Description
High-Speed Remote Access
The router provides 1 BRI with 2 channels, each transmitting at 64Kbps. With data compression, transmission speed can be increased significantly, giving the SOHO or branch office the ideal high-speed Internet access.
Remote User Support
The router provides remote network access through ISDN. This allows for 2 users to login simultaneously from 2 different locations. The router comes with Network Address Translator (NAT) which allows the network to support a large number of users from a single shared IP address for cost savings and enhanced security.
Robust Security Features
Many security features are added to provide a secured network environment. Features such as passwords for the system management terminal, PAP , CHAP protocols for remote access users, and firewall filtering for access control are provided. ( Up to 8 passwords protect accounts for remote administrators. RADIUS provides a solution to centralizing authentication for remote access.)
4 Built-in 10/100Mbps Switched Ports
The router has 4 auto-sensing Ethernet/Fast Ethernet switched ports built into it to provide SOHO users with an all-in-one solution for Internet connection. The built-in LAN switch saves users the time and trouble of purchasing and installing a separate switch. 4 hubs, workstations and servers can directly connect to the router.
