DIR-615/GFEOL EOS
Gigabit Wireless N300 Router with Fiber WAN Port and FE LAN Ports
Description
Wireless Interface
Using the DIR-615 device, you are able to quickly create a high-speed wireless network at home or in your office, which lets computers and mobile devices access the Internet virtually anywhere (within the operational range of your wireless network). The router can operate as a base station for connecting wireless devices of the standards 802.11b, 802.11g, 802.11n (at the wireless connection rate up to 300Mbps).
Secure Wireless Connection
The router supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2), MAC address filtering, WPS, WMM. In addition, the device is equipped with a button for switching the Wi-Fi network off/on. If needed, for example, when you leave home, you can easily switch the router’s WLAN by pressing the button, and devices connected to the LAN ports of the router will stay online.
Smart adjustment of Wi-Fi clients is useful for networks based on several D-Link access points or routers – when the smart adjustment function is configured on each of them, a client always connects to the access point (router) with the highest signal level.
Support of guest Wi-Fi network allows you to create a separate wireless network with individual security settings and maximum rate limitation. Devices connected to the guest network will be able to access the Internet, but will be isolated from the devices and resources of the router's LAN.
4-port Switch
The built-in 4-port switch enables you to connect Ethernet-enabled computers, game consoles, and other devices to your network.
Security
The wireless router DIR-615 includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN.
In addition, the router supports IPsec and allows to create secure VPN tunnels.
Built-in Yandex.DNS service protects against malicious and fraudulent web sites and helps to block access to adult content on children's devices.
Easy Configuration and Update
You can configure the settings of the wireless router DIR-615 via the user-friendly web-based interface (the interface is available in two languages – in Russian and in English).
You can simply update the firmware: the router itself finds approved firmware on D-Link update server and notifies when ready to install it.
General features
Hardware
Processor
• RTL8197DN (660MHz)
RAM
• 64MB, DDR2
Flash
• 8MB, SPI
Interfaces
• 1000BASE-X SFP WAN port
• 4 10/100BASE-TX LAN ports
LEDs
• POWER
• INTERNET
• WLAN
• WPS
• 4 LAN LEDs
Buttons
• ON/OFF button to power on/power off
• RESET button to restore factory default settings
• WPS button to set up wireless connection and enable/disable wireless network
Antenna
• Two external non-detachable antennas (5dBi gain)
MIMO
• 2 x 2
Power connector
• Power input connector (DC)
Software
WAN connection types
• PPPoE
• IPv6 PPPoE
• PPPoE Dual Stack
• Static IPv4/Dynamic IPv4
• Static IPv6 / Dynamic IPv6
• PPPoE + Static IP / Dynamic IP
• PPTP/L2TP + Static IP
• PPTP/L2TP + Dynamic IP
Network functions
• Support of IEEE 802.1X for Internet connection
• DHCP server/relay
• Stateful/Stateless mode for IPv6 address assignment, IPv6 prefix delegation
• Automatic obtainment of LAN IP address (for access point/repeater/client modes)
• DNS relay
• Dynamic DNS
• Static IP routing
• Static IPv6 routing
• IGMP Proxy
• RIP
• Support of UPnP IGD
• Support of VLAN
• WAN ping respond
• Support of SIP ALG
• Support of RTSP
• WAN reservation
• Autonegotiation of speed, duplex mode, and flow control/Manual speed and duplex mode setup for each Ethernet port
• Setup of maximum TX rate for each port of the router
• Built-in UDPXY application
Firewall functions
• IP filter
• IPv6 filter
• MAC filter
• URL filter
• DMZ
• Prevention of ARP and DDoS attacks
• Virtual servers
• Built-in Yandex.DNS web content filtering service
VPN
• IPSec/PPTP/L2TP/PPPoE pass-through
• IPSec tunnels
Management
• Local and remote access to settings through TELNET/WEB (HTTP/HTTPS)
• Bilingual web-based interface for configuration and management (Russian/English)
• Support of remote logging
• Ping function
• Traceroute utility
• TR-069 client
Wireless Module Parameters
Standards
• IEEE 802.11b/g/n
Frequency range
• 2400 ~ 2483.5MHz
Wireless connection security
• WEP
• МАС filter
• WPS (PBC/PIN)
Advanced functions
• Support of client mode
• WMM (Wi-Fi QoS)
• Information on connected Wi-Fi clients
• Advanced settings
• Smart adjustment of Wi-Fi clients
• Guest Wi-Fi
• Rate limitation for wireless network/separate MAC addresses
• Autonegotiation of channel bandwidth in accordance with environment conditions (20/40 Coexistence)
Wireless connection rate
• IEEE 802.11b: 1, 2, 5.5, and 11Mbps
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
• IEEE 802.11n: from 6.5 to 300Mbps (from MCS0 to MCS15)
Transmitter output power
• 802.11b (typical at room temperature 25 °C)
   15dBm at 1, 2, 5.5, 11Mbps
• 802.11g (typical at room temperature 25 °C)
   15dBm at 6, 9, 12, 18, 24, 36, 48, 54Mbps
• 802.11n (typical at room temperature 25 °C)
   HT20/HT40
   15dBm at MCS0/1/2/3/4/5/6/7/8/9/10/11/12/13/14
   14dBm at MCS7/15
Receiver sensitivity
• 802.11b (typical at PER = 8% at room temperature 25 °C)
   -84dBm at 1, 2Mbps
   -82dBm at 5.5Mbps
   -79dBm at 11Mbps
• 802.11g (typical at PER = 10% at room temperature 25 °C)
   -82dBm at 6Mbps
   -81dBm at 9Mbps
   -79dBm at 12Mbps
   -77dBm at 18Mbps
   -74dBm at 24Mbps
   -70dBm at 36Mbps
   -66dBm at 48Mbps
   -65dBm at 54Mbps
• 802.11n (typical at PER = 10% at room temperature 25 °C)
   HT20
   -82dBm at MCS0/8
   -79dBm at MCS1/9
   -77dBm at MCS2/10
   -74dBm at MCS3/11
   -70dBm at MCS4/12
   -66dBm at MCS5/13
   -65dBm at MCS6/14
   -64dBm at MCS7/15
   HT40
   -79dBm at MCS0/8
   -76dBm at MCS1/9
   -74dBm at MCS2/10
   -71dBm at MCS3/11
   -67dBm at MCS4/12
   -63dBm at MCS5/13
   -62dBm at MCS6/14
   -61dBm at MCS7/15
Modulation schemes
Physical Parameters
Dimensions (L x W x H)
• 172 x 132 x 36 mm (6.76 x 5.19 x 1.42 in)
Weight
• 286 g (0.63 lb)
Operating Environment
Power
• Output: 12V DC, 1A
Temperature
• Operating: from 0 to 40 °C
• Storage: from -20 to 65 °C
Humidity
• Operating: from 10% to 90% (non-condensing)
• Storage: from 5% to 95% (non-condensing)
Delivery Package
• Router DIR-615
• Power adapter DC 12V/1A
• Ethernet cable (CAT 5E)
Certificates
Order info
DIR-615/GF  Gigabit Wireless N300 Router with Fiber WAN Port and FE LAN Ports
Pictures
DIR-615/GF/W1
View from the right
Front view
Back view
Downloads
Support Resources
