Description
Wireless Interface
Using the DIR-806A device, you are able to quickly create a high-speed wireless network at home or in your office, which lets computers and mobile devices access the Internet virtually anywhere (within the operational range of your wireless network). Simultaneous activity of 2.4GHz band and 5GHz band allows performing a wide range of tasks. The router can operate as a base station for connecting wireless devices of the standards 802.11a, 802.11b, 802.11g, 802.11n, and 802.11ac (at the wireless connection rate up to 733Mbps1).
Secure Wireless Connection
The router supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2), MAC address filtering, WPS, WMM.
Support of guest Wi-Fi network allows you to create a separate wireless network with individual security settings. Devices connected to the guest network will be able to access the Internet, but will be isolated from the devices and resources of the router's LAN2.
Security
The wireless router DIR-806A includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN.
In addition, the gateway supports IPsec and allows to create secure VPN tunnels.
Built-in Yandex.DNS service protects against malicious and fraudulent web sites and helps to block access to adult content on children's devices.
Easy configuration and update
You can configure the settings of the wireless router DIR-806A via the user-friendly web-based interface (the interface is available in several languages).
The configuration wizard allows you to quickly switch DIR-806A to one of the following modes: router (for connection to a wired or wireless ISP), access point, repeater, or client, and then configure all needed setting for operation in the selected mode in several simple steps.
Also DIR-806A supports configuration and management via mobile application for Android smartphones.
You can simply update the firmware: the router itself finds approved firmware on D-Link update server and notifies when ready to install it.
1Up to 300Mbps for 2.4GHz and up to 433Mbps for 5GHz.
2For DIR-806A/C1 only.
General features
Hardware
Processor
MT7620A (580MHz)
RAM
64MB, DDR2
Flash
8MB, SPI
Interfaces
10/100BASE-TX WAN port
4 10/100BASE-TX LAN ports
LEDs
POWER
2.4G WLAN
5G WLAN
INTERNET
WPS
Buttons
WPS/RESET button to set up wireless connection and restore factory default settings
ON/OFF button to power on/power off
Antenna
Three external detachable antennas
Three external non-detachable antennas
5dBi gain
MIMO
2 x 2 (for 2.4GHz)
Power connector
Power input connector (DC)
Software
WAN connection types
PPPoE
IPv6 PPPoE
PPPoE Dual Stack
Static IP / Dynamic IP
Static IPv6 / Dynamic IPv6
PPPoE + Static IP / Dynamic IP
PPTP/L2TP + Static IP
PPTP/L2TP + Dynamic IP
Network functions
DHCP server/relay
Stateful/Stateless mode for IPv6 address assignment, IPv6 prefix delegation
DNS relay
Dynamic DNS
Static IP routing
Static IPv6 routing
IGMP Proxy
RIP
Support of UPnP IGD
Support of VLAN
WAN ping respond
Support of SIP ALG
Support of RTSP
Built-in UDPXY application
Autonegotiation of speed, duplex mode, and flow control/Manual speed and duplex mode setup for each Ethernet port
Firewall functions
Network Address Translation (NAT)
Stateful Packet Inspection (SPI)
IP filter
IPv6 filter
MAC filter
URL filter
DMZ
Prevention of ARP and DDoS attacks
Virtual servers
Built-in Yandex.DNS web content filtering service
VPN
IPsec/PPTP/L2TP/PPPoE pass-through
IPsec tunnels
Management
Local and remote access to settings
TELNET/WEB (HTTPS, HTTP)
Multilingual web-based interface for configuration and management
Support of application for Android smartphones
Notification on connection problems and auto redirect to settings
Firmware update via web-based interface
Automatic notification on new firmware version
Saving/restoring configuration to/from file
Support of logging to remote host
Automatic synchronization of system time with NTP server and manual time/date setup
Ping utility
Traceroute utility
TR-069 client
SNMP agent
Wireless Module Parameters
Standards
IEEE 802.11a/n/ac
IEEE 802.11b/g/n
Frequency range
2400 ~ 2483.5MHz
5150 ~ 5350MHz
5650 ~ 5725MHz
Wireless connection security
WEP
WPA/WPA2 (Personal/Enterprise)
МАС filter
WPS (PBC/PIN)
Advanced functions
Support of client mode
WMM (Wi-Fi QoS)
Information on connected
Wi-Fi clients |
Advanced settings
Support of MBSSID
Guest Wi-Fi
Periodic scan of channels, automatic switch to least loaded channel
Wireless connection rate
IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
IEEE 802.11b: 1, 2, 5.5, and 11Mbps
IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
IEEE 802.11n (2.4GHz/5GHz): from 6.5 to 300Mbps (from MCS0 to MCS15)
IEEE 802.11ac (5GHz): from 6.5 to 433Mbps (from MCS0 to MCS9)
Transmitter output power
802.11a
15dBm at 6, 9, 12, 18, 24, 36, 48, 54Mbps
802.11b
15dBm at 1, 2, 5.5, 11Mbps
802.11g
802.11n
2.4GHz, HT20/HT40
15dBm at MCS0~15
5GHz, HT20/HT40
15dBm at MCS0~15
802.11ac
VHT20
15dBm at MCS0~7
14.5dBm at MCS8
VHT40
15dBm at MCS0~7
14.5dBm at MCS8~9
VHT80
15dBm at MCS0~7
14.5dBm at MCS8~9
Receiver sensitivity
802.11a
-93dBm at 6Mbps
-92dBm at 9Mbps
-91dBm at 12Mbps
-90dBm at 18Mbps
-86dBm at 24Mbps
-84dBm at 36Mbps
-79dBm at 48Mbps
-77dBm at 54Mbps
-82dBm at 6Mbps
-81dBm at 9Mbps
-79dBm at 12Mbps
-77dBm at 18Mbps
-74dBm at 24Mbps
-70dBm at 36Mbps
-66dBm at 48Mbps
-65dBm at 54Mbps
802.11b
-98dBm at 1Mbps
-95dBm at 2Mbps
-93dBm at 5.5Mbps
-90dBm at 11Mbps
-79dBm at 1, 2, 5.5, 11Mbps
802.11g
-91dBm at 6Mbps
-90dBm at 9Mbps
-88dBm at 12Mbps
-86dBm at 18Mbps
-84dBm at 24Mbps
-81dBm at 36Mbps
-76dBm at 48Mbps
-74dBm at 54Mbps
-82dBm at 6Mbps
-81dBm at 9Mbps
-79dBm at 12Mbps
-77dBm at 18Mbps
-74dBm at 24Mbps
-70dBm at 36Mbps
-66dBm at 48Mbps
-65dBm at 54Mbps
802.11n
2.4GHz, HT20
-90dBm at MCS0
-89dBm at MCS1
-87dBm at MCS2
-84dBm at MCS3
-81dBm at MCS4
-77dBm at MCS5
-75dBm at MCS6
-74dBm at MCS7
2.4GHz, HT40
-88dBm at MCS0
-86dBm at MCS1
-84dBm at MCS2
-81dBm at MCS3
-77dBm at MCS4
-74dBm at MCS5
-72dBm at MCS6
-70dBm at MCS7
5GHz, HT20
-92dBm at MCS0
-91dBm at MCS1
-90dBm at MCS2
-86dBm at MCS3
-84dBm at MCS4
-78dBm at MCS5
-77dBm at MCS6
-75dBm at MCS7
5GHz, HT40
-90dBm at MCS0
-89dBm at MCS1
-87dBm at MCS2
-84dBm at MCS3
-79dBm at MCS4
-76dBm at MCS5
-75dBm at MCS6
-73dBm at MCS7
HT20
-82dBm at MCS0
-79dBm at MCS1
-77dBm at MCS2
-74dBm at MCS3
-70dBm at MCS4
-66dBm at MCS5
-65dBm at MCS6
-64dBm at MCS7
HT40
-79dBm at MCS0
-76dBm at MCS1
-74dBm at MCS2
-71dBm at MCS3
-67dBm at MCS4
-63dBm at MCS5
-62dBm at MCS6
-61dBm at MCS7
802.11ac
VHT20
-92dBm at MCS0
-91dBm at MCS1
-90dBm at MCS2
-86dBm at MCS3
-84dBm at MCS4
-79dBm at MCS5
-77dBm at MCS6
-76dBm at MCS7
-71dBm at MCS8
VHT40
-90dBm at MCS0
-89dBm at MCS1
-87dBm at MCS2
-84dBm at MCS3
-81dBm at MCS4
-76dBm at MCS5
-74dBm at MCS6
-73dBm at MCS7
-68dBm at MCS8
-66dBm at MCS9
VHT80
-85dBm at MCS0
-84dBm at MCS1
-83dBm at MCS2
-80dBm at MCS3
-76dBm at MCS4
-72dBm at MCS5
-70dBm at MCS6
-68dBm at MCS7
-63dBm at MCS8
-61dBm at MCS9
VHT20
-82dBm at MCS0
-79dBm at MCS1
-77dBm at MCS2
-74dBm at MCS3
-70dBm at MCS4
-66dBm at MCS5
-65dBm at MCS6
-64dBm at MCS7
-59dBm at MCS8
VHT40
-79dBm at MCS0
-76dBm at MCS1
-74dBm at MCS2
-71dBm at MCS3
-67dBm at MCS4
-63dBm at MCS5
-62dBm at MCS6
-61dBm at MCS7
-56dBm at MCS8
-54dBm at MCS9
VHT80
-76dBm at MCS0
-73dBm at MCS1
-71dBm at MCS2
-68dBm at MCS3
-64dBm at MCS4
-60dBm at MCS5
-59dBm at MCS6
-58dBm at MCS7
-53dBm at MCS8
-51dBm at MCS9
Modulation schemes
802.11a
BPSK, QPSK, 16QAM, 64QAM with OFDM
802.11b
DQPSK, DBPSK, DSSS, CCK
802.11g
802.11n
802.11ac
BPSK, QPSK, 16QAM, 64QAM, up to 256QAM with OFDM
Compatible equipment and accessories
Antennas
ANT24-0800
ANT24-0801
ANT24-0802
ANT24-0802C
ANT24-1200
ANT24-1201
ANT24-1202
ANT24-1400
ANT24-1800
ANT24-2100
ANT70-0800
ANT70-1000
ANT70-1400N
ANT70-1800
Extension cable
ANT24-CB03N (only with external antennas)
ANT24-CB06N (only with external antennas)
ANT24-CB09N (only with external antennas)
Lighting surge protector
ANT70-SP (only with external antennas)
ANT-SP (only with external antennas)
Physical Parameters
Dimensions (L x W x H)
192 x 108 x 30 mm
(7.56 x 4.25 x 1.18 in) |
192 x 108 x 30 mm
Weight
240 g (0.53 lb)
240 g (0.53 lb)
Operating Environment
Power
Output: 12V DC, 0.5A
Temperature
Operating: from 0 to 40 °C
Storage: from -20 to 65 °C
Humidity
Operating: from 10% to 90% (non-condensing)
Storage: from 5% to 95% (non-condensing)
Delivery Package
Router DIR-806A
Power adapter DC 12V/0.5A
Ethernet cable
“Quick Installation Guide” (brochure)
Certificates
Order info
DIR-806A Wireless AC750 Dual Band Router & Access Point
