802.11ac Wave 2
IEEE 802.11a/b/g/n
IEEE 802.11k/v
IEEE 802.11w
IEEE 802.11a/b/g/n
Frequency range
The frequency range depends upon the radio frequency regulations applied in your country
2400 ~ 2483.5MHz
5150 ~ 5350MHz
5650 ~ 5850MHz
Wireless connection security
WEP
WPA/WPA2 (Personal/Enterprise)
WPA3 (Personal)
МАС filter
WPS (PBC/PIN)
Advanced functions
EasyMesh function
Support of client mode
WMM (Wi-Fi QoS)
Information on connected Wi-Fi clients
Advanced settings
Guest Wi-Fi / support of MBSSID
Rate limitation for wireless network/separate MAC addresses
Periodic scan of channels, automatic switch to least loaded channel
Support of 2.4GHz TX Beamforming
Support of 5GHz TX Beamforming
Autonegotiation of channel bandwidth in accordance with environment conditions (20/40 Coexistence)
Support of STBC
CoovaChilli authentication portal
Wireless connection rate
IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
IEEE 802.11b: 1, 2, 5.5, and 11Mbps
IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
IEEE 802.11n (2.4GHz/5GHz): from 6.5 to 300Mbps (from MCS0 to MCS15)
IEEE 802.11ac (5GHz): from 6.5 to 867Mbps (from MCS0 to MCS9)
Transmitter output power
Less than 20dBm (100mW) |
2.4GHz
5GHz
Less than 17.5dBm (56.2mW)
802.11b
15dBm at 1, 11Mbps
16.5dBm at 1, 2, 5.5, 11Mbps
802.11g
15dBm at 6, 54Mbps
16.5dBm at 6, 9, 12, 18, 24, 36, 48Mbps
15dBm at 54Mbps
802.11n
2.4GHz
15dBm at MCS0/8, 7/15
5GHz
2.4GHz
HT20/HT40
16.5dBm at MCS0/8~6/14
16dBm at MCS7/15
5GHz, HT20
14dBm at MCS0/8~4/12
13dBm at MCS5/13
12.5dBm at MCS6/14
12dBm at MCS7/15
5GHz, HT40
14dBm at MCS0/0~2/10
13dBm at MCS3/11~4/12
12.5dBm at MCS5/13~6/14
12dBm at MCS7/15
802.11ac
15dBm at MCS0, 9
VHT20
14dBm at MCS0~4
13dBm at MCS5
12.5dBm at MCS6
12dBm at MCS7
11dBm at MCS8
VHT40
14dBm at MCS0~2
13dBm at MCS3~4
12dBm at MCS5~6
11dBm at MCS7/8/9
VHT80
14dBm at MCS0~4
13dBm at MCS5~6
12dBm at MCS7
11dBm at MCS8/9
Receiver sensitivity
802.11a
-92dBm at 6Mbps
-91dBm at 9Mbps
-90dBm at 12Mbps
-88dBm at 18Mbps
-85dBm at 24Mbps
-81dBm at 36Mbps
-77dBm at 48Mbps
-75dBm at 54Mbps
-82dBm at 6Mbps
-81dBm at 9Mbps
-79dBm at 12Mbps
-77dBm at 18Mbps
-74dBm at 24Mbps
-70dBm at 36Mbps
-66dBm at 48Mbps
-65dBm at 54Mbps
802.11b
-95dBm at 1Mbps
-91dBm at 2Mbps
-90dBm at 5.5Mbps
-87dBm at 11Mbps
-80dBm at 1Mbps
-80dBm at 2Mbps
-76dBm at 5.5Mbps
-76dBm at 11Mbps
802.11g
-92dBm at 6Mbps
-91dBm at 9Mbps
-90dBm at 12Mbps
-88dBm at 18Mbps
-85dBm at 24Mbps
-81dBm at 36Mbps
-77dBm at 48Mbps
-76dBm at 54Mbps
-82dBm at 6Mbps
-81dBm at 9Mbps
-79dBm at 12Mbps
-77dBm at 18Mbps
-74dBm at 24Mbps
-70dBm at 36Mbps
-66dBm at 48Mbps
-65dBm at 54Mbps
802.11n
2.4GHz, HT20
-92dBm at MCS0/8
-90dBm at MCS1/9
-87dBm at MCS2/10
-84dBm at MCS3/11
-81dBm at MCS4/12
-77dBm at MCS5/13
-75dBm at MCS6/14
-74dBm at MCS7/15
2.4GHz, HT40
-88dBm at MCS0/8
-86dBm at MCS1/9
-84dBm at MCS2/10
-81dBm at MCS3/11
-77dBm at MCS4/12
-73dBm at MCS5/13
-71dBm at MCS6/14
-70dBm at MCS7/15
5GHz, HT20
-91dBm at MCS0/8
-90dBm at MCS1/9
-88dBm at MCS2/10
-84dBm at MCS3/11
-81dBm at MCS4/12
-76dBm at MCS5/13
-75dBm at MCS6/14
-73dBm at MCS7/15
5GHz, HT40
-90dBm at MCS0/8
-87dBm at MCS1/9
-84dBm at MCS2/10
-81dBm at MCS3/11
-78dBm at MCS4/12
-73dBm at MCS5/13
-72dBm at MCS6/14
-70dBm at MCS7/15
HT20
-82dBm at MCS0/8
-79dBm at MCS1/9
-77dBm at MCS2/10
-74dBm at MCS3/11
-70dBm at MCS4/12
-66dBm at MCS5/13
-65dBm at MCS6/14
-64dBm at MCS7/15
HT40
-79dBm at MCS0/8
-76dBm at MCS1/9
-74dBm at MCS2/10
-71dBm at MCS3/11
-67dBm at MCS4/12
-63dBm at MCS5/13
-62dBm at MCS6/14
-61dBm at MCS7/15
802.11ac
VHT20
-91dBm at MCS0
-89dBm at MCS1
-87dBm at MCS2
-84dBm at MCS3
-81dBm at MCS4
-76dBm at MCS5
-75dBm at MCS6
-74dBm at MCS7
-69dBm at MCS8
VHT40
-90dBm at MCS0
-87dBm at MCS1
-84dBm at MCS2
-81dBm at MCS3
-78dBm at MCS4
-73dBm at MCS5
-72dBm at MCS6
-71dBm at MCS7
-66dBm at MCS8
-64dBm at MCS9
VHT80
-87dBm at MCS0
-83dBm at MCS1
-81dBm at MCS2
-78dBm at MCS3
-74dBm at MCS4
-70dBm at MCS5
-69dBm at MCS6
-67dBm at MCS7
-63dBm at MCS8
-62dBm at MCS9
VHT20
-82dBm at MCS0
-79dBm at MCS1
-77dBm at MCS2
-74dBm at MCS3
-70dBm at MCS4
-66dBm at MCS5
-65dBm at MCS6
-64dBm at MCS7
-56dBm at MCS8
VHT40
-79dBm at MCS0
-76dBm at MCS1
-74dBm at MCS2
-71dBm at MCS3
-67dBm at MCS4
-63dBm at MCS5
-62dBm at MCS6
-61dBm at MCS7
-56dBm at MCS8
-54dBm at MCS9
VHT80
-76dBm at MCS0
-73dBm at MCS1
-71dBm at MCS2
-68dBm at MCS3
-64dBm at MCS4
-60dBm at MCS5
-59dBm at MCS6
-58dBm at MCS7
-53dBm at MCS8
-51dBm at MCS9
Modulation schemes
802.11a
BPSK, QPSK, 16QAM, 64QAM with OFDM
802.11b
DQPSK, DBPSK, DSSS, CCK
802.11g
802.11n
802.11ac
BPSK, QPSK, 16QAM, 64QAM, up to 256QAM with OFDM
Physical Parameters
Dimensions (L x W x H)
205 x 136 x 33 mm (8.07 x 5.35 x 1.3 in)
160 x 55 x 110 mm (6 x 2 x 4 in)
Weight
289 g (0.63 lb)
197 g (0.43 lb)
Operating Environment
Power
Output: 12V DC, 1A
Output: 12V DC, 0.5A
Temperature
Operating: from 0 to 40 °C
Storage: from -20 to 65 °C
Humidity
Operating: from 10% to 90% (non-condensing)
Storage: from 5% to 95% (non-condensing)
Delivery Package
Router DIR-815
Power adapter DC 12V/1A
Power adapter DC 12V/0.5A
Ethernet cable
“Quick Installation Guide” (brochure)
Supported USB modems2
GSM
Alcatel X500
D-Link DWM-152C1
D-Link DWM-156A6
D-Link DWM-156A7
D-Link DWM-156A8
D-Link DWM-156C1
D-Link DWM-157B1
D-Link DWM-157B1 (Velcom)
D-Link DWM-158D1
D-Link DWR-710
Huawei E150
Huawei E1550
Huawei E156G
Huawei E160G
Huawei E169G
Huawei E171
Huawei E173 (Megafon)
Huawei E220
Huawei E3131 (MTS 420S)
Huawei E352 (Megafon)
Huawei E3531
Prolink PHS600
Prolink PHS901
ZTE MF112
ZTE MF192
ZTE MF626
ZTE MF627
ZTE MF652
ZTE MF667
ZTE MF668
ZTE MF752
LTE
Alcatel IK40V
Brovi E3372-325 | + | – |
D-Link DWM-222
D-Link DWR-910 (revision D1) | + | – |
Huawei E3131
Huawei E3272
Huawei E3351
Huawei E3372s
Huawei E3372h-153
Huawei E3372h-320
Huawei E367
Huawei E392
Megafon M100-1
Megafon M100-2
Megafon M100-3
Megafon M100-4
Megafon M150-1
Megafon M150-2
Megafon M150-3
Megafon M150-4 | + | – |
MTS 824F
MTS 827F
Quanta 1K6E (Beeline 1K6E)
Yota LU-150
Yota WLTUBA-107
ZTE MF823
ZTE MF823D
ZTE MF827
ZTE MF833T
ZTE MF833V
Smartphones in USB tethering mode
Some models of Android smartphones
1For some models of USB modems.
2The manufacturer does not guarantee proper operation of the router with every modification of the firmware of USB modems.
Certificates
Order info
DIR-815/R1 AC1200 Wave 2 MU-MIMO Wi-Fi EasyMesh Router with 3G/LTE Support and USB Port
DIR-815/S/S1 AC1200 Wave 2 MU-MIMO Wi-Fi EasyMesh Router with 3G/LTE Support and USB Port
