![](/up/prod/600/DIR-651_B1_.jpg)
DIR-651EOL EOS
Description
Wireless Interface
Using the DIR-651 device, you are able to quickly create a wireless network at home or in your office, which lets your relatives or employees connect to your wireless network virtually anywhere (within the operational range of your wireless network). The router can operate as a base station for connecting wireless devices of the standards 802.11b, 802.11g, and 802.11n (at the rate up to 300Mbps).
Secure Wireless Connection
The router supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2), MAC address filtering, WPS, WMM.
In addition, the device is equipped with a button for switching the Wi-Fi network off/on. If needed, for example, when you leave home, you can easily switch the router’s WLAN by pressing the button, and devices connected to the LAN ports of the router will stay online.
Support of guest Wi-Fi network allows you to create a separate wireless network with individual security settings and maximum rate limitation. Devices connected to the guest network will be able to access the Internet, but will be isolated from the devices and resources of the router's LAN.
Smart adjustment of Wi-Fi clients is useful for networks based on several D-Link access points or routers – when the smart adjustment function is configured on each of them, a client always connects to the access point (router) with the highest signal level.
4-port Switch
The built-in 4-port switch enables you to connect Ethernet-enabled computers, game consoles, and other devices to your network.
Security
The wireless router DIR-651 includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN.
Built-in Yandex.DNS service protects against malicious and fraudulent web sites and helps to block access to adult content on children's devices.
Easy configuration and update
You can configure the settings of the wireless router DIR-651 via the user-friendly web-based interface (the interface is available in several languages).
You can simply update the firmware: the router itself finds approved firmware on D-Link update server and notifies when ready to install it.
General features
DIR-651/A/B
DIR-651/A/A
Hardware
Interfaces
10/100/1000BASE-T WAN port
4 10/100/1000BASE-T LAN ports
LEDs
POWER
WPS
INTERNET
WLAN
4 LAN LEDs
Power
Internet
WLAN
4 LAN LEDs
WPS
Buttons
ON/OFF button to power on/power off
RESET button to restore factory default settings
WPS button to set up secure wireless connection and enable/disable wireless network
Antenna
Two internal omnidirectional antennas
(3.75dBi gain) |
Two external non-detachable omnidirectional antennas (2dBi gain)
MIMO
2 x 2
Power connector
Power input connector (DC)
Software
WAN connection types
PPPoE
IPv6 PPPoE
PPPoE Dual Stack
Static IP / Dynamic IP
Static IPv6 / Dynamic IPv6
PPPoE + Static IP/Dynamic IP
PPTP/L2TP + Static IP
PPTP/L2TP + Dynamic IP
Network functions
DHCP server/relay
DHCPv6 server (Stateful/Stateless), IPv6 prefix delegation
DNS relay
Support of DNSv6 AAAA records
Dynamic DNS
Static IP routing
Static IPv6 routing
IGMP Proxy
RIP
Support of UPnP IGD
Support of VLAN
WAN ping respond
Support of SIP ALG
Support of RTSP
Autonegotiation of speed, duplex mode, and flow control/Manual speed and duplex mode setup for each Ethernet port
Setup of maximum TX rate for each port of the router
Built-in UDPXY application
Firewall functions
Network Address Translation (NAT)
Stateful Packet Inspection (SPI)
IP filter
IPv6 filter
MAC filter
URL filter
DMZ
Prevention of ARP and DDoS attacks
Virtual servers
Built-in Yandex.DNS web content filtering service
VPN
IPSec/PPTP/L2TP/PPPoE pass-through
Management
Local and remote access to settings through TELNET/WEB (HTTP/HTTPS)
Multilingual web-based interface for configuration and management
Notification on connection problems and auto redirect to settings
Firmware update via web-based interface
Automatic notification on new firmware version
Saving/restoring configuration to/from file
Support of remote logging
Automatic synchronization of system time with NTP server and manual time/date setup
Ping function
Traceroute utility
TR-069 client
Wireless Module Parameters
Standards
IEEE 802.11b/g/n
Frequency range
2400 ~ 2483.5MHz
Wireless connection security
WEP
WPA/WPA2 (Personal/Enterprise)
МАС filter
WPS (PBC/PIN)
Advanced functions
Support of client mode
WMM (Wi-Fi QoS)
Information on connected Wi-Fi clients
Advanced settings
Guest Wi-Fi
Limitation of wireless network rate
Wireless connection rate
IEEE 802.11b: 1, 2, 5.5, and 11Mbps
IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
IEEE 802.11n: from 6.5 to 300Mbps (from MCS0 to MCS15)
802.11b
17dBm at 1, 2, 5,5, 11Mbps
16dBm at 1, 2, 5,5, 11Mbps
802.11g
14,5dBm at 6, 9, 12, 18, 24, 36, 48, 54Mbps
14dBm at 6, 9, 12, 18, 24, 36, 48, 54Mbps
802.11n
HT20
14dBm at MCS6/7
HT40
14dBm at MCS6/7
13dBm at MCS0/1/2/3/4/5/6/7
Receiver sensitivity
802.11b
-82dBm at 1Mbps
-78dBm at 5,5Mbps
-76dBm at 11Mbps
-87dBm at 1, 2Mbps
-85dBm at 5,5Mbps
-82dBm at 11Mbps
802.11g
-82dBm at 6Mbps
-81dBm at 9Mbps
-79dBm at 12Mbps
-77dBm at 18Mbps
-74dBm at 24Mbps
-70dBm at 36Mbps
-66dBm at 48Mbps
-65dBm at 54Mbps
802.11n
HT20
-82dBm at MCS0/8
-79dBm at MCS1/9
-77dBm at MCS2/10
-74dBm at MCS3/11
-70dBm at MCS4/12
-66dBm at MCS5/13
-65dBm at MCS6/14
-64dBm at MCS7/15
HT40
-79dBm at MCS0/8
-76dBm at MCS1/9
-74dBm at MCS2/10
-71dBm at MCS3/11
-67dBm at MCS4/12
-63dBm at MCS5/13
-62dBm at MCS6/14
-61dBm at MCS7/15
Modulation schemes
802.11b
DQPSK, DBPSK, DSSS, CCK
802.11g
BPSK, QPSK, 16QAM, 64QAM with OFDM
802.11n
Physical Parameters
Dimensions (L x W x H)
194 x 60 x 120 mm (7.6 x 2.4 x 4.7 in)
147.5 x 113 x 31.5 mm (5.81 x 4.5 x 2.3 in)
Weight
300 g (0.66 lb)
218 g (0.48 lb)
Operating Environment
Power
Output: 12V DC, 1.2A
Output: 5V DC, 2.5A
Temperature
Operating: from 0 to 40 °C
Storage: from -20 to 65 °C
Humidity
Operating: from 10% to 90% (non-condensing)
Storage: from 5% to 95% (non-condensing)
Delivery Package
Router DIR-651
Power adapter DC 12V/1.2A
Ethernet cable
“Quick Installation Guide” (brochure)
Router DIR-651
Power adapter DC 5V/2.5A
Ethernet cable
Certificates
Order info
DIR-651 Wireless N300 Gigabit Router
