DIR-628EOL EOS
Description
EXCEPTIONAL PERFORMANCE
The D-Link DIR-628 RangeBooster N Dual Band Router is designed for users looking to create a high-performance wireless network. Connect the RangeBooster N Dual Band Router to a cable or DSL modem and provide high-speed Internet access to multiple computers, game consoles and media players. Create a secure wireless network to share photos, f les, music, printers and more, from greater distances throughout your entire home or off ce. We’ve also included a QoS engine that prioritizes time-sensitive online traff c to enable smooth Internet phone calls (VoIP) and responsive gaming.
DUAL BAND WIRELESS COVERAGE
The DIR-628 supports dual 2.4GHz or 5GHz wireless frequency bands. It can be conf gured to operate in one of these frequency bands at a time. With support for both frequency bands, you can check e-mail and browse the Internet using the more common 2.4GHz band, or stream HD movies and other media using the low signal interference 5GHz band.
ADVANCED NETWORK SECURITY
The RangeBooster N Router supports the latest wireless security features to help prevent unauthorized access, be it from over a wireless network or from the Internet. Support for WPA™ and WPA2™ standards ensure that you will be able to use the best possible encryption, regardless of your client devices. In addition, this RangeBooster N router utilizes dual active f rewalls (SPI and NAT) to help prevent potential attacks from across the Internet.
HARD DRIVE,MULTIFUNCTION PRINTER SHARING, 3G MOBILE INTERNET CONNECTION
TM Network USB Utility, you can connect an external hard drive or multifunction printer to the router’s USB port to share disk space, printing or scanning functions among family members or a group of users. This USB port also supports D-Link 3G adapter connection, so you can connect your router to a 3G mobile service to provide Internet access to a group while travelling.
General features
STANDARDS
+ 1 IEEE 802.11a
+ 1 IEEE 802.11b
+ 1 IEEE 802.11g
+ 1 IEEE 802.1n (draft 2.0)
+ 1 IEEE 802.3
+ 1 IEEE 802.3u
DEVICE INTERFACES
+ 4 10/100 LAN ports
+ 1 10/100 WAN port
+ IEEE 802.11a/b/g/n WLAN
+ USB 2.0
ANTENNA TYPE
2 external reversed SMA antennas
WIRELESS SECURITY
+ 64/128 bits WEP
+ WPA
+ WPA2
+ WLAN partition support
QoS
+ D-Link Intelligent QoS Technology
+ Wi-Fi WMM
FIREWALL FEATURES
+ Network Address Translation (NAT)
+ Stateful Packet Inspection (SPI)
+ IP/MAC Address Filtering
+ VPN Pass-through / Multi-sessions PPTP / L2TP / IPSec
ROUTER FEATURES
+ Port Forwarding
+ Port Triggering / Special Applications Support
+ Static Route Support (WAN Side)
+ DHCP Server
+ DNS Relay
SharePortTM FUNCTION SUPPORT
- Allows connection of external hard drive or multifunction printer to USB port
- Allows sharing of HD space, printing and scanning functions*
DEVICE MANAGEMENT
+ Internet Explorer v6 or Later; Mozilla Firefox v2.0 or Later; or other Java-enabled Browsers
+ Remote Management
+ Extensive logging of gateway events
+ UPnP support
+ WCN (Wireless Connect Now) support
+ DDNS (Dynamic DNS)
LEDs
+ D-Link Power-On Logo
+ Internet
+ USB
+ Status
+ WLAN 2.4 GHz (wireless connection)
+ WLAN 5 GHz (wireless connection)
+ LAN (10/100)
POWER INPUT
+ DC 5V /2.5 A
DIMENSIONS
(W x L x H) 117 x 193 x 31 mm (4.6 x 7.6 x 1.2 inches)
WEIGHT
380g (0.84lbs)
CERTIFICATIONS
+ FCC Class B
+ CE
+ IC
+ C-Tick
+ Wi-Fi
MINIMUM SYSTEM REQUIREMENTS
+ Computer with:
- Pentium 3 800GHz or better processor
- 256MB RAM or higher
- Windows Vista, XP SP2, 2000, 2003 or Mac OS X v10.4 or higher
- CD ROM drive
- SharePort
Certificates
Order info
DIR-628 802.11n DualBand Wireless Router with 4-ports 10/100 Base-TX switch
