![](/up/prod/600/DAP-1360.jpg)
DAP-1360EOL EOS
Description
CONNECT TO A WIRELESS NETWORK
The D-Link DAP-1360 Wireless N Access Point connects to a broadband modem enabling you to wirelessly share your Internet connection. It is a draft 802.11n compliant device that delivers up to 14x faster speeds1 and 6x farther range1 than 802.11g while retaining backward compatibility with 802.11g and 802.11b devices. Enjoy surfing the web, checking e-mail, and chatting with family and friends online at faster speeds on your wireless network
PROTECT YOUR WIRELESS NETWORK AND DATA
The DAP-1360 provides 64/128-bit WEP encryption and WPA/WPA2 security to protect your network and wireless data. This device also supports Wi-Fi Protected Setup (WPS) to quickly and securely setup a wireless network. In addition, the access point features MAC address filtering and a disable SSID broadcast function to limit outsiders’ access to your home and office network.
CONFIGURE YOUR AP FOR DIFF ERENT APPLICATIONS
The DAP-1360 can be configured to operate in seven different modes as needed. The Access Point mode allows the device to act as a central hub for wireless users. The Wireless Client mode is available to enable the DAP-1360 to connect to another access point. There is a Bridge mode to join two wired networks (LANs) together and a Bridge with AP mode so the device can act as a wireless hub and a bridge at the same time. The Repeater mode extends wireless coverage to cover all “dead” spots. A WISP Client Router mode allows wireless Internet service subscribers to share Internet connection with home/office Ethernet-enabled computers without the need for an extra router. Finally, the device can act as a WISP Repeater to let WISP subscribers share Internet connection with wired and wireless computers without any extra routers.
INSTALL YOUR AP QUICKLY AND EASILY
With D-Link Setup Wizard, you can set up your wireless network in minutes. It configures your DAP-1360’s operating mode and makes it easy to add new wireless devices onto the network. Create a simple wireless network for your home and office quickly and easily with the DAP-1360.
General features
NETWORK STANDARDS
• 802.11n (draft) wireless LAN
• 802.11g wireless LAN
• 802.11b wireless LAN
• 802.3/802.3u 10BASE-T/100BASE-TX Ethernet
• ANSI/IEEE 802.3 NWay auto-negotiation
DEVICE INTERFACES
• 802.11g/n wireless LAN
• One 10/100BASE-TX Ethernet LAN port
OPERATING FREQUENCY
2.4 to 2.4835 GHz
OPERATING CHANNELS
• FCC: 11
• ETSI: 13
RADIO & MODULATION SCHEMES
DQPSK, DBPSK, CCK, OFDM
OPERATING MODES
• Access Point
• Wireless Client
• Bridge
• Bridge with AP
• Repeater
• WISP Client Router
• WISP Repeater
ANTENNA
Two 2dBi Gain detachable omni-directional antennas with RP-SMA connector
SECURITY
• 64/128-bit WEP data encryption
• WPA-PSK, WPA2-PSK
• WPA-EAP, WPA2-EAP
• TKIP, AES
• MAC address filtering
• SSID broadcast disable function
• WPS (Wi-Fi Protected Setup)
ADVANCED FEATURES
• Quality of Service (QOS): Wi-Fi Multimedia (WMM)
• IGMP Snooping
DEVICE MANAGEMENT
• Web-based management through Internet Explorer v.6 or later, Netscape Navigator v.6 or later or other
• Java-enabled browser
Diagnostic LEDs
• Power
• Wireles
• Security
• LAN
POWER INPUT
• 5VDC 2.5A
• External power adapter
Certificates
Order info
DAP-1360 WIRELESS N ACCESS POINT
