DIR-857EOL EOS
HD Media Router 3000
Description
What it does
Experience the unprecedented wireless speeds of D-Link’s HD Media Router 3000, which features concurrent dual-band wireless performance with 450 + 450 Mbps transfer speeds for flawless HD video streaming and quick file transfers. Built in Quality of Service (QoS) features optimize your network to ensure that your multimedia playback is smooth and your online gaming is lag free.
Instant file sharing with SharePort
It’s easy to share your photos, music, and videos; with D-Link’s SharePort™ Plus technology, you can connect a high-speed USB 3.0 storage drive to provide instant, simultaneous shared access to it for your network.1 You can also connect a multifunction USB printer to share printing, scanning, and faxing functions, allowing ou to use a single printer for your entire home or office.
General features
Standards
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.11b
• IEEE 802.11a
• IEEE 802.3
• IEEE 802.3u
• IEEE 802.3ab
• USB 3.0
Device interfaces
• 802.11n/g/b/a wireless LAN
• Four 10/100/1000 BASE-T Gigabit LAN ports
• 10/100/1000 BASE-T Gigabit WAN port
• USB 3.0 port
• SD Card slot
Wireless data rate
• Concurrent dual-band wireless for up to 450 + 450 Mbps transfer 2
Wireless LAN security
• WPA & WPA2 (Wi-Fi Protected Access)
• 64/128 bit WEP encryption
• WPS connection
QoS
• QoS engine for prioritizing traffic
• WMM for WLAN traffic
Shareport™ plus support 3
• Share an external USB hard drive or flash memory drive through a SAMBA file share
• Multiple users can access shared storage at the same time
• Share a multifunction USB printer
LEDs
• Power/Status
• Internet
Device management
• UPnP support
• DDNS support
• Integrated Wireless Security Wizard and Wireless Protected Setup (WPS) support
• Windows Connect Now (WCN) support
• Web based management using Internet Explorer 6 or higher, or other Java-enabled-browser
• Online firmware update check
• E-mail notifications for triggered events
• UPnP™ AV Server for streaming media to compatible media players 4
• Multi language support
Certificates
Order info
DIR-857/RU/A1A HD Media Router 3000
